Page 14 of 14 FirstFirst ... 4567891011121314
Results 326 to 333 of 333
Thread: Conversion Parts For Sale
  1. #326
    Houston, TX
    1997 M3 Sedan
    JTR headers $600 shipped in the lower 48. These are an early version with a standard 3-bolt collector flange. Jet-Hot 2000 coated in flat dark gray. They fit perfectly with the stock steering shaft, CXR trans crossmember, and homemade engine mounts.
    Sent from my iPhone using Tapatalk Pro
  2. #327
    Dec 2018
    Murfreesboro, TN
    '99 528iT
    I have a set of Jesus Freak E39 LS/T56 swap mounts for sale. PM me for deats, or send me an email: carcrazyethan@gmail.com.
    Sold. Thanks.
    E39 enthusiast.
    '89 535i/5 Zinnober 👍
    '99 528iT
    '16 Toyota 4Runner Ltd - tow pig
  3. #328
    Ft. Lauderdale, Fl
    E36 M3, Mk2 GTI
    Selling a Full AR5 swap for an e36 shift knob to driveshaft spline. No 5th gear, didn't break just keeps popping out of gear. Looking for 1k obo, more pics on request and willing to split some stuff up. Only thing you'll need to finish the swap is the slave cylinder and drfeshaft. Which I can give you the length for and plenty of pics.
    R154 bell housing
    R154 fork
    Spec stage 3+ clutch and pressure plate
    1jz evolution flywheel
    Colorado Ar5 welded to fit E36
    Custom trans mount
    Stainless steel slave cylinder line
    GM 27 spline yoke
    PM me for the fastest response and pics on request
    MODS
    1JZ, BC 264 cams, BC TI Springs and Retainers, Ferra Keepers, Arp Head Studs, Arp Main studs, Arp rod bolts, Custom Emerald Performance Dual Plenum intake, 70 mm TB, SC6169 T3 Turbo, full 3 inch SS exhaust, Ar5 Transmission, 60lb injectors, Walbro 400 fuel pump, GTR intercooler. Porsche Turbo Calipers, Gutted Tein SS coilovers with Koni Race shock inserts , Tein Pillowball Camber Plates, UUC Swaybarbarian bars....needs more mods and a tune!!!!
  4. #329
    DEИVEЯ, CO.
    95 M3 6.0 Litre
    E39 nascar style sway bar
    Anybody selling their e39 nascar style front sway bar? Company that have correct bar, does not have correct splines for the 15* arms or vise versa.
  5. #330
    Jan 2014
    SF, CA
    S/C LS2 e46, LS e367&8
    Pulled apart a E46M3 ZCP. Below is what’s currently leftover.
    Partout list:
    Brembo GT front and rear brakes (yellow calipers, less than 400mi of use since new) -7k
    LS2/T56 (sub 300mi on the LS2)
    BMW E46 (m3 fitment driveshaft)LS swap parts (header back exhaust, mounts, power steering line, clutch line, stainless steel fuel hardline+filter+fpr)
    2005 m3 competition chassis (sub 84k miles, clean title, no damage - pulled apart for easier sale)
    pandemusa body kit (painted ithaca verde like the chassis)
    statusgruppe trunk and CF rear diffuser (no fitment issues)
    rotiform HUR wheels (stancey dancey hotboi fitment)
    air_lift_performance 3P+airlift M3 front and rear struts (ithaca verde painted air tank attached to rear strut bar)
    mishimoto radiator w/ Spal fan riveted to shroud
    Complete M3 rear subframe (diff, axles, arms, hubs)
    Ls2 bareblock
    243 heads
    GTO oil pan
    Fbody oil pan
    6.2L truck intake, complete.
  6. #331
    Houston, TX
    1997 M3 Sedan
    Set of used JTR headers for sale. These are an early set with 3-bolt collector flanges. They have been ceramic coated w Jet-Hot 2000 TBC. $600 shipped to the lower 48. IMG-20220326-WA0003.jpgIMG-20220326-WA0000.jpgIMG-20220326-WA0001.jpgIMG-20220326-WA0002.jpg
    Sent from my SM-A426U1 using Tapatalk
  7. #332
    Aug 2022
    Dewar,Ok
    01 525i sedan 5-speed
    Is this a 6-speed?
  8. #333
    Apr 2012
    Calgary, Alberta, Canada
    1992 325i
    Looking for headers (CX racing or JTR) if anyone has them. Would prefer CX since I know they will work with my setup. Message me if you have a set
    92 325i TCD Turbo | 98 528i
    Instagram: @kairaspo
