Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 101 to 125 of 269
Thread: DIY: How To Swap a Differential (plenty of pics)
  1. #101
    Jul 2004
    Houston, TX
    36 Cylinders
    oh ok ...hmmm didn't read that, cool
  2. #102
    Sammamish, WA
    95 Hellrot M3/02 MY Z06
    Just got started on mine (been sick all week...ugh....) and so far just loosed all the Axle Torx Bolts...was quite easy. Know that mine is a CA/AZ Car (first year in GA though) so it's not that messy underneath, plus I have a AA Gen III Ex and custom springs, so my clearences may differ.
    First, trip to Autozone. Picked up there:
    1- 24" 3/8" Extension $9.99
    1- Female Torx Socket E12 $3.99 Pt# 085903 2027 26830
    I added my own 4" extension, and a large Torque Wrench for power. The night before I hit each one with some "PB Blaster". (smelly, but way better the Liquid Wrench IMO)
    I moved the axle so I saw bolts at 11 & 2, placed the extended (28" total) socket on it (through one of my Red Vogtland spring coils) and used a Rubber Mallet to make sure it had solid contact, then pushed on the Torque wrench, pushed hard and "SNAP"...each one gave a crisp sound when breaking loose. Gave a few hand turns to make sure they were loose, then on to the next one. I was able to do two at a time this way no problem. Piece of cake! Thanks for the ideas! Next up the sway bar supports.....
    John
    '95 Hellrot M3 w/Dove
    AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
    ***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
  3. #103
    Sammamish, WA
    Quote Originally Posted by hellrot325
    Look at post 69, you'll see that I did not remove the sway bar. I simply removed the two sway bar support and pulled it doen out of the way. I would recommend this only if someone is helping you remove the diff, and I would recommend that you get help. Wether you do what I did or remove the SB like Tommy R...its heavy and ackward taking it out.
    Are these the two SB attachpoints that secure the middle of the Bar? If so, how did you do it, by removing the large bolts that go up into the chassis, or some how seperate the bar from the tabs? (I have TMS bars in place, they came with the car. Have only adjusted them, never removed/installed)
    Thanks!
    John
  4. #104
    Jul 2005
    Calgary
    325i
    Newbie!
    Hi Tommy,
    Read your write up and with the pix the job was a breeze! Thank you, I had never worked on a Bimmer diff before I looked at your article!!
    I pulled it out in 3 hours myself but now I have to redo the seals any helpwith that?
    You Rock!
    Brent
  5. #105
    Jun 2005
    Winston Salem
    '01 325i / 330ZHP clone
    This is a great writeup. It helped a lot when I pulled my LSD from my parts car. Thanks again!
    B
  6. #106
    Jun 2003
    Austin, TX, USA
    '01 Jeep ;)
    No sweat, guys. Happy to help. No idea on the seals as mine have been fine. If you're talking about the output seals to the axles, I wonder if you even have to drop the diff to do that?
    Tommy
  7. #107
    Jul 2005
    Calgary
    325i
    Hehehe wouldn't that be a laugh on me heheheh
    Thanks again Tommy,
    But actually I need to do the driveshaft one... it is the worst, but while I have it out I could probably do the axles as well.
    Any one know of link to do the seals?
    Thank you
    Brent
  8. #108
    Jul 2005
    Calgary
    325i
    Alllllllllllllll Donnnnnnnnnnnnnnnne!!!!!!!!
    Hi All,
    I finished my FIRST Bimmer rear diff including the seals (two sides and the main pinion seal!!!!)
    If it wasn't for this forum it would have taken me 10 Hours but it took 3hrs (to remove the diff with lots of help from TommyR's write up) + 2Hrs to rebuild and clean and replace all seals 2 hours to reinstall and torque everything down!!! I am still greasey from the undercarriage but You can't wipe the smile off of my face . Time for a test drive
    THANK YOU ALL!!!!!!!!
    Brent
  9. #109
    Tampa, FL
    97 E36M3 S54
    How long do you guys reckon it would take to switch the diffs of 2 cars at the same time? 5 hours with a helper?
  10. #110
    Jun 2002
    Chicago
    1997 M3
    This should be stickied.
  11. #111
    Tampa, FL
    97 E36M3 S54
    Also does the car HAVE to be on jack stands at front and back? Or can I just have the rear jacked up? I ask because I only have 4 jackstands and have to swap the diffs of 2 cars, so they both have to be up in teh air at the same time. Can't put 1 down with parts all apart.
  12. #112
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    Quote Originally Posted by M52 POWER!
    Just buy 4 more jackstands. They're like $10/pair at Kragen.
    2005 Audi (Purchased 07/09) - 2005 Yamaha R6 (Raven) (Purchased 5/06)
    07/97 BMW (Sold 08/09) - 03/01 Audi A4 1.8TMCX (Sold 06/03)
    Please do NOT PM me! Email me: clumpymold@sbcglobal.net
  13. #113
    Tampa, FL
    97 E36M3 S54
    If anybody knows what size socket is needed to remove the input flange please let me know!
    The one shown here:
  14. #114
    Jun 2003
    Austin, TX, USA
    '01 Jeep ;)
    30mm.
    Just make sure you get a thin wall socket or "turn" it like I did to the one in the picture. Otherwise it won't fit in there.
    Good luck!
    Tommy
  15. #115
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    Quote Originally Posted by 328 Power 04
    i did it in 3 hours including jacking car up and setting it right... you don't need to take off sway bar .. just loosen 2 rear-most bolts and lower it down and let output shafts hang on it ... no zip ties needed.... its simple
    i did 2.93 to 3.15 LSD on a E36 328is
    Sweet. I'm about to attempt this tonight (and tomorrow).
    What size "reverse torx" sockets do I need to remove those axle bolts?
  16. #116
    Ottawa, Canada
    10/96 318IS
    Two Jack stands is all you need leave the front on the ground.
    And yes if you like you can put one car down in peices, just block the wheels so it doesn't roll away on you or use the hand break.
    I also didn't have to remove the sway bar just loosen it were the tabs are and got my helper to push it towards the floor out of the way while I loosing the rear bolts.
    Took me 1 hour and 45 min to drop my old diff out and install my new one for the first time (with a good helper).
    Current Mods....X-Brace, Stromung Cat Back Exhaust, 17/225/45 M3 Replicas, HotBits Adjustable Coil Overs, 40% LSD 3:91 Diff, E30 Gearbox, Boosted.
  17. #117
    Moscow on the Mendota, WI
    1995 Hellrot 325is
    Quote Originally Posted by Jeffrie
    Took me 1 hour and 45 min to drop my old diff out and install my new one.
    Handbrake works on rear wheels...
    Turner Perf Chip/Fan Delete/Sparco Strut Tower Brace/X-Brace/JTD Underpanel
    Zimmerman X-D Rotors/Axxis Ultimate Pads/Solid Caliper Guide Bolt Bushings
    UUC EVO3/DSSR SSK/3.15 LSD/Cosmos Racing CAI V2/ASC Delete
    96+ M3 LCA/LCAB M3 RTAB and GC Shims
    BMW OEM Alarm/Woodgrain Delete/Blizzaks baby!/16x7 BMW Style 30 Sport wheels
  18. #118
    Ottawa, Canada
    10/96 318IS
    Mentioned while the car was down, you do not need to remove the rear wheels to swap a diff.
  19. #119
    1995 Hellrot 325is
    Misunderstood your post....my bad. Just didn'tr want someomne thinking that the e-brake would help w/ the back up on jacks
  20. #120
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    Okay, I just did this tonight (removed it, anyway). Not hard AT ALL. The hardest bolts for me, however, weren't the 6 E12 bolts on each axle flange. It was the four bolts connecting the differential to the driveshaft. 16mm.
    I couldn't get a socket to fit so I had to use a 16mm wrench. I had to loosen two of them with my FOOT! Tough suckers. And I weighed the differential with my old bathroom scale. ~80lbs. FYI: I weighed myself right after. ~100lbs!
    So yeah, if I can do this MYSELF, anyone can do it.
    Now to get that bolt drilled/lasered out and the differential put back.
  21. #121
    Atlanta, GA
    1999 m3 and 740iL
    Great thread!!! Im about to attempt to do this swap in the next week or two with a 3.23LSD that I just purchased, but first I have a few questions. I bought the differential without the output flanges becuase the seller informed me that the 99 M3 output flanges that came on the diff would not fit with my 325 axles. I know swapping hte output flanges is relatively simple, but I want to make sure Im not missing a gasket or anything that would come with the diff if the output flanges were still on the diff. Here are some pics of my differential, I would really appreciate if someone could identify anything thats missing from these pictures as it would help me tremendously.
    Sorry for the pic size...
    sorry for the blurryness...
    So if you see any snap ring or gasket or anything I need before I stick my 325 output flanges in there I would really appreciate a heads up!! Thanks alot everyone!
  22. #122
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    Not sure if this has been answered but I didn't use four jack stands. Jacked only the rear up.
    Did this all by myself too. The hardest part, BY FAR, was getting the differential back in. I used my 3.5 ton jack and managed to position the diff vertical on the edge of the jack. Then slowly jacked it up while tilting the front of the diff down as it went up. Slid it in that way.
    I removed the sway bar and found it VERY helpful. In fact, I don't think I would have been able to do this if it was still there. I have aftermarket sways (UUC) so they're pretty stiff/thick.
    Anyway, good luck! Great thread.
    Might I add some suggestions though?
    It would have been nice to have a list of ALL the tools used for this DIY, as well as the torque specs for each bolt.
    Oh, and it took me about 5-6 hours total for this job (over two days). I am a VERY slow worker (clean stuff, paint stuff, etc. ). I also took pictures and stuff. Sure was a major PITA and I really don't want to do it again.
    The worst part of it is that I wasn't even swapping my diff. Only removed it to get my broken bolt out.
  23. #123
    Jun 2003
    Austin, TX, USA
    '01 Jeep ;)
    Quote Originally Posted by clumpymold
    Did it alone the first time I did it, too. Much easier and faster with a second person. If for no other reason to hand you tools and, of course, to put the diff back in.
    Go for it!
    Tommy
  24. #124
    Apr 2003
    Los Angeles, CA
    B7 Audi & Yamaha R6
    Quote Originally Posted by Tommy R
    How did you manage to put the differential back in yourself? This is what I did (post #112 & on):
    http://forums.bimmerforums.com/forum...=414611&page=2
  25. #125
    Jun 2003
    Austin, TX, USA
    '01 Jeep ;)
    I just lifted it and put it in the carrier.
    Tommy
