Looking down on the engine bay and above cylinder 1, there is a hose that hooks in the direction towards cylinder 3.
1) What purpose does it serve?
2) From that hose, there is an additional thin rubber hose that goes down and under the induction header assembly and comes up on the driver side of the unit. Where does that go and what purpose does it serve?
3) This thin rubber hose had a tear in it, would that have affected anything? I recently repaired it by wrapping it some black electrical tape around it.
what colors are the hoses? Can you take a pic?
Are you referring to these?
Vacuum hoses- Very important to keep them and the rest of the engine sealed so air doesn't bypass the meter.
Electric tape typically does not provide a good enough seal and is not a long term solution. If the hoses have a hole in them you should replace them. Bavauto has them for sale individually and bmrparts has a package for sale that includes all preformed hoses and boots (you will still need some small diameter hoses if you intend to replace all of your vacuum lines).
what i have is this:
Vacuum Hose, Silicone, White, 3.5mm x 2.0m
11 73 1 259 994
Your local parts store should have 1/8" vacuum hose in bulk for a dollar a foot....
I'm not sure the purpose of that hose, outside of adding another avenue for PCV(Positive Crankcase Ventilation) to work thru.
Does Bav Auto sell the right most crankcase ventilation hose? That is the one that goes from the valve cover to the T connector? Does anyone know the proper name for this hose? By chance is it the first one below?
Hose - Auxiliary Air Valve to T- connector Part # : 11 15 1 286 255 $ 9.95.................................................. .................................................. ...............
(click to see more) Hose - Auxiliary Air Hose Tee to Auxiliary Air Valve Part # : 11 61 1 286 258 $ 8.95
I think this might be what you're looking for:
The name doesn't seem right but it looks more like what you're talking about.
Part Number 11 15 1 286 257 - HOSE - VALVE COVER BREATHER
No. 11 in this diagram from www.bimmer.com
$4.54 from www.bimmer.com
$3.95 from www.bavauto.com (see in the UNDER THE HOOD / INTAKE BELLOWS & BOOTS section)
BMP Design (www.bmpdesign.com) puts together a kit so you don't have to figure it out and you can focus on replacing the whole caboodle. What the kit has that isn't under the bavauto section are the Auxilliary Air Valve hoses (bottom - goes to the AFM boot/bellows aka Intake Hood; top - goes to Cold Start Injector housing).
BMW Design Part number 62405 $59.95
Bavauto will price match if you request them to, for all the parts in BMP Design's kit.
Fullswing, thanks a million.
what if you're not running FI, what purpose does that ventilation serve?
Jayhawk
I have a question regarding the hose (dark brown/greasy as shown above) coming downward from the T-connector connected to the PCV hose:
- How does that vacuum hose connect upwards to the T-connector? Is there a clip or equivalent?
- The hose comes down and back up to connect to the fuel injector assembly (it's not visible unless I use a mirror). How too is that connected? Is the only way to connect it with the help of a mirror?
while it does direct the oil vapors into the manifold for combustion, this is done for pollution control and not at all the reason for the Positive Crank Pressure Vent. the reason is to vent out the positive crank pressures from within the engine. there was a time when the hose just vented to below the car.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
The hoses simply push on over the barbed nipples of the tees. This goes for both the big 'n little hoses.
The hose comming out of the valve cover descends between the inlet manifold runners and bends forward. Just forward of the bend is a tee that the small hose connects to. The other end of the small hose connects to the tee in the hose that runs from the auxillary air valve to the inlet manifold. The connection to the inlet manifold is integrated into the cold start valve mount.
Any hole, tear, breach, etc. in any of these hoses = vacuum leak = lean air/fuel mix.
As to the function of the small hose, I have'nt a clue. I vaguely remember one of those tees has some sort of valving mechanism in it but never pondered what its' function might be.
As to the physical act of inatalling / attaching the hoses, you'll have to get stuff out of the way and have double jointed wrists and fingers. Small hands help too (something I don't have). It's been quite a while since I've been into that plate of spaghetti down there & don't remember any specific tricks other than swearing profusely. Perhaps another member can help.
"The water was not fit to drink. To make it palatable, we had to add whisky. By dilligent effort, I learnt to like it." Sir Winston Churchill
hmm .. Wonder what happens if I do this ...
Awesome thanks GDAus! I found it!
