Originally Posted by
zero nero
I am currently running 18x8 et 10 fronts and 18x10 et 18 rears with 275 tire how difficult is to run 315 tires at the back with the existing specs? also have a pair of 305/30/19 potenza re050a thinking of going also 19" but havent bought rims yet ( ultraleggera perhaps ) what specs would i need on the 19" option also ?
You'd be squeezing a 315 onto your existing wheels, but they would probably clear (you'll be hitting the fender by about 2mm if they don't. Generally the same offset rule applies to 19" wheels as to 18", Those 305/30/19 might fit perfectly with a 20-22mm offset
smokum
Speak more on the Studs Bry who what why and were did you find them? i do like the look only concern would be locks
I think I picked the studs up from bimmerworld. Great company to deal with, friends and I always buy from them to support the business.
Eight Baller
Which turbo's are these..who makes them??
OEM turbos from the X5M actually, made by garrett. I'm working on getting some data for them from a connection 'on the inside' but I believe that I've already backed the data out that I will need by comparing compressor and turbine wheels/housings with existing designs.
sofiabghome
Bryson,
My friend how are you ?
Those Apex wheels look sick and very nice every time I see your car...
Have you scaled them ??? These are the lightest wheels from Apex line Wheels...All guys use them for the track.. I am planing to buy a set for my E24M6er track toy.
Anri
Good to hear from you man, I love the wheels, but haven't had a chance to set them on a scale with tires. Definitely post up here if you want to share them with us! I'm sure it'll be an awesome setup
2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
