Doru
thank for the link , first time I hear that mechanical tensioners can crack OFH on M54 engine
From now on i will watch my second 530 where i recently installed all new mechanical tensioners
with you permission i will post this BMW TSB:
got last parts for engine
06 ADJUSTING PULLEY 1 11281748131
05 Deflection pulley 1 11287841228
having a hard time to find a proper torque ...
Last edited by champaign777; 02-07-2012 at 04:01 PM. Reason: Automerged Doublepost
printed for future reference
http://www.bimmerfest.com/forums/sho...d.php?t=599240
ALT PULLEY :
Hydraulic Deflection pulley 1 11287841228 -->> 47 Nm ( 35 ft.lb )
W-P PULLEY
Hydraulic ADJUSTING PULLEY 1 11281748131 -->> 45 Nm ( 33 ft.lb )
AC PULLEY
ADJUSTING PULLEY 1 11287512758 ( in case you can find only pulley -->> 45 Nm ( 33 ft.lb )
Igor, there are some good quality aluminium WP pulleys. I think Autohaus have them for cheap. I have the UD pulleys from TM. Happy. Better than the composite (read plastic) pieces of OEM cr*p.
Looking for a DIY? Parts? Check this out, it might be your ticket
Stable: e92is, e53 N62, e46M54B25, Tribby & e39 M54B30 R.I.P.
Doru
I have the same pulleys on another car ( 20k miles counted )
They are OEM INA pulleys made in Slovenia, my dealer sales the same staff
You right about Autohaus , it sales a lot of crap as well as OEM staff , this one is OEM and i hope will last another 50k
Post a link where you got your's
I have these - a tad on the $$$ side.
dont kill me with these prices haha
I got them on sale. They were still expensive. ECS have some nice one, but not sure how good (quality) they are.
Doru
ECS has the best staff , i bought a lot of parts from them , NEVER single issue
Installed Schumacher Fully Automatic Onboard Battery Charger to keep my battery alive
Educate me: what does the Schumacher gizmo do? How does it work? Do you plug it in when you garage the car overnight?
OK, went on line and checked it. Same as a trickle charger.
So you don't drive the car every day (like me)?
Doru
i plug it in only overnight once in a week in winter time or when i have a long trips ( 2-3 weeks or more )
And i do drive my cars daily and have same charger on both cars
The good think about it , - it is Automatic , connect and forget
When battery is fully charged it works in sleep mode , when voltage drop in charge mode and so on ( trickle charger )
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
worth it just for the front cupholders
KEVIN
BMW CCA # 416146
Current 2001 525i-5 / 225,000 Miles
///M Weighted Shift knob.
CD43 with AUX retrofit + Bluebus
Auto Dimming Mirror upgrade
H&R Sport / Koni STR.T
OEM Xenon HID Retrofit
The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
CDV Free, 545i Shifter and ///M Weighted Shift knob.
Member of DSC Module Failure Club $$
what is your concern bro ?
i am using it already second winter , no issue so far
this is not a charger to charge/start a dead battery but to keep a weak battery fully charged
When i need to charge battery fast or to code my car I use THIS charger
Schumacher SC-8000A Speedcharge Charger/Maintainer
http://www.amazon.com/Schumacher-SC-...726915&sr=1-45
champaign can I code my car with the Schumacher SE-1-12S Fully Automatic Onboard Battery Charger - 1.5 Amps? aka (http://www.amazon.com/Schumacher-SE-...=5336432695-20)
Russian Comrade,
Thank you. I just installed new mechanical tensioner, deflector and belt because I had the famous chirp-chip noise. Guess what, I still have chirp-chirp. It goes away sometimes, after engine warms up. It IS the mechanical tensioner. Now I know my suspicion is correct, that it's metal base is resonating. I will remove the mechanical tensioner and apply some high-temp brake caliper grease to the back of it. I am not installing the hydraulic tensioner...I think $0.01 of special grease will inhibit the birdy chirp-chirp.
Best regards,
Lord Fiver
Lord Fiver
You are the E39 flagman hehe
I wanted to replace just couple of suspensions parts but ended up with THIS
Koni Yellows are going in with Sport springs + all front / rear suspension + all bushings + all bearings and much more
Winter project ...
nice bro!!! nice nice
Jesus...champaign777 has come from nowhere, and just crushed this entire DIY forum.
Seems like he's taken the whole damn car apart inside of 1 month.
Who is this guy !?! He's done more DIY in 1 month than most so in a lifetime.
E39 DIYs done: Wipers, O2 sensors , MAF , Upper/Lower Intake Boots , FSU , ABS module fix , Power Steering Reservoir , Changed Rear Differential Oil , DISA , SAP, Vacuum lines , Radar Detector Hardwire , Fuel Filter , LED Angel Eyes , Headlight Adjusters--> [1],[2], [3] , Headlight Polishing, Punted: Fan Clutch/Tensioner/Pulleys , Oil cap O-rings , Window regulator ,Crumbling Cowl
I was thinking the same thing.
Igor you make me feel like I have completely neglected my 530. You have done more in the last few weeks than I have in the last year.
It's all worth it though. Keep it up.
2003 M5 LSx l 6 Spd Manual l 4.10 LSD
Build Thread
The chassis must always be regarded as a means to an end and never as an end itself
hehe
I really didn't want to do all this suspension mess on 75k miles but i found out that 2-3 front suspension parts already weak so i need to replace them anyhow
Now you only need to start and then you think ,- what the hell , my struts are weak as well , so lets do it ALL and NOW ( winter time right ?? )
In reality it doesn't take more than 8-10h in a week if you know how to do it
This guy is really TOUGH to get open , you need a long Breaker Bar from Harbor Freight
I am sure bearings are excellent and they can last another 30-50k miles but i hate to open it all again and don't want to touch
any suspension parts at all in near future
I wonder that i have an old style bearings with nut on the top for 2003 car
Here is my FIRST observation about Koni Yellow vs OEM Sachs Sport ( not installed yet )
Koni Yellow looks like a cheap toy from Toysrus
Sachs Sport is all unfinished aluminum even plate where Koni is painted steel ( ? ) with some cheap chrome plate
Sachs Sport has very clear R - L marks on the top where Koni Yellow has some arrow R - L marks
on the bottom ( what the hell ? )
And the last - Sachs Sport chrome shaft is more solid 25MM where Koni Yellow chrome shaft is only 22MM
Now I really want to believe that these aftermarket Koni Yellow struts ride better than OEM Sachs Sport
( well , this is what many folks say )
what about the weight of the Sachs sports vs Koni.....
I help a friend here in Panama to replace his current Sachs OEM Sports for a new ones (again, Sachs OEM Sports), and they are very light!!!!
but I don't understand your question about quality between Koni and Sachs, you don't have already the Koni in your other e39?
