funny i went to high school in ellicott city and lived in howard county for my first 18 years but wouldn't have recognized that...some great driving back there, at least as a teenager. too much traffic now.yeah, the old factory on the river
2000 540iT- 138000, engine will be replaced, ingesting coolant in cylinder one.
BMW 540iT and a Porsche 944 Turbo S. I'm a glutton for punishment
2003 530i w/ 121,000+ miles. (purchased w/ 45k in '06)
No problems. Until now.
Just completed front brakes; rear rotors frozen to hub (car was in NY 2yr, then west coast) - so that will allow me new rear hubs (but think bearings making a rumbling noise anyway).
Told by indep in PHX needs rear ball joints; he replaced thrust arm bushings.
Ordered parts for Alt overhaul - it's chirpping.
Tranny getting sloppy (manual) on shifter, probably needs bushings?
Front underbody plastic crap all broken and ghetto, esp left front wheel well.
Have .7A steady state current draw, not a good thing. No idea where.
Last monday got Check Coolant Level msg; add ~1.5L of coolant. WTF??!
3 yrs ago blew open side of expansion resevoir - Did you know that you can use billy Mays' wonder putty to seal that?! Held for 75 miles! (Makes me afraid of radiator now.)
Probably have VANOS problem; no stalling, but 75mph-mpg down to less than 30; often 28. Need valve cover gasket anyway. Possibly Oil Filter housing gasket may be leaking. Will know when I pull off Alt.
Time for plugs anyway. Have seen threads re: timing chain tensioner, need to check into that. Better replace fuel filter whilest I'm at it.
And now have road noise in R rear door vent window; some A*hole tried to break it out in PHX last summer. Replacement not sealing well. Worth replacing car? Probly not.
Oh, and the sun roof doesn't tilt, rather rattles. Could take to stealer, but he wanted $2400 for my shocks (4 yrs ago). Pack sand. Put on a set of Bilsteins.
And the dang MID lights are about 1/2 gone. THAT's annoying.
Even toyotas need maintenance. (Ask my 4runner.)
250K. No problems today. Did have to replace the plastic timing chain guides which was probably the my biggest problem. Everything else is expected with that many miles
My car just turned over 250,000mi this weekend, actually on the 31st. 1997 538iA. Build date 09/96. I replaced the engine at 226k due to a head gasket leak. Could have been fixed but I didn't feel like messing with all the timing/vanos. "New" engine had around 100k on it when I purchased it. Installed by my uncle and I. The slushbox is original. I've owed the car since around 180k. All normal maintenance items have failed more than once. It actually needs quite a few things replaced at the moment. Hood release cable broke at the handle last week. The week before that, some unknown road debri destroyed the passenger fog light. And after checking the car today, I'm pretty sure the u-joint in the prop shaft is toast. I guess with over 250k on the clock, I can't complain.
2002 530i Auto - 122,000
bought her at 119k and have replaced the following in the last 3k miles...
- replaced General Module III
- replaced front/rear windshield weatherstipping
- replaced ignition switch
- alternator
- battery
- thermostat & housing
- vanos (Dr. Vanos)
- valce cover gasket
She is running perfectly now. hopefully i won't have to do a thing to her in 2012... except change the pads on the front to Akebono ... tired of all the damned dust!
2002 530i Sport
Titanium Silver
Rear Shades
Umnitza ICE V5 LEDs
M5 trunk lip
Dice MediaBridge
Bad Pixels (of course)
99 540i 120k
-radio does the cut out about every 3 min's
-rear passenger window regulator broke
-one side of the sunroof track is broke
-navi screen blank (I think because same problem radio has)
-and to top it off the famous front end shimmy at 50-60 mph.
Got some work to do, people can't take care of cars now a days
03 525I (auto) 153K on the ODO
- Dead pixels
- Passanger window regulator is out
- Driver side door lock actuator doesn't work
- Sunroof rattle and wont tilt
- Twisted seat syndrome on both seats
No more mods until I get the above issues squared away!
145k.... 2000 540 6 sp. Anthracite Metallic, M sport package
buck fourty on the 540, and a buck twenty-six on the 528
139k, very long list of repairs. A lot of them were fixing what the previous owner did
Other cars that don't matter, and then..
'01 530i Sport/Premium/Cold Weather(My 1st love)
'02 540i Sport/Premium/Cold Weather (German bitch)
'06 330i Sport/Comfort (Sweetness!)
'08 535i/6 Sport/Premium/Comfort/Nav ()
'99 528i Sport Touring (Repaired the Previous owners garbage and let her go)
'02 525iT Premium/Nav/Cold Weather/Alpine/Supercherry
'90 325i e30 sedan schwarz (1st e30 project!)
'90 325is e30
'06 X5 4.4
'04 325i Sport
'04 330ci
'89 325IX 31k Original Miles!
'04 330i e46 coupe
'08 550i Sport
'13 535i Sport
'13 328i Luxury
'88 e30 Stroker
I have 429241kms, that's 266718 miles.
98 540 194k
only thing I need to do is replace all power steering lines, trans mount, draglink, and maybe rear wheel bearings. Theres quite of few interiors items that need attention. I've redone all other steering components, full suspension, cooling system, intake gaskets, and vac. lines.
I would love to fully restore my baby to showroom condition one day. Just redo the whole car, but a few secret additions.
98 540i sport
"LIVEN"-taking a finely tuned performance car to it's limits. One hell of a rush
E39 DIYs done: Wipers, O2 sensors , MAF , Upper/Lower Intake Boots , FSU , ABS module fix , Power Steering Reservoir , Changed Rear Differential Oil , DISA , SAP, Vacuum lines , Radar Detector Hardwire , Fuel Filter , LED Angel Eyes , Headlight Adjusters--> [1],[2], [3] , Headlight Polishing, Punted: Fan Clutch/Tensioner/Pulleys , Oil cap O-rings , Window regulator ,Crumbling Cowl
Rear taillight has been fixed since...
182k
third engine which has 6k miles.
163K miles. No work done on the car in over a year and 30K miles. Just a clean, daily driven e39.
2003 540i M-Sport 6 speed with 183k.
Purchased in 2008 at 129k and I've spent very little in maintenance/repairs:
Alternator
Battery
Upper radiator hose
Final Stage Unit
Pads and rotors
1 front caliper that locked up
It's currently having the clutch replaced. It's been slipping for over 20k miles but I've babied it and she just kept hanging on.
Tony
1998 SVT Contour (B/MNB) #542 3L
2000 SVT Contour (SF/MNB) #1533
2003 BMW 540i M-Sport (6 spd)
2002 Lexus IS300 SOLD!!
~192800miles (309500km) on my 528iA.
Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS, E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
Just turned the clock on 156,000.
Recent repairs:
Replaced center link and outer tie rods
Replaced radiator bleeder screw that deteriorated/broke apart in its hole and needed to be extracted.... Stupid.
New tires
New drive shaft guibo... Not sure, I think I need to replace the whole thing still due to vibration.
Changed the oil
Cleaned off the engine compartment of any leaking oil...I think my cam seals are leaking.... It drips right onto my headgaskets.... Which initially horrified me before I looked above them. The bottom of the bell housing was cover too. My rear main seal is dumping oil but I don't need a clutch yet.... Just seeing how long I can go on that one :/
156,000 on my clutch, anyone have a timeframe? The last car I drove needed it at 89k it was a 96 Nissan maxima I know you can't say really, but I feel like it's coming up....
