A while ago the back portion of my power seat stopped moving, so I removed the seat from the car and opened the seat gear box up to discover that one of the plastic gears had been chewed up. I removed all the remaining pieces of the chewed gear and manual put the seat into a comfortable position, then closed the gear box back up.
I now miss being able to adjust the back portion of my seat so I want to buy a new gear, but I don't remember which gear was the one that failed. I believe there were two gears in the gear box (one white and one green), which color gear is the gear that controls the back port of the seat? I believe one gear controls the portion of the seat that you sit on and the other gear controls the back portion, but I don't remember which is which.
http://www.odometergears.com/product...s+E36+90-00/26
The company makes odometer gears first, but they also make the reclining seat gear.
You're welcome. They post on eBay -- BMW E36 SEAT GEAR -- but they just bring you to this page and price. You may find one that somebody bought and never used, and perhaps save some money.
FCP Groton also sells the ones from Odometer gears
http://www.fcpeuro.com/1997-bmw-328i...79&m=20&page=2
yes, more expensive, just another source.
Maybe checking on Ebay might be even cheaper.
Are you serious? $45 for a plastic gear? Holy crap!!!!! I have two power seat frames. i can actually sell these for $20 each and not feel guilty?
not the motor assy, ist is just the plastic gear part for $45:
BMW E36 Reclining Seat Gear (Pink)
Forward and Back Adjusting Seat Gear
Includes:
E36 Reclining Seat Gear (1 Qty.)
well, almost no option, 45 for the plastic gear or a cpl. motor for... surprise, surprise
http://bmwfans.info/parts/catalog/E3..._single_parts/
this comes when I check with my VIN
the gear units and the motor are not that expensive from BMW compared to a simple plastic gear
I was serious. What parts do you want? Motors? gears? switches? Ive got it all except cushions and covers. I'll let it all go cheap.
I'll check it out as soon as the Pats are done playing. Super close game right now.
I just bought the white gear. I need to install it. Was 35 off eBay including shipping, Damn thing is the size of your fingertip.
I do things the right way... IF I can't afford the right way, I don't need it.
Is this where that gear is?
Yeah that looks like the gearbox, I guess you already removed the 2 motors.
Well anyway just remove the the torx bolts that are holding the gearbox together and remove the 2 gears. The 2 plastic gears will be pressed onto threaded looking rods and if you try to pull them off the rods you will more then likely break the gears. Be careful or just sell it with the rod attached.
Ok I wont take off the gears. I'll try to get the whole box off the seat tomorrow. no one wants seat parts so let me know if you need anything. I have both seatbelt latches and all the motors. If you want anything let me know. I'll put together a package deal.
Whole gearbox $25 shipped? I just want to see this stuff get used instead of thrown out.
