thanks for the fuse 31 check. mine was popped causing my no start. not sure what caused it as I'm all stripped and most wiring deleted. turned key after putting in new MAF hoping it was causing my bad idle problem and nothing when i turned the key.
wanted to comment for future search results for others!
^^ I'm having this exact same issue. The car used to crank no issues (97' 328iS). I went through the fuse box and replaced a few blown fuses and now my accessories are working (lights, horn, wipers etc - they previously were NOT). The aftermath from that would be: lights on dash, gong chime, no sounds/click at start/ no crank.
Battery is relatively new and I was using another car to jump.
I'm going to try and do an deeper analysis of everything. Hopefully it's something minor as I would love to start driving her again.
BUMP for anyone that has information.
function leads to form
Hi there. Bumping on a really old thread here in hope for some answers!
Was gonna take my 328i to a shop for rust welding this weekend after 9 months in the garage and when i turned the key around i had a no crank no start. BUT the starter motor clicked and the lights inside dimmed crazy.
Changed the battery and then all of a sudden no click from the starter motor either. Just lights working, OBC working, horn working, radio working.
So this is what ive done so far:
- Checked the battery for voltage; 12.4V
- Tried to boost the battery, nothing.
- Tried to jump start it with cables from another car, nada.
- Tried to push start it, nothing.
- Checked the connectors on battery, all fine.
- Took out the Crash Relay, still nothing.
- Changed the #31 fuse just for good measures, still nothing.
- Hammered on the starter, still nothing.
Its a m52b28, 09/96, so obd2.
Gonna try to do diagnostics tomorrow to see if anything shows.
Any ideas guys? I've barely toutched a engine, so im pretty newb at electrical stuff and im wondering if it could be that the key is broken. Dont have a spare either so gotta order a new one if so.
I also wanna say that it cracked up fine 4 months ago...
Also, relays... what is actually what here? its all in german so i dont understand anything.
Please help a engine noob out.
Edit:
Found out the ground cable from engine mount to chassie were in really bad shape.
removed it, cleaned the mounts and put a jumper on just to try.
Sadly that didnt do anything...
I have the same issue with my 97 328i at 145k. Randomly the other day, it won't even crank when I try to start it. All lights and accessories work, including the OBC and HVAC. Battery reads 12.3v and a jump start doesn't help at all. I opened the back of my key and I can see what looks like a bit of corrosion on the chip inside, so I ordered another key because I only have the one anyways. I'll post if it was the key or not when I get it in 2 days.
Sent from my HTC One_M8 using Tapatalk
Just wanted to bump this with some results. I ordered a new key from BMW last week, it came in today. Stuck it into the ignition and she fired right up (although I did need to boost my battery.) Hope this was helpful! Now I need to tackle a slew of other electrical issues.
Just curious, how much did the new key run you?
I'm having the same issues. I had my windows down and work and it started to sprinkle so I went outside to roll them up and accidentally left the key turned on. I went to leave for lunch and the car wouldn't start. i tried to jump it and nothing. I ended up pulling the battery and putting it on a battery charger here at work. Once i got off i tried it and all my lights and everything work but the starter wouldn't even click. I thought maybe the battery had a bad cell or something so I took it to Autozone and they tested it and said it was fine. The battery is exactly a year old this month. I put it back in the car and checked the connections at the battery and the connections to the posts under the hood and everything seems very secure. Tried to start it and same thing, fuel pump kicks on, lights work, starter doesn't even click. I've let the car sit for a few weeks now because I just havent had the time or money to deal with it since school started back up with my kids. I checked it out yesterday and I have the same issues. I grabbed a meter from the shop and I'm at 11.7v at the battery, 11.7v at the posts, 11.4 volts at the relays, and 11.2-11.4v at the fuses. i checked all the fuses listed in this thread and they all appear to be perfectly fine. i even tried to push start the car across the parking lot and had no luck..
1996 318i manual.
Check out if fuse 31 is blown. It powers the heater valve, clock, warning chime, OBC, and something related to the starter or EWS. If it's blown then you can't start the car. Also check whatever fuse and relay power the starter.
LivesNearCostco - you are the man! I tried to move my '97 328 this evening to get it out of the way of my wife's 2013 328. Lights were bright but not even a click from starter. I was about to check the clutch pedal switch when I read your post and went back out and checked - No heater control lights! Swapped fuse #31 and heard the chime. Car started.
Now to see if it blows again - but at least the problem is narrowed down.
Thanks!
Glad to hear you were able to start the car by swapping !the fuse. In my case it was blowing because of a short in the heater control valve. Once I blew it 2 times, I disconnected the heater control valve and it stopped blowing fuse 31. But then I got hot air from the vents all the time! Eventually I replaced the heater control valve
hello i have a 97 bmw e36 328is manual trans i have been getting a problem i turn the key and everything electronic works but it doesent crank to start the car and i don't know what it might be starter maybe the guy i bought it from told me that everything it doesent that to put the windows down for like 10 min and it will start and a couple times i tried it and it works but others it doesent
He's saying if he turns the car the dash lights come on and "everything else" works (presumably that's blower fan, headlights, stereo, power windows, etc.) but the engine doesn't crank. So it's likely not fuel and not spark. It's either starter solenoid, anti-theft system, blown fuse or bad relay, or possibly a loose ground wire or loose positive cable connection at the starter.
Felipe: check all fuses and relays related to the starter. See if any of the fuses are blown and try swapping the starter relay with an identical relay that does something else for the car. Make sure the OBC, alarm remote, and climate control system can turn on and off--if all 3 of those are out, it's likely it's that common fuse (#30 or #31 I think).
If you suspect starter solenoid is failing, one option is have someone bang on the starter with a breaker bar or prybar while you try to start the car. If banging on starter solenoid lets you start the car, then time to replace the starter.
Thanks so much for this tip ! Changing fuse 31 with OBC and Climate control not working solved my start issue
its crazy that BMW puts all this thru the same circuit. EWS should have its own fuse.
i blew fuse 31 again by putting blower motor on high
when not in heat mode. Putting heat on didnt blow it So i got some work to do figuring this out.
hi i have very same problem with my one every thing working but not cranking i check all fuse starter is good and pump not working
OBC fuse (#46) was my issue as well. (95 M3) One of the few that supplies the OBC... car fired immediately.
Dakar 95 M3 (4/95 manufacture)
Techno Violet 97 M3 (12/96 manufacture)
Alpine White 16 535i M-Sport (10/15 manufacture)
_________________________________
"I have no idols. I admire work, dedication and competence." -- A. Senna
Illegitimus Non Tatum Carborundum
Im dealing with this issue too. I thought my starter was bad since it wasnt spinning or anything but im getting enough power and even with a jump it wouldn't spin the starter and I just replaced it with a Bosch one but im still having the same issue. Any suggestions? Mine is a 93 325i. OBD1.
did you ever figure it out?
Does my car even have a starter relay? It's a 93 325i OBD1. I've been looking everywhere and can't find a starter relay. Im getting good voltage at the ignition switch, and the starter solenoid, the battery is fine. Just replaced the starter but still can't figure out the issue with no cranking.
Look at the ETM, don't waste your time guessing. google "WEDO BMW ETM" and pick the exact production year.
'94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
'93 325is Coupe, Schwarz, work beater 299k
'89 325i Vert, Alpine White: 5spd swapped. Sold
'04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
'05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
'85 Toyota LandCruiser: Lifted, gas hog. 205k
1995 e36 325i. Ran fine sat for 3 weeks tried to start nothing. No crank and makes a ticking noise from fuse box. Will push start can anyone help me
My 1997 328i has a similar issue except mine turns on the fuel pump an all the lights work as normal but still no crank from the starter, I removed the starter an tested it and it works perfectly fine all wiring connected to the starter seemed fine an all fuses have been checked and there okay so does anyone have advice?
I’m having the similar problem with my 97 328is. My car starts most of the time but that’s not good enough. I’ve not removed the starter because it looks like a pain so I began inside the car. First, I jumped the clutch switch with a small piece of wire in the connector. That rules out the switch and lets me try to start it from the passenger side. Next, I removed the glovebox to gain access to the ews2 module. I stuck a couple of test lights on the large wires. During an attempt to start, I have power coming in to ews2 on the black/green wire but it’s not going out (black/yellow)to the starter solenoid. This means ews2 is causing my no-crank,no-start and probably yours too. However, I’m not sure what to do now. It could be a faulty key, the ring antenna, or the ews2 module itself. There is so much weird stuff that has to happen for ews2 to allow the car to start. I could jump the two wires at the ews2 connector but I’ve read it kills spark also, resulting in a crank,no-start. These cars are +20 years old now and theft is not a huge concern so doesn’t someone have a solution to “hotwire” this darn thing?
