Results 1 to 20 of 20
Thread: Calling on all wheel fitment Gurus
    Nov 2008
    LOS ANGELES
    1981 E21
    Gents,
    I have a modifed E21 with the RACETEP Big Brake conversion up front, 323i rear disc out back. Coilovers also done at RACETEP. Will 16x8 et5 fit up front and 16x8 et0 fit in the rear? What tire size would you suggest?
    Thanks!
    Asheville, NC
    2003 325Ci
    offset wise everything should fit but it sounds like you may need some fender rolling/pulling to fit that size wheel. and you may need to stretch tires just a bit
    '83 320i in the works
    Nov 2008
    LOS ANGELES
    1981 E21
    Thanks! What tire size would you suggest?
    Asheville, NC
    2003 325Ci
    I would ask "TheNeek" about that one or you can play around with the miata tire calculator. i'm asuming you want something that wont throw off your speedo too much
    http://www.miata.net/garage/tirecalc.html
    Mar 2003
    Orange County, So CA
    Turbo E21,12 WRX,03 S2K
    You will have to have the fenders roll. If you go 205 series tires you will be fine, but might rub if you go to the lowest setting.
    E21 LEGION
    Crypto success: http://brief.watchersfrontline.com/SHV
    Asheville, NC
    2003 325Ci
    205/45/r16's look like they would be your best bet
    Nov 2008
    LOS ANGELES
    1981 E21
    Will et5 up front will poke out past the fenders? I will have to roll my fenders with any tire set up? Thanks again!
    What about 205/40/16 up front and 215/40/16 out back?
    Or 205's the way to go?
    Aug 2008
    Carlsbad, CA
    80 320i
    Im running 205/40s all around on 16x8 et0. You'll be fine with 215s in the rear because the lip of the rim will be 25mm away. The front will be flush with the fender but with stretched tires you should be in the clear as long as you roll the fenders. The rear will only need the fender lips to be rolled.
    Nov 2008
    LOS ANGELES
    1981 E21
    sweet! thanks to you all! You're great!!
    Would you mind posting pics E21Robb?
    Aug 2008
    Carlsbad, CA
    80 320i
    the front clearance of 16x8 et0
    side shot of both front and rear with the 205/40 stretched tires to fit under fender, these pictures are after i rolled the lips and rolled the fender out. Also the rear has a 25mm spacer on so the rim is close to the fender.
    Nov 2008
    LOS ANGELES
    1981 E21
    Thanks for the pics. Was the spacer needed before rolling the rear fenders?
    Aug 2008
    Carlsbad, CA
    80 320i
    just the lips if you go low
    australia
    E21 320i 2.0ltr "79"
    E21 Robb you have a nice neat tough looking little car, what a gem
    Nov 2003
    TX
    '98 528i 98k 5-SPP
    WOW! !
    Greenville Wi
    1982 320i 5 speed.
    Now that looks clean! Lets see some more pics of those rims!
    Oct 2005
    Canberra, ACT, Straya
    82' E21 318i, 92 MB-180E
    Quote Originally Posted by DHoang View Post
    WOW! !
    I know I have a go at people with form > function cars but fuck that looks tough man. If I was a little less about hunting skylines and silvias I'd be all over that look.
    "The most important thing is balance." - KT
    Aug 2008
    Carlsbad, CA
    80 320i
    Quote Originally Posted by Big John View Post
    Hah i think i need to do a new photoshoot cause this was when i was at a comfortable daily driving height hah. im daily driving another inch lower right now
    Jan 2003
    Mill Creekish WA
    97 M3/4/5 81 E21 72 Bav
    Quote Originally Posted by E21Robb View Post
    Immediately
    Oct 2005
    Quote Originally Posted by TheNeek View Post
    Immediately
    +1
    Asheville, NC
    2003 325Ci
    +1
    +2
