Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 226 to 250 of 333
Thread: Conversion Parts For Sale
  1. #226
    Nov 2012
    Va
    2004 STi, 1996 318i
    Selling the following parts that were used on my lsx swap.
    vorshlag abs relocation kit
    cx racing radiator piping kit to connect to stock radiator. ( I used on it on my mishimoto with no problems)
    e36 lsx intake comes with maf sensor and could include a IAT sensor.
    two spal 10 inch fans. Worked perfect on my ls1 with a mishimoto radiator
    ls1 fuel rails and injectors (good for truck motor swaps) from 04 gto
    cx racing e36 lsx swap catback exhaust 3 inch v band connection
    message me for price
  2. #227
    Northern CA
    96 328is
    Quote Originally Posted by adame36m View Post
    i have a wiring specialties e36 ls1 swap harness for sale. Comes with their flashed ecu, the coolant setup for the stock gauge, and the adapter oil pressure sensor. Only modification to the harness is the maf wires were extended to run the intake on the passenger side. Also comes with electric fan with plug wired to work with pcm
    looking to get $950 or best offer
    also have the rest of the full swap kit pulled from my completed swap
    steel driveshaft with jtr flange and t56 yoke: $400
    jtr headers painted with ceramic header paint: $400
    vorshlag power steering kit:200
    vorshlag t56 throw out bearing and aluminum master cylinder: $400
    replica vorshlag motor and trans mounts. Trans mount has sent from speed bump but still works: $400
    shipping to be determined
    bump
  3. #228
    Buffalo, NY
    2001 BMW 540i/6
    LS1 Corvette intake manifold for sale
    NO EGR port.
    MAP sensor clip is in perfect condition, comes bare with NO rails or injectors.
    Only removed to do an LS6 intake swap.
    Perfect working condition, just needs to be wiped down. Great for a swap car, custom project, etc.
    $120 picked up in 14086
    $150 shipped
    Please call or text 716 949 seven 4 two 4 or PM me
    _DSC4975 by Norbert Ogiba, on Flickr
    _DSC4974 by Norbert Ogiba, on Flickr
    _DSC4976 by Norbert Ogiba, on Flickr
    _DSC4979 by Norbert Ogiba, on Flickr
    _DSC4980 by Norbert Ogiba, on Flickr
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
  4. #229
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by mbfinatic View Post
    Can you send me a price on the ABS relo kit and the E36 intake?
  5. #230
    Oct 2008
    Columbia, MD
    96 M3 TT LSx
    I have vorshlag headers for sale with vbands welded on. 1 clamp included, the other clamp got bent in storage. So you'd need 1 entire assembly (2 flanges and 1 clamp) to complete your exhaust with these headers. They have slight indentations where the mandrels bent them but this is barely noticeable and does not affect performance. I also slightly dented one of the primaries near the collector to clear the FCAB. - $1200 OBO
    Also have Spec Stage 3+ clutch and pressureplate w/ 15k miles (no flywheel) - $250 OBO
    WIll post pics of both tomorrow. Probably have more swap parts as well.
    96 M3 | Forged LSx | Twin S366 | Injector Dynamics | E85 | AEM Infinity
    90 Schwarz 325i
    IG : sdobart
  6. #231
    Northern CA
    96 328is
    Quote Originally Posted by AdamE36M View Post
    I have a wiring specialties e36 ls1 swap harness for sale. Comes with their flashed ecu, the coolant setup for the stock gauge, and the adapter oil pressure sensor. Only modification to the harness is the maf wires were extended to run the intake on the passenger side. Also comes with electric fan with plug wired to work with pcm
    Looking to get $950 or best offer
    Also have the rest of the full swap kit pulled from my completed swap
    Steel driveshaft with jtr flange and t56 yoke: $400
    Jtr headers painted with ceramic header paint: sold
    Vorshlag power steering kit:200
    Vorshlag t56 throw out bearing and aluminum master cylinder: $400
    Replica vorshlag motor and Trans mounts. Trans mount has sent from speed bump but still works: $400
    Shipping to be determined
    Bump
  7. #232
    Somewhere, USA
    2000 “560i”
    FS: 04-06 GTO Front sump LSx oil pan, windage tray and dipstick.
    I've got a good used GTO oil pan assembly for sale. Comes complete and is clean and ready for your swap project. I bought it to use in my E28 swap but I've sold that car and am now building a E39. This pan is great for E28's or V8 subframe E39's. Got it on EBay right now, can be found here:
    http://www.ebay.com/itm/201589007745...84.m1555.l2649
    S.F.
  8. #233
    Sep 2015
    Stow, MA
    1997 328i
    I have a couple of items available:
    EDIT: Everything sold
  9. #234
    The Black Hills (Souf Dak
    Diesels and a 04 M3
    http://www.bimmerforums.com/forum/sh...LS1-Long-Block
    NICE Engine to start with. Should make 430 rwph with LS6 intake and other parts
    I'm a ROLEX wear'N
    Diamond ring wear'N
    KISS steal'n
    WHEELIN DEAL'N
    Limousine RIDE'N
    JET PLANE FLY'N , SON OF A GUN!
    And I'm havin a hard time holdin these alligators down!!!!!!
    WHOOOOOO!!!!!!
  10. #235
    Sep 2015
    Stow, MA
    1997 328i
    LS1 flywheel still available, mounts and L33 harness sold.
  11. #236
    Jul 2016
    Viet Nam
    BMW M3 Coupe
    I bought it from a guy that never wronged me before . I was told I needed a 260 for a OD trans and just got it
  12. #237
    Sep 2015
    Stow, MA
    1997 328i
    Also have a GTO T56 shifter and shift rail available- SOLD.
  13. #238
    Elizabethtown, PA
    99 540i6
    LS6 intake, 42lb injectors (8.1 marine/truck connectors), Professional Products fuel rail.
    Separated:
    LS6 Intake (Bolts included, no head port gaskets) - $420 shipped
    42lb marine Injectors - $210 shipped
    Professional Products Powerflow Fuel rail / crossover line - $60 shipped
    '99 BMW 540i6 L33 5.3, PRC Heads, E-force supercharged
    http://forums.bimmerforums.com/forum....php?t=1674320
  14. #239
    Sep 2015
    Stow, MA
    1997 328i
    Selling my NAHR E36 swap stuff.
    I have the LS swap headers available. Would like to sell as a package. Previous owner used them for a couple of track events then went to a different setup (forced induction I believe). I only mocked them up in my car and have not run it.
    These headers retail for $1400, looking for $679 or best offer. Will take partial trades for E36 suspension pieces or for Sparco/Recaro/etc buckets (looking for coilovers mainly, but could be interested in a spring/shock kit). I can send pictures to anyone interested.
    Edited, pictures added:
  15. #240
    Nov 2008
    nnj
    Vipers, e46m
    Ls1 coil harness, right and left sides. sold
    Stock F-body shifter, $70 shipped:
  16. #241
    Northern CA
    96 328is
    Jtr headers painted with ceramic header paint: $400
    headers are sold everything else still available
  17. #242
    Nov 2008
    nnj
    Vipers, e46m
    I have a brand new LSx starter for sale. I bought it for a friends build, then left it at my house like an idiot. Wasn't going to drive 2.5hrs to go get it so bought another one local.
    My idiotness, your gain.
    It's smaller than stock for better clearance:
    SOLD
  18. #243
    Apr 2016
    Kahnawake
    2002 540i
    Motor mounts for LS into v8 e39. Made by bmwman528e. Paid $400, asking $300. For Faster response, email me directly.. Grand_national87@hotmail.com
  19. #244
    Sep 2015
    Stow, MA
    1997 328i
    GTO T56 shifter and shift rail- SOLD
  20. #245
    Sep 2010
    North Carolina
    1998 M3 - Lsx
    I have a 80k F-body T56 with bellhousing, hydraulic throwout and BNIB MGW shifter. - Asking 1700
    I also have a ~100k 3.91 LSD in good working order with new seals, red line fluid, crush washers and m3 flanges included. - Asking 450
    And lastly I have a freshly built LQ9, done by my machinist to spec, with ARP hardware. Has a SNS torquemax stage 2 cam. Very torquey, specced for an e36. 0 miles, never installed. Still at the machine shop. - Asking 3500
  21. #246
    Diesels and a 04 M3
    http://ls1tech.com/forums/parts-clas...l#post19434063
    Heads/cam LS1 long block. Great starting point
    JUST SOLD!!!!!!!!!!!!!!!!!!
    SOLD
    SOLD
    SOLD
    SOLD
    I'm a ROLEX wear'N
    Diamond ring wear'N
    KISS steal'n
    WHEELIN DEAL'N
    Limousine RIDE'N
    WHOOOOOO!!!!!!
  22. #247
    Dec 2004
    Milford,CT
    95 M3
    Built T56 with RXT twin disc and fluid pump $2400obo in CT
    newhaven.craigslist.org/pts/5853054475.html
    T56 shift lever made to center in the console and take a stock BMW knob.
    $50 shipped
    95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
    10.4@136 Pump gas at 3530lbs.
    Build thread
    http://www.bimmerforums.com/forum/sh...LS-Turbo-build
  23. #248
    Mar 2005
    Charlotte, NC
    97 M3 Coupe, 93 240SX, 03 Pathfinder
    Quote Originally Posted by sdobart View Post
    Will post pics of both tomorrow. Probably have more swap parts as well.
    Are these still available? I'll shoot you a PM too.
    -Andy
  24. #249
    Sep 2014
    The Netherlands
    E46 BMW 330/ Een BMW Z4
    Quote Originally Posted by 2Fass240us View Post
    -Andy
    Pictures will be handy
    Sent from my SM-N9005 using Tapatalk
  25. #250
    Sep 2014
    The Netherlands
    Quote Originally Posted by iflytii View Post
    SOLD!
    Up for sale is my Tilton (Sonic) Bellhousing, clutch/pp/flywheel/TOB , and reverse mount starter setup that was mounted to my e30/LS1 build with a TKO 600 RR transmission. This was sold as a kit through Coleman Racing (part # 20949). It will work with TKO and other similar 4 bolt transmissions with the same spline count.
    http://www.colemanracing.com/Driveli...ter-P3610.aspx
    The kit includes the follow:
    •Sonic Bellhousing for LS (maybe other?) blocks.
    •Sonic/Tilton lightweight flywheel
    •Sonic/Tilton 3 disk clutch/pressure plate setup
    •Extra set of clutch disks
    •Tilton hydraulic throwout bearing
    •Tilton reverse mount starter
    I installed this in my BMW e30/LS1 Racecar, and attended 1 track day to shake down all the changes I had made. The only time since it has had any use was moving the car in and out of the garage to make room to work on other projects. The clutch disks have virtually no wear! My racecar has sat, and I ended up pulling the motor or another project. I had hopes of resurrecting the racecar but as time has set in, the racecar just needs to go away – so parts are going up for sale.
    I've got over $1900 invested, I'd like to get $1300 (shipped conus) out of this sale. If someone is interested and doesn't want the spare clutch disks, I'll separate those.
    I am interested in the clutch
