Results 1 to 20 of 20
Thread: No High Beams, No Dash Error..?
    Oct 2008
    From Maryland to New York
    E46 M3
    Seems my high beams are on the fritz. My low beams (DDM 55w HIDs) and fogs work just fine. The blue high beam dash indicator works. I do not get an error message on the CC readout. Are the highs even wired into the ccm?
    The bulbs are good, I checked them with a 12v power source.
    Any ideas?
    Dec 2007
    South of Boston
    Scrap
    There is no error with highs
    NW suburban Chicago
    hiss by my window
    The high beam signal to the LKM is processed through a relay in the crash module. Perhaps a good swift backhand on that module will wake it up.
    I assume you've checked fuses.
    Jul 2005
    Crook County
    BMW X5, Lotus
    Both high beams not working? Sound like a relay problem. Check to see if you get 12v at the connector. You may want to check the fuse that provide power to the relay.
    Quote Originally Posted by GarrettSR5 View Post
    Hate to admit it but attack_eagle is right.
    Quote Originally Posted by SpiritofBavaria View Post
    ............. then upallnight has probably got it right
    Spirit
    Oct 2008
    E46 M3
    I did check the fuse but not the relay.
    Also, I did pull my crash control module/relay months ago because of the hazards going off randomly. But I think my highs worked after I had pulled it. I'll stick it back in and see what happens.
    Thanks guys I'll give it look when I get home from the office.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by PorscheDude View Post
    I gaurantee the highs won't work with the crash module removed.
    Jul 2010
    Vallejo, CA
    '95 540iA
    Quote Originally Posted by ross1 View Post
    That makes sense since they are supposed to flash after you get into an accident.
    Quote Originally Posted by 1990525i View Post
    the bees knees
    Oct 2008
    E46 M3
    I thought only the hazards were supposed to flash after an impact?
    Avon, CT
    1990 BMW 525i 5spd 230k
    You've checked the solder joints for the relays in the LKM? I couldn't believe how obvious the cracks were in my LKM. Easy to resolder tho.
    1990 525i 5spd 260k miles (Daily Driver Winter)
    1976 Porsche 911S 122k miles (Daily Driver Summer)
    1999 C280 240k miles (DONATED to Goodwill, will never buy another MB)
    2004 Saab 9-3 Linear (serviceable)
    1985 Chevy K-10 (Project)
    Jul 2006
    Hanover MA
    '11 Golf TDI+Porsche 996
    The highs and fogs are intertwined.
    I remember on my ex's 95 525 I put Euro smiles in it with DDM HID lows and didn't hook up the highs and her fogs didn't work. But there was no error code for any of the lights being out
    I own mostly junk. Except the Porsche, that's kind of cool.
    All the motorcycles are trash which you can read about at
    http://oneguytwowheels.blogspot.com/
    I'll update it eventually
    Thansk
    Oct 2008
    E46 M3
    I have not looked inside my lkm. I'll give that a check too.
    Garret, that's why I mentioned my fogs work. I thought they were on the same circuit as the high beams. Its been awhile since I looked at the lighting schematics, I guess I'll have to open them up again if I don't see anything obvious tonight.
    Thanks for all the suggestions guys..
    Mar 2010
    Fayetteville, AR
    1990 535i manual
    I am interested to know how this turns out. I have no high beams (no power at the bulbs), but my fogs work fine.
    I have tried two different LKM's, one of which I resoldered all the connections. I also tried some spare relays I had laying around, but nothing.
    Jul 2005
    Crook County
    BMW X5, Lotus
    Highs and fogs are intertwined, when the highs are on the fogs should be off.
    Spirit
    Oct 2008
    E46 M3
    Thanks Ross!
    It was the lack of crash control module.
    Also I think I fixed the reason the hazards were randomly going off when I resoldered all my wire terminations under the RM/GM last year. I guess I never plugged in the CCR to check things after my wiring repair.
    Mar 2010
    Fayetteville, AR
    1990 535i manual
    I too replaced my CCM and now have high beams. Thanks!
    May 2019
    North Highlands
    BMW 535 I
    So i am currently having this problem with my 535i and i checked all fuses all relays and everything. however when i try turning on the high beams, i hear a clicking noise but no highbeams. i get no error lights or anything. however my car was in a recent car accident but nothing major. any ideas?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Hello and welcome!
    It's considered proper form to start a new thread when the last post was 7 years ago. But to answer your question: I'd first check wiring and loose or dirty contacts at the lights. Something might've severed or bonked loose during the accident.
    May 2019
    North Highlands
    BMW 535 I
    so i had checked the wires for the headlights and they are all good. i have 2 new headlights, and all new bulbs so i know that can’t be the problem.
    Aug 2020
    Uk
    F10,w221
    Hello, i have the exact same issue with an F10, can somebody point me to the direction where i can find the crash control module and how it looks like?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you are in the wrong forum, here we talk E34, your F10 is completely different, post questions in the F10 subforum, there the experts for F10 will try to help you.
