Subscribed...
I've worked with a Motorsport system sourced from Curt Jung, but would like to upgrade the ASC system in the E46 that I autocross.
Peter Florance
PFTuning.com
I've confirmed that they are M12 x 1. I copied Simon P's use of the CNC brake light junction block with M10 x 1 to M12 x 1 adapters for the pressure sensors. I bought the version of the CNC block that accommodates M10 bubble flares. Nice way to organize and mount the sensors and also serves as an additional location to bracket the hard lines.
--Peter
have you installed ABS on your m3?
Ive had these adaptors made up to work with all MC's. The sensors are M12x1
[img]rund.jpg[/img]
Andrew
I have a 01 Z3 master cylinder with both sensors and connectors for sale,and DSC module as well.
I bought a CAN emulator from demlotcrew that is now allowing me to get CAN data from my Mk60 to my AiM dash. Unfortunately if you have anything going into CAN other than an S54's stock ECU (or an ECU that normally can communicate with the mk60) then you will need an MXL2/MXG/MXS that has the optional CAN2 stream input to get the data. I have a functional ABS fault light now. Yippee.
It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
Turning Benjamins into noise since 1997
I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
You have my attention! Curious as to why your fault light didn't work right out of your harness to a stand alone LED and resistor? What CAN messages are you reading (e.g., brake pressure and wheelspeed?) and do you mind sharing the addresses to which the various readings are output? I have all of my ABS-related sensors hard wired both to the ABS and my Motec ECU, but I would love to read them all via CAN from the Teves MK60 and use the sensor inputs for other sensors! I have multiple CAN buses I can use, so if I need a clean stand-alone CAN bus, that is not an issue.
--Peter
No idea why my fault light didn't work. Tried many different things.
It appears that I can only read wheel speeds, brake switch, and ABS fault light. But for some reason i am getting data on an ASC innervention channel but I don't have ASC. Still being developed at this point in time and I am not doing it so I don't have the specifics.
I have brake pressures that have their own sensors (independent of the ABS pressure sensors)
Does anyone have the schematic for the wiring of the mk60 as stand alone? or just the pinout? I am looking at doing this mod on my car.
Just finishing installing this on an E36, I have all live data (wheel speeds/pressures/accelerometer info etc etc) but the ABS is not working, I can operate the pump with the bleeding process via inpa but it just locks wheels when driving, only faults showing are can errors and one for vin, pedal switch is fitted and working, fluid level is operational, fault light is wired via an LED/resistor and is on, any ideas what the problem could be?
What are the error codes? IIRC there are 4 that won't affect the operation of the system.
5 errors in total, first one is vin not matched.
the other 4 are can errors
lws
instruments
dme
cant remember the other right now
Module cannot store more than 5 codes.
Have you reset/calibrated pressure and dsc-sensors?
Ok well thats a good piece of info, I did recalibrate as much as I could see on the inpa screens, there is a whole page of learned values which I also reset.
The only digital readout I could not turn off was the tyre pressure 'rpa passive'
I expect the codes that stop the system working would make their way to the top of the list?
I did have fluid level error showing until I wired it up
Also wheel speed sensor open circuit with a sensor unplugged will show
Never had an error for pedal switch even though I started out with it not wired
Now changed the complete pump unit and its still the same
Dont think fault codes get queue priority.
Which wheel speed sensors are you using?
If you have the fault light lit then one of the codes is tripping the system.
https://www.dropbox.com/s/gci17d7646...nout.xlsx?dl=0
Should be a spreadsheet.
I copied from my WorldChallenge notes (which were populated on top of generic Teves pinout.
Peter Florance
PFTuning.com
Hi all,
In the process of installing a CSL unit now. Have all the components plumbed in, working on the wiring. This is a standalone install, tilton masters, Motec ECU and Aim dash. I have some specific questions:
1. OBDII plug is used for diagnostics and service (INPA, DIS, etc), yes? I assume I only need the D_TXD1 (white/violet, pin 2) wire from the ABS module wired to the OBDII plug? +12V, GND, and Data Link .... anything else on the plug?
2. Is the fluid level sensor needed (pin 9)? Can I just run a GND signal to it? I assume GND indicates full fluid.
3. +12V on the fat red wires (pins 1 and 32). Should this be constant +12V right to the kill switch, via fuses?
4. If I want an on/off switch for the ABS, I use pin 4 (fuse 33, 5A) and wire that to a switched +12?
5. Brake light switch: I'm using a pressure switch for my brake lights, and it switches to GND when activated. I assume the ABS module needs to see +12V when the brakes are applied. Use a simple relay for this, activated by the GND on the pressure switch? Or just tie into the brake light +12V?
6. CAN bus to Motec. Anyone do this? What do you get on the CAN bus? Id's like to see speed sensors and pressure sensors ... I'm running CAN from Motec to AIM Pista so I can't run the CAN to the dash directly
Thanks for any insight!
I got wheel speeds via CAN on the Motorsport version.
Also, the warning light was nice to have. Every once in a while, the ABS didn't power up well and needed it's ACC cycled.
Sent from my XT1080 using Tapatalk
Peter Florance
PFTuning.com
1. Yes you just need power, ground the the diag line to the OBD plug (white with violet tracer).
2. I have added pin to a switch to ground. My harness didn't come with it initially. The guy I trust most about ABS issues says it is a good idea to have it. I had it ganged to the ground but have changed it to where it can be switched (for future upgrades)
3 and 4. I have 2 big wires run thru switches and fuses to turn the ABS on.
5. I run a pressure switch in one of my rear brakes lines. It send 12v to the brakes lights and the ABS. Works fine.
6. Depends on the speed the ABS talks on and the Motec listens on. I know nothing about Motec CAN. As I understand it, the E46 ABS talks on a speed of 500k. Dunno if you can tell the Motec to what speed and what to listen for. I thought about upgrading my ABS to an E90 unit (Mk60E5) but it talks at a different speed (1Mb) so the E46 ABS can't talk to my S65 ECU. I do have an AiM MXG and have the 2nd CAN input however I had to buy a CAN emulator for it to really work and not give errors on boot up to get that data transfer. Solution works well but it was not cheap (then add on the 2nd AiM harness and getting that ABS data to the dash was about $5-600 alone. I can also have the warning light on the dash- I could never get a straight LED to work.
