Page 4 of 28 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 689
Thread: Who's E39 has more than 120,000 miles on the clock
  1. #76
    Jun 2006
    Frederick, MD
    e39 540i/6, e36 318i
    Quote Originally Posted by OnTheFence View Post
    Almost no one seems to have replaced their MAF or ABS module.
    Are these repairs more rare than forums tend to imply?
    I think *all* repairs are more rare than this forum implies. The MAF should be a lifetime component with a good (read: OEM) filter.
    1985 325 - 5 speed - LSD - M50NV - MS2/extra - AEM UEGO - TiAL MV-R - 750cc injectors - HX35 - Blunttech Manifold - 3" exhaust
    1991 318i - 5 speed - M50NV - e36 rack - Smileys
  2. #77
    Rural KY
    2002 BMW 530i Sport
    I will post a pic later but
    i have an 02 530i but its solid now after doing all my maintenance plus the failures below
    i have 132,000
    - steering u joint replaced
    - Alternator failed
    - window regulator fail
    - tensioner fail
    - rack & pinion failed
    current problems
    -strut bar mount
    dead pixels
  3. #78
    Nov 2009
    San Jose, CA 408
    2000 528i
    About to hit 180k. Put on coils last week. Only major problems were fixed with a new radiator, ccv, and alternator rebuild.
    Need to replace vcg, vanos seals, sway bar links, and various bushings.
    ignore the dent
  4. #79
    Jul 2010
    Norfolk, Virginia
    1999 BMW 528i
    Just about to tick up to 160k miles this month. Drove her across the country 3,026 miles to be exact and no CEL. Proper I did however just blow a lower radiator hose, but that was truly my fault.
    Loving that look kchang, just need some polished calipers or something to complete the stealth look IMO.
    Alpine White 1999 528iA {} DJ Auto w/ 55w 6000k White LED Angel Eyes {} Carbon Fiber Wrap {} Matte Black Body Moldings {} DEPO Clear side-markers {} EURO Clear Tails {} 12" Alpine Type R sub in bandpass box
  5. #80
    USA
    (OO=[][]=OO)
    1998 528i with 119,xxx. Just replaced the radiator... AGAIN.
    Worst problem I had were the ABS sensors and the radiators.
  6. #81
    May 2001
    Traverse City, MI
    E46 M3 Cab, E39 540iA
    2001 540iA Sport w/261,511 miles and still runs like a champ!
    Pondering what it all means...
  7. #82
    Feb 2008
    Omaha, NE
    99' 540i/6
    122k 99' 540i/6 - just replaced ignition switch.
  8. #83
    Tyler, TX
    2001 530i
    145212 miles valve cover gaskets secondary air pump coolant system overhaul drives awesome!
  9. #84
    Illinois
    2014 BMW 435 xDrive
    My e39('99 528i), has almost 131K miles on the odometer.
    I wish it was stick, and it had a little over 200hp. Id be 100% happy with that car.
  10. #85
    Nov 2009
    San Jose, CA 408
    2000 528i
    Quote Originally Posted by I Shield I View Post
    ahh clever... I shall think about it. Black would be a possibility as well
  11. #86
    Nov 2008
    Baltimore, MD
    98 540i6
    Quote Originally Posted by joako View Post
    sounds like you need to switch to Evan's Coolant - it's expensive but cheaper than a radiator.
    I'm @ 181k. Replaced most suspension related stuff, differential, MAFS, cam sensor, coils, plugs, radiator, coolant hoses, valley pan, intake manifold gaskets, CCV.....lots of stuff.
  12. #87
    Jan 2005
    Nashua, NH
    15 328xi
    00 528i sport 5-speed
    155K and rising
    new clutch/flywheel/e60 shifter/input & output seals/guibo/rear main/and much more at 135K
    cooling overhaul, OFH seal and vanos at 137K
    tie rods and enlinks at 153K
    She had been neglected when I got her and she's come a long way. Next is suspension and wheels. Unless my brother in law decides to part with his 05 M3 with 27K miles on it.
  13. #88
    Sep 2010
    Louisville, KY
    E30, E39 540i, F30 335i
    Quote Originally Posted by 12CoolDude View Post
    Oh yeah, I don't baby her either...my middle name should be "lead foot flashing DSC dude". :-P
    EDIT: ***Fixed my "butt"...LMAO!
    LOVE it!!! Keep Flashing that DSC buddy
    123k on the clock. I bought her at 104k almost a year ago. I have since done:
    -Broken inner door handle
    -Complete cooling system overhaul, including heater hoses
    -Center support bearing & Guibo
    -Valve cover gaskets and NGK plugs
    -Mobil 1 oil every 7500k
    -New Filters
    -Wash & detail every week, nice perk when you work at BMW dealership..
    -Two rear Hankooks, Goodyear F1's went defective..
    -Plasti-dipped M-pars black for winter protection
    Knock on woods:
    -Not one dead pixel
    -Only 3 cel's since i've owned the car, & the car fixed itself overnight...
    *I do get a check brake lights everytime when car starts, but they always work fine, and they are original OEM's, just a short.
    I tell everyone she rides like a Caddy and handles like Racecar!!
    Last edited by charliehustle1; 01-03-2012 at 07:08 PM. Reason: Automerged Doublepost
    Dinan Stage 4 Software, CAI, MAF, Exhaust, Floor Mats, Stage 3 Suspension w/front & rear Strut Tower braces, Konis Yellows, & ///M5 LSD 3.15 Diff! UUC Short shifter, Evo Power Pulleys, CDV Delete, Valentine One prewired install with the StealthOne IBUS interface, 18 inch M-Parallels
  14. #89
    Jan 2003
    Santa Cruz, Ca
    87 M6, 99 540i 6spd
    Bought it 2 years ago with 132k miles, has 152k miles now, in the last 2 years did....
    -Center Link
    -Thrust arms w/bushings
    -RF wind reg.
    -RR wind reg.
    -PS pump/hoses.
    -Cup holders in front.
    -LF inner fender.
    -Removed CDV/Flushed all brake fluid in clutch/brake lines.
    99 540/6-speed
    Luckily the prev. owner did the entire cooling system and brakes all around at 125K, the clutch at 110K. Did all the work above by myself, has surprisingly been one of the cheaper BMW's Iv'e owned.
    -Schwartz 1988 DINAN M6 #1431/1767
    (Totaled by moron in Blazer, R.I.P. M6, you were always my favorite)
    -Schwartz '99 BMW 540i 6-Speed. H/R racing springs. Bilstein sport shocks, Eibach sway bars. (Police Interceptor)
  15. #90
    Apr 2009
    East
    2003 S2000
    140k , 2003 540i M-Sport
  16. #91
    Sep 2004
    NorCal-Belmont
    '01 530i s/p/5spd
    '01 530i 5spd
    210,XXX and still running strong. No major problems. Just started to have oil drops here and there....
    OEM M5 F Bumper | EuroDyne R Bumper | Magnaflow Exhaust Manifold and Full Cat-Back Exhaust | Koni+H&R Sport | CDV Deleted | Eibach f/r sway bars
    Hard-wired V1 Radar | E60 shifter w/ZHP shift knob | 18x9 Style 42 | Bridgestone RE970AS 255/35 | Zimmermann XDrilled F/R w/Akebono Euro Pads
    35% Madico tint | Infinity Basslink | E0n0n D5124Z Navi | Thule Bike Rack
  17. #92
    Nov 2011
    1998 528 162xxx got her two months ago, dealer fleet vehicle, that was regularly serviced at the correct intervals.
  18. #93
    San Luis Obispo, CA, USA
    E30 325IX, E39 540/6
    E39 540/6
    Production Date: July 1997
    Currently 180,xxx miles
    I purchased my e39 in 2004 with 75,000 miles and have had up's and downs with her. Here's a list of the downs:
    *Cooling system overhaul at 78,900
    *Alarm module went out. Dealer replaced and recoded. 110,000 miles
    *Front window molding, waterpump (again), valve cover gaskets at 130,422
    *Right rear window regulator at 154,834
    *Front left window regulator at 160,727
    *Windshield washer fluid pump at 165,972
    *New ignition coil and boot at 169,053
    *Valley pan gasket, all engine seals, coolant system overhaul, timing chain guides, ccv,
    suspension overhaul, front window molding, front door seals inner/outer, and I'm
    sure there is stuff I'm forgetting. 180,000
    That's the list of stuff that has "broke". I've also done all the scheduled maintenance stuff blah blah blah. Over all I've dug having the car and I'm glad I got it. The car is currently down while I'm finishing all the suspension stuff I'm currently working on. Should be done in Feb sometime. I can't wait!
    [IMG][/IMG]
  19. #94
    Lexington, NC, USA
    2003 BMW 540i6 M-Sport
    2003 540i6 (m62) w/ 140xxx. wish it was lower, but still runs like a champ! Im the third owner and had it for about 8 months and put maybe 6k on the car. since i've had it ive only replaced a throttle body housing and a powersteering line. Needs thrust arms. not to bad i guess.
  20. #95
    USA
    (OO=[][]=OO)
    Quote Originally Posted by mattmartindrift View Post
    It is flammable? Would be nice if I wanted to get rid of the car, but I don't. If the car were to catch fire I would get another E39 or an E60.
  21. #96
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    What isn't flammable? You have pressurized gas, pressurized oil, trans, power steering.
    And a low pressure coolant, seems like a no brainer to me
  22. #97
    Jun 2006
    Frederick, MD
    Quote Originally Posted by Kris88 View Post
    ellicott city? Same place I shot this?
    slammed e30 by Cyrix_2k, on Flickr
    e30 plant by Cyrix_2k, on Flickr
  23. #98
    Nov 2008
    UT, USA
    00 528iT,06 Charger
    152K on the clock, nothing major all regular crap our cars need! but she still runs strong!
  24. #99
    Manchester, United Kingdo
    E39 525i Auto ^_^;
    2003 525i Auto. Just over 100K miles. Had a new FSU (at 80K), ignition coils (at 65K) and AC Panel (at 80K) fitted. Normal maintenance carried out. Have a new thermostat and housing put to one side to be replaced in the next week or so. Parts that didn't need replacing but got done during the modding phase were springs and exhaust. No other problems to report.
    E39 525i Sport Auto / AC Schnitzer Mirrors / Hamann Sideskirts / Hamann 19" HM2 Alloys 9J Front 10J Rear / Exotics Tuning lip
    Quote Originally Posted by Okin View Post
    O Tay..... Eyez Essplainin...
    See, In teh Live Free or Raise Yo Sh*t state, Teh Po-Po no likey dem Lo Lo's. So dey be on teh look-outs fo Lo Lo's. Eyez no ownin teh cah, eyez jus du paintz fo teh ownah
  25. #100
    Ellicott City, MD
    98' 528, 80' 911, 04' A6
    Quote Originally Posted by Cyrix2k View Post
    yeah, the old factory on the river... cool spot, i'll have to try it myself!
