My lease was up and I have a set of used (look new) tail lights that will retrofit your older '07 '08 and '09 E92 coupe (and M3) to the new LCI tail lights that are seen on current model 3 series coupes. They really change the look of the car! The kit includes the lights (inner and outter with all bulbs) and the wiring retrofit harness. Everything you will need to change them out. Note that you will need to get your car reprogrammed to remove the error codes. This can be done at a place in orange county and there are other places across the country that will do it. Takes about 30 minutes. The lights can be installed very easily, only a few bolts for each one.
Email me at: darrenm405@gmail.com -- These will go fast! Thanks!
