Looks like I would still be able to squeeze by with 295s at ET27 on a 10.5.
Thanks for the PM!
No problem.
Thanks for your experience as well.
hey. I like what you have discovered. thats awesome. question for you... you ran 285's before for your rear tires. im expecting that you didnt rub. i running currently 275/30/19 rear by 245/35/19 front without spacers and the ride is perfect...no rubbing at all and handles well. if i wanted to fit a 285/30/19 on my rears...on a 10 width rim...will it fit ...and will i not rub without spacers? thanks
Thats amazing!!! I want this
2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
Bryson, looking at this view, With my current wheel ET20 I have 0.10 inch from being flush with the body line and 0.55 inch from the trailing arm. I'd really like to run those 315/30-18's but I fear that they'll ride hard on the inner quarter panel, What do you think? Yes my quarters have been rolled. Forgive the dirty Vette, it's my DD.
Chris
That is a PHATASS!!!! LOL! Damn Eisenman is in my way.
@Imndeep...shouldn't you have more room where the fenders and rim meet? I am always confuse with the offsets. I plan to put 5mm spacers on my rim (et 22). And the guy on ebay has 16 sets of those 315s left. Shall we do a group buy?
I need to listen to what I told vinnyricci myself, no matter how much I want those 315's they will not work with my ET with only 0.1 inch from the outer wheel lip to the outer surface of the quarter panel I don't know If I can fit 295/30-18's in there. and the 295/35-18 is a 26.1 inch tire, maybe a little too tall
Yeah, I don't think you'll fit with 315s.. You'd have to trim the fenders all the way down and roll the lips out just a little like Wolf/Wokke's car. You should be able to do 295s after trimming the fenders down though.
I think I'm happy with et24 right now after ticking the tire pressure up to 38psi, pretty much eliminated the rubbing and I didn't have to take a cutting wheel to my fenders
2/16:
It just occurred to me that my subframe bushings are totally shot and on my to do list. It's certainly plausible that this is allowing my subframe to move more than normal, allowing the tire to come closer to the inner fender well during cornering. Hopefully, I'll be doing new subframe bushings with Olin in SD next weekend on our 8's and can report back on the improvements. I'm going for CSi bushings
Still at et24 and am going to replace my subframe bushings as I found one completely torn around the circumference. 240k mile dead bushings could have easily been causing the rubbing under extreme cornering as static clearance is 5-8mm.
Anyway, it was a nice day today so on my way out with the girlfriend I dragged her along to snap a few (okay, a lot of) photos
Oh, and I bought these..
Gorgeous, His and her Turbo's too eeh?
Exciting! Please continue to update.
Those turbos look promising.
Bryson,
The car looks fantastic. The fitment and the tire to wheel side wall is just perfect. !
One of these days I will give you a rig and come up with my E24 M6 and kill some time talking for our toys.
Think twice before you to install turbo...I personally will not do a turbo..
Anri
- E24 M6 88' Schwartz/Sparco Race Track Toy
- E24 M6 88' Schwartz/Nature. daily driver
- E24 M6 88' Royal Blue/Lotus White- Restoration project.
- E24 M6 88' Zinnoberrot/Natur. daily S38 B35 special engine project...
- E30 M3 Diamand Schwartz build S14-B2X.
- E28 M5 Black/Nature M-Technic project
- E31 '97 840Ci Black/Black CSI complete futures my cruiser soon S62-B50 6spd.
https://www.youtube.com/watch?v=XTV4asC3Bp0&t=14s
https://www.youtube.com/channel/UCyh...yUW-Q/featured
https://www.instagram.com/euroclassicmotors/
Looking good Bryson. A lean mean silver bullet machine! Have bushings too, awaiting instructions, date, time... looking forward to it.
Bryson, looks like you converted to 3 inch wheel studs in the rear. Reasoning?
Of course
I'd love to chat cars.. I've driven a few turbo cars, even DDed a 450hp M3 for a couple months, and I love them. These turbos should spool extremely early, estimating before 2000rpm, but fall off up top in power. I'll make every effort to keep lag to a minimum and spool responsiveness to a maximum.
Let me just finish cranking out this degree and we can set it up for real (two weeks and I'm done with my Master's!!)
The wheel studs allow me to try out several different sized spacers without having to buy new lug bolts. Additionally, it makes mounting the wheels much easier (especially the front), as the wheel goes right where it needs to.
YOU'VE GOT TO BE KIDDING ME! Is it a lot more stable now? That is freaking nice but does the affect performance?
More stable? It's always been pretty stable at speed, but it certainly corners faster and with quite a bit more vigor
Do you mean performance as in acceleration? These 315/30/18s are actually the same weight as my 285/35/18s and are slightly smaller in diameter. In theory, the car will accelerate faster due to a slight gearing advantage as well as a lower polar moment of inertia. In reality, there's no discernable difference.
