Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 101 to 125 of 333
Thread: Conversion Parts For Sale
  1. #101
    Feb 2012
    Socal,ca
    97' E36M3 11' e92 lsxm3
    Im looking for anyone sell a LS2/3 engine... Im looking for a swap kit like Vorshlag or NA HotRods etc.. any info or leads.. im searching. Thanks
  2. #102
    Dec 2005
    Frederick, CO
    94 M353is
    SOLD - For those who bought an oil pan that didn't come with the oil cooler blockoff plate, I have the factory piece. It has one port (plugged) that can be drilled & tapped for a gauge sender or an Accusump. 15 shipped.
    EDIT: Cleaned out the garage and have a few more things that some folks may be interested in.
    AIR & EGR (?) exhaust gaskets. 7 shipped
    http://i76.photobucket.com/albums/j4...ps53f77584.jpg
    ABS wiring connector for those who want to relocate their ABS pump and not modify their original wiring. This can be spliced together to extend your OE wiring. 15 shipped.
    http://i76.photobucket.com/albums/j4...psb9bae04a.jpg
    Various AN fittings & hose. I have: (2) M14 banjo to male -3 AN adapters, a 10" long -3AN hose assembly with a straight female fitting and a 45 female, a male -4 to male -3 adapter, and an female M10x1.0 to male -3 adapter. 25 shipped for all of it. Will separate...we can work something out.
    http://i76.photobucket.com/albums/j4...ps3a670b64.jpg
  3. #103
    Aug 2008
    na
    na
    interested
  4. #104
    May 2012
    San Jose, CA
    are teh worst.
    Sold.
  5. #105
    Feb 2013
    Butler, PA
    E36 328iS, RB26 S13
    PM'ed Earl...
  6. #106
    Mar 2004
    USA
    96 328is 6.0L
    e36 LSx Engine Mounts and Trans Mount
    Hi,
    I have for sale my original e36 LS1 Engine mounts and Transmission Cross member that I've built for my car. I used it for probably couple of years before I was bored and redid the mounts in my car. These are obviously not pieces of art since it was the very first set that I've built for myself, but did work fine for couple of years. The same exact design that I duplicated off of these and are still in use and working in my cousin's LS2 swapped car that now lives in Denver.
    These mounts were made for my 1996 328is. These mounts will let you install an LSx engine and T56 trans in your e36 coupe with stock brake booster.
    You will need to buy the transmission mount that it was designed for - which is: Energy Suspension ENS-3-1108G. It cost about $25 from Advanced Auto Parts or you can order it from Summit Racing. The engine mounts that are used for this set up are: Energy Suspension ENS-3-1114G and included with the mounts.
    I was holding these mounts as I was planning on doing another LS1 conversion, but plans changed since and they just take up space in my garage. You can use these mounts to install the engine or have them as a starting/reference point and modify/upgrade them if you want to. Obviously custom headers will need to be implemented as my headers were custom built around these mounts.
    These mounts are sold AS-IS with no warranties of any kind. Again they were used in my car and worked for me just fine.
    You can see my build thread where I built and used these mounts in my sig. Also you can find a link to LS2 conversion where I built a dup of these mounts.
    Let me know if you have any questions.
    The price is $350 + S/H
  7. #107
    Sep 2010
    Acton, MA
    95 M3/2/5
    For sale is one of the t56 clutch line to BMW hard line adapters that come in sets of 2 from speedway.
    10MM-1.0 European to -4 AN Steel Male Brake Adapter Connector Fitting
    it was 27.24 for 2 shipped to my door, I will split it with someone and make it 13.62 shipped to your door.
    http://www.speedwaymotors.com/10MM-1...ing,32849.html
    EDIT: SOLD
  8. #108
    Fl
    1989 325i: 00 M Roadster
    Quote Originally Posted by bimerok View Post
    Hi,
    PM Sent
  9. #109
    Mar 2004
    USA
    96 328is 6.0L
    Replied with email since your inbox is full
  10. #110
    Morgan Utah
    1995 M3
    Built for LSA Trans Am legal with stage 1 Dry Sump(DS not included)
    Will make great road race engine or add boost!
    Eagle crank and rods, ARP studs, Clevite bearings, 10.1 Molly pistons,
    stock bore and stroke
    ASA cam, Comp valve springs, sodium filled valves, LS rockers and pushrods, ARP hardware
    LS2 Intake, 90mm TB
    Block, honed and deck measured
    Stock heads(will make much more power if ported)
    Melling oil pump, water pump with AN fitting, injectors, fuel rail, covers, coils, plugs
    New Aluminum tubing and silicone 45’s included
    6800 rev limit tuned ECU and harness, will spin to 7300 safely
    438WHP on 91 Octane, used for 2 sprint races by Tom Sheehan
    Just port the heads for a lot more HP or add boost!
    $4900 OBO
    I will be able to post pics of the engine on the stand with the pan off as soon as my back heals up a bit more, tweaked it last week on another project.
    Thanks,
    Rick
    801-829-4997
    -1997 332ti CA edition street/track completely rebuilt in progress
    -2012 Duramax dually, Ultra high end audio, maximum sound deadening, perf, handling, custom leather.
    -2007 V8 4runner, murdered out, we love it buy might sell it instead of leaving it parked a few years.
    -2012 43' Voltage Toyhauler, not quite a race trailer but will make it work, going full time RV all over NA with it to run on all the tracks I can
  11. #111
    Morgan Utah
    1995 M3
    Updated LS1 for sale info
  12. #112
    The Black Hills (Souf Dak
    Diesels and a 04 M3
    Anyone have a bead on a T56? Looking for one that will handle 450 easily
    I'm a ROLEX wear'N
    Diamond ring wear'N
    KISS steal'n
    WHEELIN DEAL'N
    Limousine RIDE'N
    JET PLANE FLY'N , SON OF A GUN!
    And I'm havin a hard time holdin these alligators down!!!!!!
    WHOOOOOO!!!!!!
  13. #113
    Morgan Utah
    1995 M3
    I have an LS oil line adaptor plate for hooking up oil coolers, Accusump, etc and a one way valve for sale as well as some fittings.
  14. #114
    M5Hunter is offline Still has a E39 Supporting Vendor
    Nov 2009
    Hanover, VA
    E39
    I've got an ABS harness "extension" for a e36 3 way ABS pump after you relocate it. Uses 2 OEM BMW connectors. Total length is 16"
    $20 shipped inside the US
  15. #115
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    I've got a t56 for sale - decided to put a magnum behind my engine. 38k miles out of an '02 TA and is in good working condition to my knowledge. Does not have a shifter on it though. PM if interested.
  16. #116
    Jan 2013
    Naperville, IL
    1993 318is
    E36 302 exhaust setup...2 passenger side stainless shorty headers, 4 vband flanges, 3 flex pipes, 2 02 bungs, all t304 stainless and tig welded and heat wrapped.
  17. #117
    San Pedro california
    '94 325is ls1/T56
    I have e36 ls1 engine and trans mount av available pm for pics and price
  18. #118
    Apr 2013
    Carlos MN
    73 Camaro, 67 Nova
    PM let me know.
  19. #119
    Feb 2008
    Upstate
    2 Boosted,1 more left to
    Brand new Ls1 billet fuel rail 10an feed to 8an return fitting black. 10an hose crossover black fittings $85 shipped
    E39 LSX SWAP PARTS FORSALE
  20. #120
    Dec 2003
    Arlington VA
    E30 M3
    Quote Originally Posted by ckpitt55 View Post
    Any chance you still have it?
    Those Who Stay Will Be Champions
  21. #121
    Aug 2003
    Arizona
    lsx powered....
    I have a brand new fully built LS7 for sale. Will ship direct from the builder(HKE in Texas). PM for details
  22. #122
    Mar 2008
    Bunker Hill, WV
    95 M3, 07 Titan, 96 XJ
    Quote Originally Posted by GoBLue View Post
    I bought that trans and may be selling it, due to going with a dog box.
    E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
    Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
    *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
    Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
  23. #123
    Feb 2009
    North Jersey
    E30 M50/E36 M3/ E39 525i
    looking for:
    T56
    LS6 Intake w fuel rails and injectors
    pm me!
    thanks
  24. #124
    Dec 2003
    Arlington VA
    E30 M3
    Quote Originally Posted by rpm620 View Post
    Shoot me a price and condition of it.
  25. #125
    Nov 2009
    Auburn, GA
    Chevy, xBMW's, LS Volvo
    I have OEM blue ls6 valve springs for sale. 2 sets available, brand new. Looking for $55/shipped per set in the continental us.
