- hot starting issue
hot starting issue
Sorry for starting new thread but couldn't find anything related,
When I do a cold start with the car it starts with no problem. However, when when its warmed up, I start the car after its been turned off for 5-10 minutes it has serious trouble starting up, sometimes it'll take 10 seconds to crank over, most often it takes a few attempts, and sometimes it won't start at all. It cranks over fine, but sounds like its not getting any fuel. If however though I pop the hood just after I turn the car off, the chance of refiring seems to get a lot better. I've had this issue with my car now for close to a year now, but as soon as the weather drops the problem gets worse (during the summer it usually works fairly predictably). Some recommendations have been:
damaged crank position sensor
temperature sensor
Mass air
ECU (not turning the fuel pump on)
faulty/ leaking lines that cause hotter air to be sucked in (supported by lifting the hood resulting in easier starting?)
fuel regulator/pump?
I'm just wondering if anyone has experienced similar problems because I have had no luck at all in google/ forum searching and mechanics say to get a code reading. However, temperature and crank position sensors won't put out a code unless they are wrecked so a reader might not find anything relevant.. or so I've been told. Thoughts anyone?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
