What do 850i have for coilovers? Friend needs a set asap
make sum
*~*Yamaguchi-gumi Syndicate Member #59,005 *~*
[ Bippu Couture ] ( D_G ) [ FALKEN Tires]
Like DG says, if you/he want coilovers, they will need to be custom made. There is nothing available aftermarket for the E31.
91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
I believe Bryson has a "coilover" set-up on his beautifully set up car...(custom ALL the way)
I am desperatly trying to achieve the "stance" that his car has.. (without coilover)
Bryson's car looks sweeet !!!
DMP
Yep, it's custom all the way. There are a few 8's that are running setups similar to what I've got, with varying degrees of tweaking depending on the intended use. Is this a street car, weekend/track car.. what is the desired use?
Here's a quick guideline if you're interested in DIYing: http://forums.bimmerforums.com/forum....php?t=1439087
Thanks for the compliments! I'm glad all the work paid off too
2.8 Z3 coupe + 6 speed || 200kW electric 1970 Jaguar XJ6
True.... there is nothing out there.
Though a user here might be able to have some made in the UK I believe.
Sadly for many, including myself, this is not an option as it does not come with a certificate from TüV, DOT or similar.
There are not many options for the E31 out there.
Most use Bilstein shocks, they work ok, but there is not really any better alternative out there.
Springs can be had with various drop from i.e Eibach, H&R, and KAW.
-Egil (my name)
2012 ///M550xd touring
1990 850Ia Hartge Supercharged.
2004 M3 (sold)
Ouch... So I assume the best way to go might be struts and springs?
