Not to revive the dead/old, but how hard is it (and can someone post clear instructions) on how to change the driveshaft flanges? My 328is has a 4 bolt 2.93 Open diff, and the one i was is from a 95 M3, and is a 6 bolt 3.15 LSD. how hard will this be?
Reviving an existing thread should be ENcouraged, not DIScouraged. People create too many new threads as it is....but I digress.
I've swapped an input flange. It's a matter of removing the nut, using a puller to remove the flange, inserting the new flange, and torqueing the nut down to the proper specs and with the proper thread locker. It may require a new nut to be safe. I would measure the preload on the pinion flange before removing it. When you install the new one, torque the nut until the same preload is reached.
I would verify this with the Bentley.....or a good manual if you have one.
Good luck,
Tommy
It isn't terribly hard. you need to take your 328 output shafts out of your 328 diff. Pretty straight forward.
Then you need to inspect the seals and bearings in the output shafts of the M3 diff. The best bet is to replace these. Then just press the 328 shafts in.
When it is on the car I would drain and refill the fluid as well.
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
You should also inspect the innards of that 3.15 diff--check the link in tommy's sig. The factory omitted threadlocker on a few of the bolts and they have a tendency to back out, bounce around and get stuck in the gears. You should verify that everything is as it should be.
thanks! Im needing this right now.
94 318is
95 M3
93 325is Euro
95 318ti clubsport
97 M3
88 535is
98 328i vert
99 M3
Off the bmw crack at the moment
Great great writeup. If I get my 3:15 replacement this weekend, I'm ready to do this thanks to the quality of the pics and narrative. Thansk! *Crosses fingers*
Speaking of, can anyone confirm that the E12 TORX is available for $3.99 from Autozone, and if so, perhaps show a link? I'd rather not waste the money on the extra Sears set if I don't have to. Thanks!
I can confirm it was 4 or 5 bucks. Just call whichever store you're planning on going to.
Not sure whether this has been mentioned already in this thread or not, but the exhaust and sway bar do not have to be removed from the car inorder to swap the diff.
I just swapped mine this past weekend, and I left the exhaust completely bolted in place (a few extensions are required to get at the drivers side halfshaft to diff bolts). I also only unbolted the swaybar from the frame, not the suspension. This allows you to push the swaybar up enough the get at the rear diff mount bolts, and lower the diff out of place.
'94 325i (manual swapped): Sold
'01 540i M-Sport
'92 735i
I was told that there was quite a bit of "timing" when it came to installing the new diff as far as spinning it a few times until input and output shafts were synchronized. This isn't the case?
Great write up by the way
There are several ways. You could get a torque wrench that measures in in-lbs. and simply use a socket that fits the input flange nut. Increase the torque setting on the wrench until the flange rotates. That's youre preload.
Or you could use a fish scale in a hole on the input flange. Measure the amount of "weight" required to get the flange to turn. Then use some math to determine how that force (applied "x" distance from the centerline of the flange) correlates to the amount of torque in in-lbs.
Tommy
This is a GREAT write up, thank you! It is a job I look forward to doing sometime this year!!
My pleasure....
Thanks for the write-up and pictures. As mentioned, pics do a world of justice when us DIY'ers want the challenge/satisfaction of doing something ourselves....now if I can only find an LSD that'll balance my auto trans(ugh) with better low-end take-off power....anyway, the search continues. Peace. PG
H&R springs/GR2 shocks/Custom TMS JC chip/S50 cams/21.5lb injectors/Shorty headers/Stromung cat-back/5 speed swap/Dr Vanos Stg II/Sachs clutch kit/3.15 LSD/KN af/BW silicone t-body boot/TMS sways/TMS UDP/TMS drilled rotors/SS lines/PBR pads/Depo Gen-IV 55w 6k dde hid h/l's/Apexcone Crystal 35w 6k hid fogs/hi-beam with fogs mod/FDM/LBF delete/UUC goodies.
great job, i'm considering swapping but it looks like a lot of work
If you have doubts about the DIY nature of this for a relatively new DIY mechanic - let me say from experience - DO IT!!! It took my dad and I approximately 2.5 hours with air tools and no prior experience with BMWs. There were a couple of times when we got stumped, and of course the natural profanity when one of the half-shafts smacked him in the face (I always manage to escape injury), but other than that it's well worth it and fairly straightforward.
'95 ///M3 - Alpineweiss on Black Vaders
w/Bilstein Sports/Umnitza TSE/UUC Black Trans Mounts/Rogue RSMs/228,xxx miles and counting!
is it normal to go 65 mph at 3500rpm I did a manual swap on my 93 325is dont know if I also had to swap the differencial
Nope. If you had an automatic, you had a 3.91 gearset so you would likely be better off with a 3.15 from a 5 speed car.....or a diff from an M3, but those carry a premium for only a marginal improvement in gearing. At least all M3 diffs have a limited slip whereas not all 5 speed diffs do.
Tommy
thanx did I have to change my wiring to get my check engine light of and the ecu or is there a way to get around that
also do i have to change my wiring and my ecu to get my check engine light off and my back up lights to work because I don't have anything plugs connected to the trans
What the heck, bring back a really old thread . . .
I'm about to go through this and I am concerned about how much torque to put on the input flange nut. I found this info, see post #32:
http://forum.e46fanatics.com/showthr...6&pp=20&page=2
According to this post, the necessary torque is all about "spinning torque". Interesting.
Tom stated that the nut on his diff was not torqued . . . I suspect it was originally. Once the "crush sleeve" has done its job, the nut will likely back off very easily.
hi people!!!
did anyone put m3 dif on 320i cabrio 1998?
datails,pics,info plz
