Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 201 to 225 of 333
Thread: Conversion Parts For Sale
  1. #201
    Aug 2015
    Boston, Ma
    too many
    I'll be looking for parts to put an LS* into a 2000 E38. May go the e39 sub frame route.
  2. #202
    Jul 2013
    Minnesota
    B5 S4 stage 3
    Nisaan Sr20DET to e36 parts for sale!
    Custom engine and tranny mounts
    Driveshaft shop custom aluminum driveshaft
    Wiring specialties custom sr20-e36 wiring harness.
    Power steering hose needed
    Top mount manifold for stock or gt28 turbo
    Custom downpipe.
  3. #203
    Jul 2006
    Mckinney, TX
    E36, Cayenne S
    Selling an ls1 bare intake intake 160 shipped to your door!
  4. #204
    Dec 2014
    St. Louis, MO
    1994 BMW 318i vert
    Quote Originally Posted by 89gtcs View Post
    E36V8 motor mounts and CD swap guide for sale. Motor mounts appear to have been painted flat black.
    $150 shipped for motor mounts and $50 shipped for CD. Or buy both for $180 shipped.
    Are these still available? PM or email racinjason89@gmail.com
  5. #205
    Aug 2015
    dallas
    1993 325is
    GT40 intake system for your stock mustang 5.0
  6. #206
    Nov 2008
    nnj
    Vipers, e46m
    Looking for some LS swap parts. Let me know if you have anything.
    Specifically:
    Power Steering retrofit parts
    Corvette Filter/regulator and retrofit lines
    Throwout bearing with remote bleeder
    Steering shaft
    Throttle cable
    I may be interested in some other parts as well.
  7. #207
    Jan 2012
    Midland, TX
    1995 LS1 M3, 2001 750iL
    I have a Driveshaft designed for the ls1 swap. Only reason im selling is im going to a bigger rear diff which warrants a new driveshaft all together.
    The one i have was made by http://www.axle-exchange.com/ is 44.5" long and is steel. Comes with the appropriate 4-bolt flange as well.
    Would like to get $400 for it shipped.
    Current:
    E38
    2001 750iL - Current DD.
    E36 1995 M3 Coupe - Ls1/t56 - FIXED...now with a Ford 8.8 IRS Rearend
    E36 1998 323is Coupe - Back-up DD.
    R53: 2005 MCS W/ GP and JCW bits. - Wifes Project Car
    Past:
    E36 1999 Dinan M3 Coupe AW/Sand Beige - In BMW Heaven.
  8. #208
    Oct 2007
    sterling hts, michigan
    02 M3
    Quote Originally Posted by Inflame View Post
    Vorshlag Aluminum Drive Shaft - $250 Shipped.
    Bought it off Spec3HOR a few months back but I believe I'm going to run into fitment issues with a 3" driveshaft so I'm selling to get a smaller diameter steel shaft.
    I bought it off Spec3HOR broken, it needed the u-joint cap repaired. I had it repaired at a local facility to me, they took the cap off, cleaned up the ID of the driveshaft and OD of the cap, popped it back on 90* to the opposite end and welded it back together.
    I'll have pictures this weekend as the shaft is in my car and it's under a tarp covered in snow
    Bump, still have this! $200 shipped!
  9. #209
    Apr 2015
    1995 e36 sedan
    For an Ls swap right? I'm interested in it. One of the last big pasts on my to buy list.
    Ls2 e36 sedan
  10. #210
    Leicester, MASSHOLE
    99 323i?
    Quote Originally Posted by greenmonster138 View Post
    PRICE DROP $250 SHIPPED. Anyone need this let me know.
    Still have it make an offer.
  11. #211
    Oct 2007
    02 M3
    Quote Originally Posted by Jaxchrisfla View Post
    Yes, it is Vorshlags driveshaft for an LS swapped E36.
  12. #212
    Dec 2002
    Canada
    95 M3
    Quote Originally Posted by pMak26 View Post
    Specifically:
    Steering shaft
    Throttle cable
    I have a corvette filter regulator...Test fitted it to my car and then changed plans with an aftermarket regulator instead.
    I also bought the 3 an-6 male nipple adapters for the in, out, return lines from the unit. Will sell the package for $55 shipped!
    Topfuelman
  13. #213
    Mar 2004
    OKC, OK
    e30 Racecar
    SOLD!
    Up for sale is my Tilton (Sonic) Bellhousing, clutch/pp/flywheel/TOB , and reverse mount starter setup that was mounted to my e30/LS1 build with a TKO 600 RR transmission. This was sold as a kit through Coleman Racing (part # 20949). It will work with TKO and other similar 4 bolt transmissions with the same spline count.
    http://www.colemanracing.com/Driveli...ter-P3610.aspx
    The kit includes the follow:
    • Sonic Bellhousing for LS (maybe other?) blocks.
    • Sonic/Tilton lightweight flywheel
    • Sonic/Tilton 3 disk clutch/pressure plate setup
    • Extra set of clutch disks
    • Tilton hydraulic throwout bearing
    • Tilton reverse mount starter
    I installed this in my BMW e30/LS1 Racecar, and attended 1 track day to shake down all the changes I had made. The only time since it has had any use was moving the car in and out of the garage to make room to work on other projects. The clutch disks have virtually no wear! My racecar has sat, and I ended up pulling the motor or another project. I had hopes of resurrecting the racecar but as time has set in, the racecar just needs to go away – so parts are going up for sale.
    I've got over $1900 invested, I'd like to get $1300 (shipped conus) out of this sale. If someone is interested and doesn't want the spare clutch disks, I'll separate those.
  14. #214
    Feb 2001
    Kansas City
    6.0 Z3, E36 & F80 M3
    Ls3
    8000 mile LS3, choice of camshaft. $5,500
    PM me for details.
  15. #215
    Reston, VA
    SpecE46, 99LS/M3, 07GMC
    Car sold, have a couple LS Parts remaining
    Firebird Coil packs and coil pack brackets $50
    LS1 aluminum valve covers with gaskets only a couple thousand miles old $50
  16. #216
    Dec 2004
    Milford,CT
    95 M3
    Mods can delete this post
    95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
    10.4@136 Pump gas at 3530lbs.
    Build thread
    http://www.bimmerforums.com/forum/sh...LS-Turbo-build
  17. #217
    Oct 2007
    02 M3
  18. #218
    Mar 2004
    USA
    96 328is 6.0L
    May I ask what car did you use it on, LSx swapped? What cooler are you looking to upgrade to?
  19. #219
    Apr 2012
    colorado
    1997 LS1 M3, 2004 330xi
    E36 T56 Vorshlag transmission mount with nylon spacer...make a reasonable offer.
    http://www.vorshlag.com/product_info...roducts_id=161
  20. #220
    Oct 2007
    02 M3
    Quote Originally Posted by bimerok View Post
    Yes, my LS6 E36 M3 Track Car. Oil temps would peg my 250* gauge after 4-5 laps on a 80-90 degree day. I'm sure they're not much higher but I'd like to be able to drive harder and have nice stable temps between 220-240. I'm upgrading to a 42 Row Earls Oil Cooler.
  21. #221
    LA
    95 m3
    For sale is entire car. Everything you need is included.
    Ls1 and t56 approx. 50k mile. Vorshlag full swap kit.
    Custom exhaust.
    Asking $6,200
  22. #222
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I have a pair of RevShift poly motor mounts, which fit E36, E46, and E90-92 models. In the "track" 95A hardness. See: http://www.revshift.com/product-p/pmm-r36.htm
    I found out these are too tall for my swap, and I had to get the shorter E30 mounts instead.
    They were installed for a couple days, but never put in service. They have a tiny bit of discoloration on the bottom surface that touches the subframe, but are otherwise as new.
    If one of you has a use for them, I'm offering them out for $60 (half MSRP) plus shipping. Please inquire by PM. Thanks for looking.
  23. #223
    Aug 2012
    va
    97 m3 sedan
    I posted my LS2 swapped 97 m3 Sedan for sale in the 3 series car section. I may be willing to sell the engine and trans and Vorshlag Swap kit and various item to complete someone's swap if interested. I won't be selling anything off the car until I sell the engine an trans, so PM me if you have any interest in the cars engine and trans and swap parts. All the info on the car is in the 4 sale Post. ls2 1.jpg ls27.jpgls28.jpg
  24. #224
    Dec 2004
    Milford,CT
    95 M3
    FS: 3" steel driveshaft for T56 and 210mm diff Fits CX racing engine/trans mounts and 210mm rear diff. Probably won't work with a 188mm diff as the input is a bit shorter. No yoke just shaft and ujoints. 1310 joint in the rear and 1350 up front. $150 picked up in Milford CT Selling because I went with an aluminum shaft.
    Build thread
  25. #225
    Northern CA
    96 328is
    I have a wiring specialties e36 ls1 swap harness for sale. Comes with their flashed ecu, the coolant setup for the stock gauge, and the adapter oil pressure sensor. Only modification to the harness is the maf wires were extended to run the intake on the passenger side. Also comes with electric fan with plug wired to work with pcm
    Looking to get $950 or best offer
    Also have the rest of the full swap kit pulled from my completed swap
    Steel driveshaft with jtr flange and t56 yoke: $400
    Jtr headers painted with ceramic header paint: $400
    Vorshlag power steering kit:200
    Vorshlag t56 throw out bearing and aluminum master cylinder: $400
    Replica vorshlag motor and Trans mounts. Trans mount has sent from speed bump but still works: $400
    Shipping to be determined
