FOR SALE $300 plus shipping- Custom 1-piece Driveshaft for E36 LS/T-56 swap. 51" length overall. 48" critical measurement from transmission seal to differential input flange face. 3" diameter tube. JTR 4-bolt flange. This was made at a local Houston driveshaft shop called C&T Driveshafts for my setup which uses homemade engine mounts and a CX Racing transmission crossmember and the stock 188mm differential. This driveshaft was mounted to check for fitment but never used. I decided to swap to a 210mm differential before the swap was finished and it made more sense to use a 2-piece driveshaft with the CV joint to match the 6-bolt input flange on the 210mm diff. Please respond by PM.
Items no longer for sale
E39 LSX SWAP PARTS FORSALE
Unfortunately I ended up having to part out my E39/LS swap. I have sold off the car, motor and trans, but I do have several parts left over if anyone wants a cheap start to their conversion. All parts are located in Salina, KS (67401). Pickups preferred, but I can ship at the buyers expense. If you have any questions, please feel free to ask. Pictures of the swap can be found here http://www.candbmotorsports.com/gall...tvehicles/BMW/
Modified GTO oil pan. Notched for clearance to the 540I crossmember. Comes with oil pan, pickup and dipstick (dipstick handle is broken, could be glued back together). $400
540I driveshaft shortened for use with 4L80 automatic. Has new yoke, u-joint and center support bearing. Only missing nut from front to back half. $75
E39 540I LS Motor mounts. Tubular style. Were used in conjunction with the modified oil pan above. Has been powdercoated black. $300
Early LS (3 lengths of studs) import head studs. Studs have some silver overspray on the tops from being threaded into a mockup block. Have not been torqued though. $50
New LS1 Corvette radiator with used but clean factory Vette fans. $200
Thanks,
Chris
E39 Swap Parts For Sale
PM sent
FS: New Age Hot Rods E36 LS&T56 swap mounts - 950
Removed.
I have a bunch of parts left over from my swap I would like to sell to someone for very cheap. I just need this stuff out of my garage.
(2) 2-1/2 v band clamps with flanges.
Portion of a D steering shaft. Plenty long for another swap car.
Custom homemade transmission mount. That was modeled off a Vorshalg mount(same geometry but uses a poly bushing to reduce vibration) needs holes drilled and paint. TIG welded.
Engine mount plates for an LS and poly engine mounts. All someone would have to do it mount the tranny with my mount and then fabricate there own mounts from the subframe to poly.
(2) Inovate wide band o2 sensors. I was using these for data logging but one of them was not responding. These have been sitting for years so I don't want much for them since I have no way to verify them working.
Custom diff bracket that can be welded to the diff and grade 10.9 bolt.
A few random fittings I used to adapt the metal GM fuel rail to AN hose.
A small roll of Summit Racing AN hose
Big box of random wire harness cleanup conduit that I bought. I had to buy much more than I needed for my swap from MC Master.
I am looking for this stuff to go to a good home so most offer will be accepted.
If anyone has E39 I6 LS stuff, shoot me a PM. I’m starting to dip my toes in the water with a car
sold
Got two LS e36 builds going, if anyone has parts that will help with the swap (mounts/headers/driveshaft wiring) please PM me.
Thanks in advanced!
Looking for JTR flange if someone has it please let me know!
New Age Hot Rods headers - 750
Thought I would try on here, but looking for some Jesus Freak E39 I6 LS motor mounts and possibly 4L80e trans mount. Doesn't have to be his mounts, but something similar that would work. Thanks.
I have a dbw pedal and tb from a 2014 camaro ss ls3.
$200 obo
https://imgur.com/a/X8nGryO
I'm going 6-speed manual so the E39 Automatic shifter is for sale. This shifter is heavily modified to accept a Shiftworks 4L80E cable and brackets. The shift detents on the shifter itself have been modified so the lever locks in the correct places relative to the internal detents in the 4L80E. The range switch is setup to activate the reverse lights through a ground trigger. A manual shifter boot is required. Pics can be found in my build thread "Project 560i" or PM me and I'll email you pics.
$100 shipped anywhere in the continental U.S..
Thanks!
S.F.
F-Body LS1 Oil Pan with pick-up for sale. Removed from a 2002 LS1 Pontiac Firebird Trans-AM 5.L purchased for swap.
I'm running a dry sump system and do not need.
will isell for $150 shipped in the US
Stock Camshaft from same engine in excellent cond engine had only 46k miles on it.
$75 shipped in the US.
Stock Harmonic from same engine in excellent cond rubber looks like new
$50 shipped in the US
PM me for Pictures.
I have a few parts for sale from my LS swaps that might helpful to LS swap guys.
1. T56 bell housing. New. $200.
2. A pair of 241 LS heads. About 40,000 miles. I put AFR's on my LS1. $100.
3. 4L60E tail shaft and main shaft. It allows you change a 4x4 4L60E into a 2 wheel drive 4L60E. $90.
4. 8 LS1 pistons and rods. About 40,000 miles in good shape. I put forged in my LS1. $90.
5. 2002 Camaro ac compressor and mount. Includes new idlers. $100. Sold
All pricing does not include shipping. I don't do Pay Pal so check or money order. Cell is 320 266 7531.
Complete turn key E30 LS swap in CT
https://newhaven.craigslist.org/pts/...746878292.html
95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
10.4@136 Pump gas at 3530lbs.
Build thread
http://www.bimmerforums.com/forum/sh...LS-Turbo-build
That seems like a really good deal, wonder what the headers look like....
Build thread
Prices reduced on all I posted above.
T56 bell housing. $180.
241 Heads$90
LS1 pistons and rods. $70
6.0 Coil packs pair. $100
Fbody AC compressor, mount and new idlers. $75 Sale pending.
Prices do not include shipping. No Pay Pal cell is 320 266 7531.
