137,239 on a 2001 525i Sport wagon. I have put a whopping 200 miles on it myself since I bought it a week ago and I have already encountered some serious problems... time will tell if I got a lemon or not.
185,700 miles right now. Runs fine but with vague steering that I'm tracking down. Since 135k I've replaced:
-thrust arms
-tie rod ends, center link, idler arm w/bushing
-shocks/struts
-diff
-CSB
-passenger window regulator although the original didn't appear to be bad
-battery
-two water pumps
-idler pulley on the belt tensioner
-a bunch of hoses
-filters/spark plugs
-front brake rotors/pads
I can't really think of anything else. It's mostly normal wear & tear. Oh, and my moonroof is broken thanks to a friend.
123,xxx miles on my e39 and I have driven many long trips since I got it this past April @ 108k. Installing new MAFS made a HUGE difference.
'13 328i F30
'13 Mustang 3.7 V6 Coupe Premium Pony Package
PAST
87 528eA. 01 525i/5 Sport
87 528e/5. 01 M5
92 525i/5. 03 325xi
92 535iA. 10 Mustang V6 4.slow
99 528iA Sport. 13 X1 xDrive 35i
Somewhere between 160,000 and 170,000. I wouldnt know as 70% of my pixels are gone lol
153,000 miles. New radiator about 10,000 miles ago, but thats to be expected.
'99 528iT M52TU/5 speed - 229K miles
Work completed w/in the last 90 days
Bilstein Shocks/Struts
Inspection I
Rear sub frame bushings
Rear stabilizer bar links
Right rear lower control arm
Four wheel alignment
Both of the sedans have less than 90K miles.
2004 X3 2.5 Silver/Grey - Sport/Premium Package
2001 530iA Steel Blue/Sand - Sport/Premium/Cold Package
1982 Fiat 2000 Spider Blue/Blue
1999 528iA Black/Black - Sport/Premium/Heated Seats SOLD
1999 528iT 5 speed Beige/Sand - Sport/Premium Package SOLD
1989 535iA Salmon Silver/Black SOLD
Auto @176k miles
Cooling system
VCG
FSR
MAF
Shocks
Just ordered trans oil cooler lines today
M52TU, manual, 221K mi. Replaced lots of pulleys and tensioners, main belt, all cooling parts except water pump (soon to be done), VC gasket, and vanos seals.
No problems so far. Have only out 11K on it myself. I'd say the vanos seals made the biggest difference so far. Still need to do throttle body gasket, disa valve o-ring, airbox o-ring, and CCV and hoses.
M62, Manual, 138.5k mi.
Quick running log I set up a little while back : http://forums.bimmerforums.com/forum....php?t=1713303
2002 540i | 6 speed | (892) Titanium Gray | BC Coilovers |E60 SSK - ZHP Knob | CDV Delete | M5 RSB | Muffler Delete - 2.75" Turndown | Dice Duo | Spec Dock | Running log -> http://forums.bimmerforums.com/forum/showthread.php?t=1713303
NOT I! 2002 530i at 83,xxx. 2 owners. Previous owner had it in storage for a little under a year saving it for his 14 yr. old son. Son refused to keep it and wanted a VW instead
I have 267,605 miles as of tonight. It's the original m52 engine and original auto trans with original fluid.
Most recently I replaced the CCV this week, which was original as far as I knew. I've also replaced the whole cooling system about 25k ago. ICV about 10k ago. All new Bilstein coils 10k ago. Vanos seals and valve cover gasket about 4k ago. New general module 3 about 2k ago.
And that's the recent stuff, and the oil has been changed since 114k with royal purple.
138k No problems
130.000 miles, did the CCV and VCG replacement, no further issues
Engine m54, 3.0l
'02 525iT 5sp 130K mi. No problems.
If money is the root of all evil ...why do churches beg for it?
there / they're / their ...then / than ...two / too / to ...bass / base ...bare / bear ...brake / break ...you're / your ...do / due / dew ...patients / patience ...wait / weight ...affect / effect ...know / no ...sell / sale / sail / cell ...whole / hole ...reign / rain ...moot / mute ...its / it's ...pore / pour / poor ...buy / bye / by / bi ...lose / loose ...here / hear ...bore / boar / boor ...waist / waste ...were / we're ...and / an ...mourning / morning ...shelve / shelf ...well / we'll / will ...one / won / Juan ...who's / whose ...through / threw ...for / fore / 4 / four ...bored / board ...steel / steal / still ...scene / seen ....road / rode ...sight / site / cite ...mat / matte ...ascent / ascend ...tear / tare ...throw / throw ...vice / vise ...meat / meet / mete ...learn the difference
An armed man is a citizen ...an unarmed man is a subject.
Mine is a 1999 540 6 speed with 145001 k miles.No major problems as of yet prob doin the vanos and valley pans and while im in there what ever else needs it to be preventitive !
135k
2000 540i6
Could need a valley pan gasket
Want to change timing chain guides
Valve covers leak
PS fluid leaks
Just had $1,500 worth of front end work done and a rear ball joint
KEVIN
BMW CCA # 416146
Current 2001 525i-5 / 234,000 Miles
///M Weighted Shift knob.
CD43 with AUX retrofit + Bluebus
Auto Dimming Mirror upgrade
H&R Sport / Koni STR.T
OEM Xenon HID Retrofit
The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
CDV Free, 545i Shifter and ///M Weighted Shift knob.
Member of DSC Module Failure Club $$
283k. M52, head gasket followed by cooling overhaul with high performance water pump, alternator due to leaky power steering fluid reservoir, driveshaft, fuel pump and recently an o2 sensor. All else just regular maintenance stuff. I change my oil every 3k on the dot, no matter what BMW says. Engine flush every 9k. You could eat off my valves.
Arctic Metallic 2007 328i Coupe
Alpine White 1997 528i
Orange 2011 Dodge Caliber
Titanium Silver 1985 325e (RIP), Oxford Green 1992 325i (RIP)
Sachs Sport Suspension, 18x8.5 18x9 staggered RPM 505
OEM prefacelift M5 headlights and taillights
Boston Acoustics Pro50SE speakers, Boston Acoustics Competitor 12" sub
Boston Acoustics GTA-400M and GT-22 amps, Alpine CDE-HD148BT Headunit
2001 with 216K
Maint wise I've done intake gaskets and everything associated. Valve cover gaskets, plugs. Recently did shocks/struts/H&R Springs and suspension front and rear. Some suspension parts didn't need replacing but did it anyways.
This pic is before suspension rebuild, car sits a bit lower and front is now a bit lower than the rear.
01 530ia with 152k miles
-Radiator replaced
-Disa Valve replaced
-complete cooling system (stewart wp, and npg+ waterless cooling)
-new alternator
-Radiator replaced again
-oil filter housing gasket
- valve cover needs to be done next weekend
260 k km
525 d
everything redone except engine and tranny (and body+interior) the rest 70-80 % is replaced
just turned 180k on the 99 wagon and my 99 sedan 193k .
153,500 on a 2000 540i Auto.
Both vanos and cam sensors
Front struts
Thermostat
Wheel speed sensor
Condenser cooling fan
Valve cover gaskets
Front cover is leaking oil but haven't fixed it yet because it's expensive and it's not on my driveway yet.
