This may be useful to the swap guys:
Cooling fan temp switch - Lower temp switch
http://forums.bimmerforums.com/forum....php?t=1926269
Complete LS7 pullout with dry sump/harness/clutch $8500
This is not mine, just came across it:
http://forums.corvetteforum.com/c6-p...-for-sale.html
Good morning,
Up for sale is 1 Vorshlag 2.5" steel driveshaft. T56 yolk and 4 bolt rear axle flange.
Price $550 shipped and insured.
Please PM me with any questions you may have.
Thanks,
Eric
Ktech manual belt tensioner for Corvette, Cts-v, Gto and F body LS1/6 . Replaces the spring loaded tensioner that is know for failure and throwing belts. Has about 8k miles on it. In good working condition, but not brand new. Part number : KAT-A4425
Retail is $119 plus freight
$85 shipped
Here is a list of items I have available..anything that is big / heavy / bulky is for local pick up. Prices do not include shipping
Mz3 parts ( car is Silver with Balck Interior)
GTO 2006 Parts- from my LS2 swap
AC compressor plus mounting bracket. (100)
Stock cam (50)
LS2 oil pan, baffle pickup tube. LS2 windbags tray (100)
LS2 large Throttle Body DBW (75)
LS2 stock throw out bearing (10)
LS7 fly wheel (25)
LS2 GTO engine covers (75)
MZ3 parts
~AC condenser (100)
~AC lines and Dryer (75)
~Electric moon roof with frame and motor + headliner(250)local pick up
~Interior panels misc stuff ( keping door panels and center console)
~Switches from center counsel for sale
-seat heaters switches (10ea)
-AC recirculation. (10)
-ASC (10)
- rear Defrost (10)
~Hamann side skirt aero piece (75) good shape- (rear right was refabricated)
~Oem side skirt Mz3 (50)
~2000 Mz3 Harmon Kardon stereo, sub woofer, amp and speakers (250)
~Rear hatch glass (75)
~Quarter glass. (50)
~Door glass (75) large 25 vent window
~Electric motors for windows (50)
~Front bumper rebar(60)new- this is a not aluminum ( local pick up)
~Radiator support- very slightly tweaked (100) Local pick up
~Cargo cover / rear net (150)
interior dome lights(20)
~S54 Radiator with overflow tank(100)
~S52 clutch fan (10)
~S52 oil filter housing (75)
~S52 mz3 stock differential (150) local pick up
~E46 m3 wheels from 2002 with snow tires ( blizzackLM2) (500) local pick up
~s52 guibo (10)
~super charger air to water heat exchanger - came with Eurosport twinscrew kit 5x18 (25 )
~Mz3 steering shaft (50)
~s54 double oil cooler line (15)
~E36 M3 ( from 1999 car) 4 channel abs pump x2 (100) ea
~E36 m3 ( 1999 car) computer ASC/dsc x 2 (100) ea
~E36 abs harness ( 1999 car) ( 75)
~Porsche Brembo front calipers (150 pair ) Not S model
~mz3 air bags doors and passenger dash mount (75ea)
~Mz3 steering wheel + air bag leather man accent tab (100)
~Vibrant black polished catch can. (25)
~Mz3 S52 servo and master cylinder (100)
~E36 s52 servo and master cylinder(100)
~Tck 600 lb rear springs (50 pair)
~Mz3 power steering cooler ( mounts around radiator ) (25)
~Brembo boxster s calipers machined for rally road brackets with front rotors e46 m3 325mm x 28 (375 with rotors) - fits 17 inch wheels
SSR Comp 17x9, 17 x10 ( pick up only) 900
~Mz3 ABS unit 4 channel plus ASC / DSC computer
00 MZ3 with LS2 /T56 swap (425rwhp/404Torq corrected to SAE), with oil cooler and 3 qt accusump, TCK DA, , 1.75 in Vorshlag Headers, RD Sways, Dinan Upper Strut, Turner Brake Cooling with Stainless Lines, DTC90 Pads, Fidanza LTW Fly Wheel and LS7 clutch and pressure plate, Hurst Shifter Hamann Kit, Digi tec Wing, Full grand am style cage from Deman MotorSports, New Age radiator, Lower temp alum thermostat, center 75d FCAB, Rear Camber and Toe plates, AKG 75d bushings throughout , SLR Roll Center / Bump Steer Correction kit, Turn one power steering pump and cooler, Rogue Rear Strut mounts, TCK Camber Plates, 18x10.5 wheels with Hoosier R6, Rogue Dual-Ear diff, Randy Forbe Reinforced Diff Mounts, adjustable sway bar end links, 500/700 springs, Custom Advanced Motorsports carbon fiber hood, carbon fiber roof, bumper cover, splitter and Dive Planes, Pole Position, lexan Windows, PBR C6 z 6 piston calipers with C6z rotors,custom dual master cylinder pedal box...
Chuck Musello, owner of Corvettes of Westchester - who tuned my car to absolute perfection....runs a great shop just off Rt 9 near Bear Mountain Bridge....COW
Has a fully dressed 2009 LS3 from a C6 with 20K miles. Super clean.
New WP, TB, Intake and injectors. Comes with tuned PCM.
No wiring harness..
$4700 ( I am not marking that up...just sharing the info with my BFC community) ....
If intersted...you can call him directly ...he is a great dude..and knows LS tuning as well as anyone.
37 Old Albany Post Road
Ossining, N.Y. 10562
914-332-0049
www.corvettes-of-westchester.com
I have a oilpan from a 06 Gto (front sump) that is used in a lot of ls conversions. $200. Is is in good condition with no cracks. It has the tubes and baffle inside. I don't have the pickup tube but it costs $21 new.
Alex
S70driver@ rocketmail.com
561-601-3080cell
1998 F-Body manifolds, stamped steel, i started to cut up the passenger side before finding a better solution. make me an offer.
passenger side flange cut off.
LS shorty headers, forgot the brand. surface rust, otherwise no problems or cracks. $200 shipped
LS Truck 6.0 iron manifolds, great for turbo application. $100 shipped
e-39 "welder series" engine mount brackets and transmission mount (5/16 brackets) for sale - $100$ 1 set left.
e-39 i6 differiental flange to standard spicer flange for standard 1350 iirc u joint - $100 each 2 left
f-body intake manifold - $100 1 left
some stuffs in the closet, others in the garage.. either way i know its there and want the space lol if interested, pm
2006 X5 L83 5.3 6l80 swapped in progress
1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
2007 ZX-10r - sold
1987 R-10 SWB L83 5.3L 6L80e swapped
Hello All,
A good friend of mine who has a couple of LS FD's was planning on putting together a LS2 E36 car for a DD. He recently turned on of his FD's into a Time Attack car and need to get a better tow vehicle and decided not to go through with that project. So he is selling his LS2 on NoRotors (http://www.norotors.com/index.php?topic=15474.0) and I though it was a pretty good deal. Please see below for details:
I have a full LS2 engine out of a 2005 GTO. The motor has 32k miles on it and comes with everything you see in the picutures. The alt and crank pulley will come with it. I had them off to mock up something on another motor. The only item missing is the throttle body but I have one from a LS1 that I will throw in with the engine. I have pictures of the cluster and video of the engine running. Looking to get $3500 shipped. Shoot me a PM or call / text me if you are interested. My number is 414-791-2414. I'm in Milwaukee but will deliver if you are around that area like Chicago or madison, etc.
Thanks,
Scott
I made an offer and lost out on that LS2. Sold locally...
:: 1999 BMW 528iT ::
LS3 / T56 swapped
There's a modified GTO oil pan for sale over on LS1Tech. Originally for an IS300 swap but I don't see why this wouldn't work for someone putting an LS into their 540i (8 cyl chassis only).
http://ls1tech.com/forums/parts-clas...s300-swap.html
Putting my car up for sale. Even if you didn't like my chassis you could buy the car, use the swap for your car and put your current engine in and come out way ahead of buying everything separately.
http://forums.bimmerforums.com/forum...1#post26289141
2001 330i.
I have a 5.3L long block (block, crank, rods, pistons, heads, intake manifold, etc.) that has been disassembled, inspected, and is ready to be honed and reassembled. I was going to use it before I found the LS6 block/LS7 crank I'm currently using.
$350 and its yours (local preferable)
Also have a Z4M roadster driveshaft that will connect up the 6 speed to an M rearend. So anyone with a 6 speed Z4 who wants the M rearend (LSD), buy my driveshaft, find yourself an M3 rearend, and you have a direct swap setup. $200.
Chris
Also willing to sell the whole LS1/T56 swap. $7,900 for everything.
2001 330i.
anyone have a coolant temp pigtail for a 2001 540i? I sold my old E39 harness a while back.
plugs into this style sensor. i'm sure it's universal across many models. couldn't find one at the local yard.
you can order from your dealer or bavauto or elsewhere,
Plug is: 12521703571 (~$5)
Pins w/ ~ 1 foot wire: 61130007657 (~$2)
I ordered 4 wires and got two that are male pins and 2 that were female pins. The male pins I guess are universal and can be cut so that they are female. I ordered from Bavauto. Then just check resistance between the prongs. One will be around 2k and the other around 6k at ~70F. The 6k is the one for the coolant guage and the 2k I believe is for the DME. (This is all from memory on hook up but this info has been posted on here somewhere.) On the thread with this information it talks about the sensors that are the same for the BMW's. It sounds like the coolant temps may be the same across the lineups but I would double check the thread to confirm.
i want a turbo
I have a spare LS1 motor that I picked up. Looking to sell for $1,750. Longblock only. Came out of a wrecked camaro.
Description: A long-block LS1 F-body with requisite camaro oil pan for swaps. Ran great, can include LS1 intake manifold. I picked it up to do an LS1 swap in my M3.
Pictures:
I will consider parting my car out if there is interest in the full drive-line and or all the swap parts as a package. (rather just sell the whole thing, link below)
http://forums.bimmerforums.com/forum....php?t=2001026
I will swell the SWAP components for $2500, this would include:
Engine and trans Wiring Harness already setup to work for the E36 Chassis and a 3g Explorer Alternator, Proven to work, and work well .
Un-Equal length generic shorty headers with custom Y-pipe and full 3 inch exhaust to a flow master 10 that was custom built for an E36 Sedan.
E36V8 Motor and Trans swap Brackets, along with manual.
Poly (Ireland Engineering) E30 motor mounts to use with the swap brackets.
Brand new Trans mount that works WITH the swap trans member.
Fox mustang Driveshaft with JTR Rear flange, brand new 1310/1330 Ujoint, is the correct length to work with a Fox T5 in a E36 sedan and bolts straight up to a Medium case Diff.
Hydro Clutch Conversion and lines.
I will sell the full drive line for $2,000, this would include:
FULL 5.0 Explorer longblock top to bottom (many/most parts are new as outlined, which includes a 90mm Maf tuned to 30lb injectors that are installed, ProForm intake, FRPP GT-40X Alum heads, Fully assembled with FRPP Springs/valves/seats/etc)
Oil pickup and Pan were switched to BRAND NEW fox mustang parts, and I replaced the oil pump with a high volume unit.
ProForm 1.6 Roller Rockers
intake spacer
Brand new RAM HD Clutch
Fox T5 Trans
I will sell the wheels and tires for $500 (Tires are like-new Dunlops, rims are very clean, and can be seen in the pictures below, will only sell if the car gets parted)
I will sell the 3.91 M3 LSD Diff with 325 Flanges for $250 (but will only sell this if the car gets parted)
I will sell the shell rolling on steelies (Which is rust free, from LA, no sunroof, PS Bypassed) for $650 (but will only sell if the car gets parted)
'pics for clicks' of what I have:
Selling my Vorshlag mounts, have them listed in the classified section here's the link http://forums.bimmerforums.com/forum....php?t=2004888
^ Man I thought that they were the LS1 mounts, got excited for a second...
T56 transmissions are sold.
Im looking for LSX swap parts.... just finished my cage now moving onto motor and trans... all help or leads appreciated.
