I have a '99 528i with xenon that I upgraded to '01-'03 Hella Angel eye xenon lights. My question is am I able to just have the AE's on and daytime running lights off when I have my switch in the parking light position? Currently, both are on, AE's and DRL, when the switch is in the parking light position.
Posted this in the Lighting forum, but no responses.
Can't seem to find the exact info. Any help?
Thx.
You need to turn off your DRL with a scan tool that can do this. Be aware that once the DRL are off, they will not be on when your parking lights are turned off.
Much modified VF Supercharger Kit tuned by Tuning Tech FS, M5 front sports seats, CVV to catch can conversion, Boost Gauge, Schmiedmann header to rear muffler high flow exhaust, Header Ceramic coated inside & out, Exhaust heat wrapped from flanges after header to before CATs, Kicker sub with dedicated 200 watt amp, CCFL angel eyes, CF facelift kidney grills, Quaife LS diff ,Super duty cooling kit, Electric fan controlled by temperature adjustable 2 speed controller (JimLev design)
John
I'm pretty sure your DRL's are just your high beam bulbs on low brightness... thats what mine are! So no, you can't leave those unplugged or they'll throw a code, especially if your LCM is coded to run DRL's.
^This is an e39 99' doesn't come with DRLs!
Do what I did which requires custom wiring. Locate ur fuse box under your hood passanger side. (It is under your air filter box and u have to remove the air filter box to open it with hex wrench) Then locate a large red wire and tap into that. Use that wire to power you angels. This supply comes on when the car key is in the on position automatically and turns off when your car does. U can then have the parking light on when the car is off and they will not come on.
Current: 1991 325ix Coupe Turbo/ 981 Boxster Base
Past: 2007 Z4MC/ S13 240SX/ 2002 S2000/ 2004 350Z/ E39 1999 528i/ E46 2004 SC 325CI/ E30 1989 325i Vert/ 1987 E24 635CSI/ E82 135I
I make signatures, just ask
Yes e39 99+ do have DRL you must have them programmed off to take them off or just unplug your highbeam bulb
ha my cousins 99 528i had DRL. It ruins the look of the AE's.
he ended up just disconnecting the bulbs.
if you have the low instrument cluster is not as anoying to see bulb error like the high cluster.
I explained it further here:
http://forums.bimmerforums.com/forum....php?t=1793116
sorry old thread revival -
I know djkapeesh did a great job showing how to wire angel eyes to come on independent of the headlights, but (and maybe I'm not seeing this) my DRL's come on when I turn on my car. They'll only turn off if I turn on my headlights, but I really only want to use my angel eyes as DRL's.
For now, I've just disconnected my high beam/drl bulbs, but the error message on the display is getting old. Other than going with Carsoft or GT1 is there really no other way to disable DRL's altogether?
2003 BMW M3 - Alpine White - 6 speed
2002 BMW 330i - Gray - 5 speed
just reprogram the DRL's off. i am sure you can find somebody in your area that has the software and hardware to do the reprogramming. or you could do it yourself for little money, and have the ability to do other coding if you like. changing the door lock sequence, changing the oil change interval. lots of stuff.
G~
Search and buy: bmw scanner 1.4
cost about 20 bucks can do everything for the E46 really simple
