e36 lsx DIY
I have some energy suspension poly mounts for sale as well as a custom transmission cross member that is modeled after my vorshlag cross member but made from plate steel to allow better clearance for exhaust. I also have engine mount plate that bolt onto ls engine blocks as well as some thick wall tube that could be used to make a custom set of mounts. Also for sale is a custom e36 diff brace to put the diff in double shear(requires welding to the diff). Also for sale is two sets of 3" vband clamps and flanges that vorshalg supplied with there headers which i never used on my car.
All parts are OBO. With all this stuff it would not be hard to have an lsx engine in your e36. Just construction and welding of the engine mounts and drilling of the transmission mount.
2072408281 or sb1616ne@gmail.com
Focusing on my '69 Chevelle LS turbo swap..... Hope to do an e39 swap next...... but in the mean time this has to go.
complete e39 M5 3.15 diff with M5 axles $1500
black M5 carpet in perfect condition $250
90mm DBW ported new GM TB $300
90mm DBW exterior polished GM TB $300
'97 e39 528i: LS2 bottom end/LS3 top end with T7875 turbo swap. Rossler powerglide, PTC 9.5" convertor. Radium e85 surge tank.
M5 Suspension, interior, 3.15 rear diff. 800rwhp+, 9's@150mph+ with p/s and a/c project. Parts gathering mode.
'93 FD RX-7 with LS7: T56 Magnum/8.8" Cobra IRS/Ohlins 315 front/335 rear on 18" Forgelines 2800lbs 10.31@137mph 165mph 1/2 mile
delete.
E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
*RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
BMW turbo engine, known as M106 engine from e23 745i
With that engine you get:
-megasquirt
-RC550 injectors
-OEM EXHAUST COLLECTOR
-Selft made EXHAUST COLLECTOR, with that collector turbo starts working 1500 rpm faster than with OEM exhaust collector
-metal head gasket
-OEM turbo
-another more powerful turbo
-brand new claws(don't know how it is in english), not screws, to connect engine head with engine block
-control block
-manual gear box
That is full swap set to completely put this engine in any car, this set will fit perfect for E23, E28, E32, E34, easy to put in E30 also.
3150 euro, for shipping just ask, I think we will make a good deal.
my email lauris.davids@gmail.com
I'm parting out my 2000 528i with ~160,000 miles. It is a jet black car with a black interior. The wheels and drivetrain parts are not available for sale. If you are looking for something that is not listed, feel free to ask. ***wheels are not available***
Interior
Complete black interior (includes front heated non-sport seats): sold
Exterior
Taillights, pair:$30
Orange side marker lights, pair: $10
Side mirrors, pair: $60
Passenger side xenon headlight: $60
Heated steering wheel with clock ring and airbag, dual stage: $180
Misc
Front wheel speed sensor, each: $20
2003 M5 LSx l 6 Spd Manual l 4.10 LSD
Build Thread
The chassis must always be regarded as a means to an end and never as an end itself
Complete LS1/t56 e36 swap. $6900
Includes engine, transmission, Vorshlag swap kit, OBD2 wire harness, and all supporting parts for the conversion.
5.7L LS1 aluminum block V8
Engine wiring harness compatible with OBD2 BMW system
New starter
New power steering pump
Corvette engine covers
T56 6-speed manual transmission
MGW Short shifter
LS2 clutch & flywheel
Modified BMW master cylinder
Throw-out bearing kit (w/ remote bleeder)
Vorshlag swap kit
Engine/Transmission mounts
ABS relocate with custom plumbed brake lines
304 SS long tube headers with 3/4” primaries
Custom supporting parts:
Small diameter steering shaft assembly
Power steering lines w/cooler
2.5” diameter single piece drive shaft
Throttle cable system
Cold air intake system
Corvette fuel filter with all hoses and fittings
Cooling system with all hoses and fittings
Also available but not included
Custom duel 2.5” SS mandrel bent exhaust system with:
MagnaFlow high flow cats
Magna flow resonated x pipe
OEM e36 M3 muffler
3:91 LSD rear differential
95 M3 front and rear suspension/brakes
H&R lowering springs
Rear koni shocks
full set of M3 rubber bushing
See build thread for details.
I will consider selling the complete swap kit separate from engine transmission but I dont want to start parting things here and there.
I'm only interested in package deals so please don't ask for onesy twosy parts.
Send a PM for any questions, Thanks!
Anyone have a foam mockup block available for sale / rent? Looking for one to set driveline angles / build my mounts from
Sold...
E36 DIY Engine / Trans mounts. They are not painted, and come with everything pictured. Please PM me if interested in this set of mounts.
I also have the following
BNIB Fast LSXR 102mm LS2 Intake manifold - $830 + Shipping
2006 LQ9 78k 24t reluctor wheel.. Short block... I bought as a dropout minus the accessories.. I sold the heads only off of it.. $900
Photo's soon... All parts Located in Bunker Hill, WV
Forged 10.1 LS1 for sale, email if serious only please as parting out two projects, building a different car, modding a new dually and 43' trailer, getting the house ready to sell, going full time RV so damn busy at the moment
-1997 332ti CA edition street/track completely rebuilt in progress
-2012 Duramax dually, Ultra high end audio, maximum sound deadening, perf, handling, custom leather.
-2007 V8 4runner, murdered out, we love it buy might sell it instead of leaving it parked a few years.
-2012 43' Voltage Toyhauler, not quite a race trailer but will make it work, going full time RV all over NA with it to run on all the tracks I can
Forged LS1, barely used, 10.1 so great boost engine, ARP hardware, Eagle crank and rods, Molly pistons, sodium filled vavles, LS7 rockers, ASA cam, LS2 intake, 90mm TB, tuned ECU and harness, Melling oil pump and more, ready to ship, $4900 OBO and I do mean OBO, as long as reasonble that is
I have a few LS swap parts that I have no use for after selling the car. All parts are OBO.
I am located in Central Massachusetts.
Vorshlag transmission crossmember
Holley LSx oil pan kit
Radium fuel pump install kit with Walbro 255 pump.
Flaming River steering u-joints & DD shaft all stainless steel
330i front calipers
M [COLOR=red !important][COLOR=red !important]Roadster[/COLOR][/COLOR] cluster
You can text me at 716 949 7424 for fastest response.
LS1 F-body water pump, used, OEM General Motors casting number 12573175 . I don't know the mileage as I bought it used for my swap, but I only put about 7K on it. No issues at all. Only selling because I replaced it with a new unit trying to chase down a belt squeal issue. It has a brass fitting tapped into the top of the water pump body for your coolant cross over. DOES NOT come with outlet neck or thermostat. What you see is what you get.
$100 shipped
OEM LS1 F-Body Alternator Bracket - with idler pulley/bearing. Again no issues, but I replaced it along with the idler thinking it would help my belt squeal.
$75 shipped
Billet, very well made, 4" Maf housing, tapered input for better flow, includes 3/8" hose fitting(might be 1/4" as somethings are measured differenty) silicone coupler and two SS bands. I do not think I have ever seen a better made part like this. Not sure on the value just yet so starting off at $99 OBO shipped, I am sure it cost a great deal more and has barely been used, buffed up a little and it would look perfect as has a few water spots on it.
K&N 4" inlet cone filter, brand new. $39
I still have the forged LS1 for sale, I will take a reasonable offer, a very solid engine, see my post on it.
Slammed right now so no pics for the moment but I can get some for a seriously interested buyer
Rick
RF-1032 for the K&N filter.
4" inlet, base outer dia 6.5", top dia 4.5", length of element 8", top is metal, flange length is 1 5/8".
ehh, that' sucks.... the base and top diameters are too big for me...
Looking for an early OBD1 harness with a X20 plug for an M60
It's that last thing I need for my swap and I'm having trouble locating a good usable harness
94/95 b30 or b40 harness with the x20 plug.
If you have one please contact me with cost + shipping to 92887...
Does anyone have 2jz motor and trans mounts for an e36??
Forged LS1 with LS2 intake, 90mm TB, tuned ECU, harness, truck coils, barely ran, 241 heads, same as 243 when ported, very good parts and properly built for a road race series to the specs required, sold due to rule change to crate LS3.
With stock heads which will make a great deal more power with a port job it made 438 WHP on pump gas so much more is easily available.
Mahle pistons, 10.1 so great for boost
ASA cam
Cleavite bearings
ARP hardware
Melling pump
LS7 rockers, sodium filled valves
Brand new $100+ K&N filter included
$4900 shipped to the 48 states, OBO
Rick
801-452-5858
A/C lines for 4cyl to 6 swap, $99 shipped.
