hello every one i need your gurus help
got 96 bmw 850i auto with 76k and it shows codes p1421 and p1423
(p1421 manufacturer controlled auxiliary emission controls)
(p1423 manufacturer controlled auxiliary emission controls)
is some one knows what is it and what needs to be don
and i got some weird noise under back seat
it only doing some times its like some thing splashing inside is it fuel pump going out ???
then the half of the dashboard is hot and the other one if cold
so far that's it
any help will be thankful
thanks Sam
SAE Code P1421
Description Secondary Air Injector Valve Circuit Short to Ground
SAE Code P1423
Description Secondary Air Injection Bank 1 Flow Too Low
Your injector valve relay is shorting to ground, causing the "Flow to low" error.
Use the attached PDF to understand how it should work and to troubleshoot it.
'93 850Ci - Mineralweiß Metallic
2001 740iL - Titansilber
ALPINA B7 -Alpinweiß III
thank you very helpful info
now i got some checking to do will let you know how its turn out
I received 2 diagnosis: 1. Replace air pump. 2. Replace air pump and check valve and hose. Is diagnosis 1. too conservative, or is it worth a try?
