Results 1 to 9 of 9
Thread: Broken Head Bolts
    Nov 2011
    Louisville, KY
    2006 BMW 525
    Broken Head Bolts
    3 of my head bolts broke in my 2006 525 and when I called several dealerships I was told that is a very common problem but it was my expense to fix. Since this is a very common problem with BMWs and I called BMW of North America to see if they were considering recalling any model years and I was told their responsibility stops at 50,000 miles when the warrenty runs out.
    I am looking into how much interest there would be in filing a class action lawsuit against BMW to force them to cover the cost of fixing their design problem. Please let me know if you have had the same problem and are interested in participating.
    norwalk ct
    2000 M COUPE
    TX!
    2009 BMW 335i E90
    Broken head bolts can be a serious problem. And if its a common problem, the Lemon law should take place.
    Nov 2005
    Mechanicsville, MD
    90 325iS50, 98 Jetta :-/
    Head bolts. I'm not going to say where I work or what I do, but I've seen it many times just this year.
    Nov 2011
    Louisville, KY
    2006 BMW 525
    It was the head bolts which as it was explained to me, the different metals used for the block, head, and head bolts all heat and cool at different rates which causes the head to shift and eventually cause the bolts to break. Also I followed all the BMW recommended maintenance intervalls sms after only 97,000 miles I had several bad lifters and my valve stem seals were seeping oil, all premature wear caused by changing the oil every 15,000 miles. Every mechanic that I have talked to that has opened up a BMW engine has said it was bad and everyone of the owners followed BMWs guidelines.
    Nov 2005
    Mechanicsville, MD
    There is a service bulletin for lifter noise. I haven't seen bad valve seals on an N52 yet personally, just the N62 all the time.
    Oct 2007
    Chandler, AZ
    E36 323is/5
    File lawsuit, take money, have ARP head studs installed.
    Semper Fidelis
    H&R /// Koni /// Powerflex /// AKG
    My 3.46 LSD Build Thread
    Jun 2012
    Carmel valley, ca
    2006 bmw 325i
    Just found out that one head bolt is broken on my 2006 325i. 61k and just out of warranty. Dealer quoted $3500. I would participate in a lawsuit. Has one formed?
    Holly, MI
    2005 325Xi
    i haven't seen this issue with head bolts yet ... . Working at a high-volume dealer, you'd think I'd have seen some. I'm not saying that it isn't happening, but either it's happening less than it seems to you, or maybe it's a regional thing.
    If a dealer employee told you that it's a "very common problem", they were likely speaking of broken head cover bolts (aka, valve cover bolts), and not actual head bolts. Broken valve cover bolts aren't uncommon. However, they don't cost $3500 as Oellen mentioned. Of course, if Oellen just called a dealer and asked how much it costs to replace "head bolts", when he/she really meant to ask about "head cover" (or valve cover) bolts, that could cause some confusion and he/she would obviously receive an incorrect quote.
    I'm curious as to how the two of you came to the conclusion that you had broken head-bolts.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
