Page 17 of 17 FirstFirst ... 7891011121314151617
Results 401 to 415 of 415
Thread: E39 I6 LS Swap kit
  1. #401
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by 2000 548 View Post
    Hi, please send me a quote for a kit. I have a t6060 trans. from a 2012 camaro, the only thread I found on using this trans. showed a need to cut the floor for the shifter. If this is necessary I may use a T56. Are there any aftermarket shifters that would work, or is it that the trans. is too tall? What exhaust manifolds are you recommending now that you aren't making headers? Let me know, thanks. paulmcurran@gmail.com I can wait for a group buy if that helps you.
    I'm not sure about the tr6060. I know my transmission mount won't work with the 6060.
    If you decide to go t56 get ahold of Lantz. I don't have any t56 sets in stock.
    As far as headers/manifolds, I have no leads. I've heard there are options but never got part numbers.
    Let me know if you have any questions
  2. #402
    Washington
    BMW 525i
    I still have one set left. I went the T56 magnum route. The T56 magnum is the new aftermarket version of the tr6060 that can handle up to 700 hp stock and has the benefits of the newer tr6060 design.
    That with the gto 04-06 shifter lines right up.
    You should be able to run stock truck manifolds I believe. I donít think there are options for long tubes.
  3. #403
    Oct 2014
    sunderland ma
    2000 bmw 540 sport wagon
    Hi, what is it that you have 1 left? Transmission or mount kit? Let me know here or send me an email. Thanks, Paul paulmcurran@gmail.com
  4. #404
    Oct 2014
    sunderland ma
    Thanks JF, I have a kit coming from lantz. Questions on proceeding: I need a 6 cyl. front crossmember to put in my E39 540i V8. Looks like all of these 6 cyl. ones are the same? Not clear how many parts I need, crossmember, steering rack with tie rods, control arms (upper & lower)? Shocks, What else? Should be able to find off 1 car, where to look, what should I have to pay? You mentioned someone found headers from Summit that fit, anyone have info on those?? I'm sure there will be more questions, thanks for the help, Paul
  5. #405
    May 2010
    Salem, OR
    2000 BMW 528
    Any subframe will fit, any year range. You'll need the whole assembly though, subframe, control arms and shocks.
    I paid $200 for a subframe with a rack, lower control arms and tie rods.
    I don't have any information on the headers, never got part numbers.
  6. #406
    Oct 2014
    sunderland ma
    Hi Josh, I received one of your motor mount kits though lanz today, great looking pieces, nice work. They look beefy enough o hold up a building! Thanks. What rubber motor mounts do you recommend?
  7. #407
    May 2010
    Salem, OR
    2000 BMW 528
    I run Z8 mounts. They fit in stock locations but seem to be a little more rigid rubber. You can use stock E39 ones as well.
  8. #408
    Apr 2019
    PALMER,MA
    2009 BMW 335 XDRIVE Seda
    Hello, new to the forum. I have a 2000 540 6-speed that im planning on doing an LS1 swap in. I will be putting in the front suspension/crossmember and steering rack from a 530 in it. Will these mount work since i will be using my 6-speed tranny, not a t56?
  9. #409
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by ONLYBIMMERS View Post
    The engine mounts should work, you'd probably have to make a transmission mount though.
  10. #410
    Apr 2019
    PALMER,MA
    Ok, it will be a while till I do the swap, I'm just doing all my research now. I plan on doing a TT setup so it should be a fun project. Do you know if anyone makes a harness kit for e39 anymore or do I have to custom wire it?
  11. #411
    Jul 2018
    Louisiana
    Bmw E39 528i
    if we got enough ppl to do a batch of headers would u be down. ik they take alot of work but the price is urs to set. or atleast the bends and cuts of the piping.
  12. #412
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by mrallande5020 View Post
    Unfortunately with my current work schedule I just won't be able to make this work.
    I'd much rather build headers and swap parts day in/day out. Haha
  13. #413
    May 2019
    Everywhere
    E39 530i
    E39 ls swap
    Greetings . I'm new to the threads and I don't know how to PM you JF . May I ask you to contact me at my Email . its : hamoud.mn@hotmail.com
    Thank you for your time .
  14. #414
    Oct 2014
    sunderland ma
    What style accessories (p/s, a/c, alt., etc.) fit best with JF mounts. I know there are several options. Thanks.
  15. #415
    Washington
    BMW 525i
    Depends on what your doing. If you are going turbo I would do corvette style. In my opinion it gives you the most options. Check out my build thread if doing turbo. I tried to document spacing for others and what I ran into.
    Non turbo I think anything fits besides truck.
