Page 3 of 8 FirstFirst 12345678 LastLast
Results 51 to 75 of 180
Thread: Amsoil MTF WOW (new)
  1. #51
    New Jersey
    1997 Z3 Roadster 1.9
    Temps on Sunday morning were below freezing and through the first 10 minutes of driving I felt some improvement in shifting but was still kind of sticky between 1st and 2nd.
  2. #52
    Tyrone, Ga USA
    2010 135i M Sport 6MT
    how does it feel now?! :-)
    BTW, I currently have 10% all orders :-)
  3. #53
    New Jersey
    Trans is feeling quite silky when cold now, gonna stick with this till spring then I'll put in some 5-30 sycnhro mesh.
  4. #54
    Tyrone, Ga USA
    Quote Originally Posted by Bergen Bimmer
    Awesome :-)
  5. #55
    San Diego, Ca
    2006CiC
    Just did the Amsoil MTF and 75-140 Diff fluid in my 2000 M roadster. Combined this with a stainless clutch line and removing the delay valve.
    It's waaaay better. I can actually feel the detents now.
  6. #56
    Rochester, NY
    99 M Coupe, 02 Z3 2.5
    I just ordered off $300 worth of Amsoil products last night including everything for the coupe. Can't wait to get it all swapped.
    1999 M Coupe Boston Green, Beige, H&R/Bilsteins, Underdrive Pulleys, Euro 6 speed, UUC SSK and Randy Forbes in the back
    2002 2.5 Z3 roadster Oxford Green, auto, all stock
    2013 Ram 3500 Crew Cab Dually 385 HP, 850 ft lbs torque at 1600 rpm, all stock and staying that way
    2004 Mini Cooper Chili Red, daily driver, modified almost daily
  7. #57
    Tyrone, Ga USA
    Quote Originally Posted by Wertles View Post
    So how is it?
  8. #58
    Tyrone, Ga USA
    updated with more specs in first post :-)
  9. #59
    Dec 2012
    Fort Worth, TX
    2000 BMW Z3 M
    I had good luck with Amsoil previously and this sounds like it might be good preventative maintenance for my car.
  10. #60
    Jul 2012
    putnam, ct
    Z3lda-Crash/burned RIP
    Call me Lazy but I put Amsoil in my DD's (09 Mazda 6 and Mazda 3)and change my oil once a year, I average over 30K year on 09 and 15K on 3 and when I do get around to changing them, it looks like any other oil changed at 3 to 5K. Oh and my 6 has that idiot light that comes on to tell me that my oil needs changing...last time it came on I had like 40K since last change, So yeah, I'm a believer.
    Z3lda - R.I.P. 7/6/13 crashed and burned, total loss.
  11. #61
    Salem, Nh
    01 Z3M Coupe
    Quote Originally Posted by 2kredz3 View Post
    OEM Fluid Specs: MTF-LT-2
    VIS40 = 58
    VIS100 = 10.6
    5w30 Manual Synchromesh Fluid
    VIS40 = 48.3
    VIS100 = 9.7
    75w90 Manual Transmission and Transaxle Fluid
    VIS40 = 88.4
    VIS100 = 14.8
    And just for comparison a diff fluid which should not be used in your transmission:
    75w90 Sever Gear Amsoil
    VIS40 = 109
    VIS100 = 16.8
    Automatic Trans Fluid, also should not be used in your car:
    Amsoil Multivehicle ATF
    VIS40 = 38.8
    VIS100 = 7.5
    Hmmm...I've been using Red Line MTL in all my BMW manual transmissions -track and street forever and been pleased.
    Vis @ 100°C, cSt 10.6
    Vis @ 40°C, cSt 56.2
    Looks like it's almost identical to the BMW OEM Fluid Specs: MTF-LT-2. wonder if I'd see any improvement in going with the 5w/30 seems it'd might be better for the street less so for the track ??
    For the diff I've always used the RL 75/90
    Vis @ 100°C, cSt 16.4
    Vis @ 40°C, cSt 115
    There is loud no-load whine from my diff at 65-85 mph as described by dkindig that I'd love to eliminate wonder if changing out the RL to Amsoil 75w / 110w would help ?? doesn't look too different
    Viscosity @ 100°C, cSt 16.8
    Viscosity @ 40°C, cst 109
    Any thoughts suggestions??
  12. #62
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The specs I have on the original BMW fluid is very different.
    cSt@40 c 37.5
    cSt@100 c 7.5
    Viscosity index 172
    And the current Pentosin replacement is
    cSt@40 C 38.2
    cSt@100 C 7.7
    VI 177
    /.randy
  13. #63
    Tyrone, Ga USA
    Quote Originally Posted by rf900rkw View Post
    cSt@40 c 37.5
    cSt@100 c 7.5
    Viscosity index 172
    cSt@40 C 38.2
    cSt@100 C 7.7
    VI 177
    I do not know about the current pentosin, but the specs you provided now in red are for MTF-LT-1 not MTF-LT-2.
    I know there are some mz3's that came with MTF-LT-1 but most that I have seen had the label for MTF-LT-2 and have never seen one that said pentosin on it.
    Quote Originally Posted by CMM3 View Post
    Vis @ 40°C, cSt 115
    You should not be running anything but 75w140 in your rear diff, which could possibly be why you have noise. However, once the noise has started it is nearly impossible to stop. . .with out a fresh set of gears.
    If you track your car regularly then I suggest the thicker MTF :-)
  14. #64
    Dec 2007
    Great Dismal Swamp
    Yes, the "original fluid" is LT-1, as LT-2 was not introduced until the 2004 model year. And at the time of introduction, BMW said LT-1 and LT-2 were fully interchangeable and mixable.
    Also, the Pentosin is the current LT-2.
    /.randy
  15. #65
    Tyrone, Ga USA
    Cool, ill update the main page :-), also if LT2 was not released until 2004 the Bmw replaced badges on a bunch of car made before then. My z3 had LT2 badge on it, interesting.
  16. #66
    Imperial, PA
    1998 Z3, 2.8; 2000 328Ci
    Post
    As indicated in another thread, I just purchased the Pentosin and will try it this time; after running Mobil 1 75W-90LS for @15K miles (3 years). Not sure if I am graduating up or down grading...
  17. #67
    Dec 2007
    Great Dismal Swamp
    I'll send you the pdf I have. I have it at home if I can't dig it up here. As best as I remember,
    1990- Green tag = Synth oil
    Orange tag = ATF
    1998 Yellow tag = LT-1
    2004 Green tag = LT-2
    2006 Blue tag = LT-3
    EDIT:
    http://billswebspace.com/BMWOperatin...rans230409.pdf This appears to be the manual trans section of the same document.
    /.randy
  18. #68
    Tyrone, Ga USA
    Thanks for sharing, i find it most interesting that it says specifically not t use atf fluid unless extreme cold.
  19. #69
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by wmcq6 View Post
    ... my 6 has that idiot light that comes on to tell me that my oil needs changing...last time it came on I had like 40K since last change, So yeah, I'm a believer.
    So the Mazda 6 oil change computer said the AMSOIL did not need changing for 40,000 miles? Wow, you should tell AMSOIL. I was an AMSOIL dealer back in the 1980s and their oil sure has gotten a lot better now. Or maybe the computer programming has.
    Two of our cars have oil change computers, and when they say 50%, the oil is between 5,000 and 10,000 miles but looks so black and nasty that I can't bear to leave it in.
    ... You should not be running anything but 75w140 in your rear diff, which could possibly be why you have noise....
    AMSOIL does recommend 75W140 for limited slip differentials. For my 1.9 they only recommend 75W-90 :
    http://www.amsoil.com/mygarage/Produ...=1997+BMW+Z3+1
    Why do you say using anything other than 75W140 could actually cause damage to a differential? That is not likely what BMW specified for any of its differentials. Do you know what BMW specified (I don't) ?
  20. #70
    Dec 2007
    Great Dismal Swamp
    Yes it does, it also states that the use of any unapproved synthetic lube will cause damage. Lucky for us this is in the section on transmissions that use mineral GL4.
    /.randy
  21. #71
    Dec 2012
    pthu507
    pthu507
    Vote bác, em lÃ* newbie mÃ*!
  22. #72
    Sep 2008
    Havertown, PA
    02 e367, 08 Acura TL-S
    I always thought the oil change computer went on driving style/mileage calculations and not actual oil condition.
    -Todd
  23. #73
    Quote Originally Posted by lokijibber View Post
    That is correct
    PRICE CUT on ALL FABRICS
  24. #74
    Imperial, PA
    Thumbs up
    Quote Originally Posted by aba4430 View Post
    Completed the fluid changes yesterday with Pentosin MTF2 (tranny) and Mobil 1 75W-140 (differential). The Mobil 1 was previously in the differential and was an even replacement. The Pentosin replaced Mobil 1 75W-90LS in the tranny. Went for a @25 mile drive and I can say that the tranny fluid is an upgrade from the Mobil 1 for the Z3. The shifts were easier than with the Mobil 1 when cold, and felt at least as damped throughout the drive. The Z3 also felt more responsive (butt feel). Though I did not have drivetrain noise (notable whine etc.) with Mobil 1, the Z3 was quieter last night (butt feel again).
  25. #75
    Tyrone, Ga USA
    Quote Originally Posted by Vintage42 View Post
    For the 1.9L yes 75w90 is what you want, for 6 cyl non m cars (2.3,2.5,2.8,3.0) 75w110 is perfect, and the 75w140 is what is recommend for the m cars :-)
