So why did you buy two Silver M3's? Lol, i sold you my 1998 M3 with 242k.. i could've sworn that was the car you were using... im confused.
Would be nice if you had it done for when I bring ny car in to dyno on the 22nd (Love Field).
It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
Turning Benjamins into noise since 1997
I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
We've seen big improvements in S54's just by improving our tunes. Running closed-loop knock control has been a benefit. These motors can be a bit det sensitive on individual cylinders, but as we tune them more and more, we have found power in interesting places. They seem to respond well to injector timing too, we've gone to bigger injectors and higher fuel pressures just to run shorter injection times so we can position the pulses better. Tuned in conjunction with VANOS we're very happy with continued improvements.I remember seeing s54s only making 330whp with cams like only ~3yrs ago.
We've seen improvements in S54's as the tunes become more sophisticated. Running closed-loop knock control has been a benefit. These motors can be a bit det sensitive on individual cylinders, but as we tune them more and more, we have found power in interesting places. They seem to respond well to injector timing too, we've gone to bigger injectors and higher fuel pressures just to run shorter injection times so we can position the pulses better. Tuned in conjunction with VANOS we're very happy with continued improvements.I remember seeing s54s only making 330whp with cams like only ~3yrs ago.
Last edited by neelvasavada; 03-09-2012 at 12:38 AM. Reason: Automerged Doublepost
Great post!
That's the simple stuff. I'm still unclear as to the required "elctronic peripherals" to make this swap work in an OBD2 E36 M3.
For instance, the e-throttle assembly is required (or you get Evosport's cable conv.) but what modifications, exactly, are required (other than special tune) to stuff the S54's DME/harness into the 36 and have 100% transparency for street use?
Is the E36 DME/harness still utilized after the swap? Or is it completely replaced?
Who sells these "harness conversions" and what do they cost and what are the options? Does anyone actually have a 100% complete, stock DME (tuned), modified harness conversion "kit" ready to go?
Sorry guys decided to go full race car. I am turning this into a bmw cca cmod car. probably going to move the thread not sure.
x2
nuuu..dayum. just as I found it and thought I found treaure!... sub'n anyways incase you revive as I'm debating s54 conversion vs an euro m3 evo
Any updates?
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
it is probably one of those projects where the guy spends all this money on a swap, then is almost finished, then needs money, then tries to sell it, and can't get half of the money he put into it, ends up selling it cheap, just because he tore the interior and wanted to make it into race car...
Sorry guys project just slowed i will post some new pics had to do lots of research for the cage, buying tools and refreshing high school geometry.
Car is still in progress. Hopefully I can hook you guys up with a tuner that can do what everyone is wanting i should know this week.
cmod will be fun with that car. keep us update don the progress.
Also, I'm local to you. Would you mind if I came by sometime to see the project and talk to you about it?
Pm me if you dont mind. Thanks!
coming soon, S54's for everything....
Wanganstyle Powertrain
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
Has anyone ever heard of simply replace the top end of the M52/S52 with an M54 top end? Just wondering if it would work much the same as an LS Special VTEC Upgrade.
Thanks, Cris
Yes.
I put s52 cams/trays/single vanos and sensors on a m50 non vanos head and s52 bottom end
M54 head does not bolt to m50/s52 block but the cams and trays and double vanos will move over
So one can take a complete iron block longmotor and update it to doubke vanos for a super turbo friendly setup:
S52b32 (usa spec 3200cc) longmotor
M54b30 (usa or euro spec) cams and cam trays and double vanos+all sensors
+intake manifold of your choice
A: (ideally m54b30 with disa and electronic throttle to run original m54 ecu)
B: m50b25 intake manifold +cable throttle if you desire to run obd1 m50 bosch motronic ecu+seattle circuit dual vanos add on controller
Double vanos iron block with full mapping via can bus m54 dme for turbo will be the most potent turbo engine choice avail. Build it with TRM turbo internals for proven daily driver 500-600rwhp
Sent from my GT-N7100 using Tapatalk 2
an actual s54 is 11.5:1 compression and 6 throttles of joy to turbocharge; I love s54 myself but have seen many more high power 500/600-1, 000rwhp single throttle turbocharged built units from pedestrian m50/s52 engines.
Cheaper - yes. Better? Im not sure; theoretically the s54 with crazy everything should produce the most power.
S52and m52/m54 is a good turbo motor for many other reasons- the mild cams and lower compression and smaller bores allows for turbocharging happily- same reasons m52 is so happily boosted in stock original form.
m52 with 84mm bores are theoretically more stable with equal fasteners and sealing under high boost than 87.0mm s54 or even 86.4mm s52 bores.
s50 family engine+ Studs and o ring head+ oem head gasket has been proven locally in the bay area to 1000rwhp and low 9's in 1/4 mile use
