Ok here I go, Like two moths ago I was racing with another M3 from stop and when I punched it in first gear my tires started to spin like crazy so in order to get traction I used the clutch and gas at the same time after that I changed to 2gear and I notice that my RPM's when all the way up to 6.5k and stayed there while the car accelerate (like if you are release your clutch slowly). After that day if I drive w/o racing everything works perfect but if I want to race and change gears really fast my M does the same thing that back in that race: . Before all this happened my tires spin every gear but now they don't
So I don't know if my clutch or my slave cylinder is F$%#@
Any ideas...........
BTW my M has 60k
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Your clutch is slipping, you need a new one.
There is any write up of how to change the clutch out there so I can do it myself?
Bumps!
I have done my M50 manifold conversion, cranck pulley, UUC exhaust, UUC SSK and clutch stop myself so do you guys think I can change my clutch myself?
You need a new clutch buddy.
youll nees some helping hands and you need the proper equipment to be able to get the tranny off and back on.
94 325is- telephone pole
98 3238is- sold
now- 88 944 turbo, in endless state of disrepair
what equipment do i need for this......I have air tools, jack stands , a big garage and a ton of friends to help me out.
youll need an engine support or a crane jack, a floor jack, and a lift or jackstands.
and id highly advise investing in a bently manual before you do this, they run about $55, youll thank me if you get one. it tells you how to do just about anything on your car.
98 3238is- sold
Cool!
Thanks for your help!
a clutch isn't that hard, but is a PITA on jack stands. Scho and I did his. You will need some torex sockets, a 30" extension. Other that its not hard. Drop the center exhaust section, undo the shifter, driveshaft, center bearing, then the tranny, clutch. It took us a while to do it, one day, then part of another, but thats not working all the time.
Sean
That is what I wanted to know. I have the extension but I don't have torex sockets........what is a torex socket?
its that star shaped screw head, instead of phillips head that looks like an X it looks like a star. they make them like screw drivers and like socket wrench attatchments
98 3238is- sold
oh........any special size for the clutch installation so I can buy it?
not sure on what bit sizes youll need but go ahead and ge a set of them b/c if you keep working on your car yourself believe me youll need them, those torx scews are everywhere.
98 3238is- sold
No need for a engine hoist. At most you may need to tilt the engine back a bit. A second jack at the front of the engine will do the job. As for the torx sockets, go ahead and buy a whole set T5-T45 or so. They will come in handy in other places.
If I am not mistaken the torx sockets you speak of for the tranny bolts are reversed torx sockets. The tranny bolts have the torx heads, and the the SOCKET set is female torx.
Also, I cannot think of one bolt on my car that needs a standard torx socket. You use the reverse torx on the DME also(small). All the bolts on my car, are allen, metric or reverse torx.
2008 335I Space Grey,Black leather, Steptronic
Vishnu Procede V3 (16-17 lb boost) ,AA FMIC,AA Discharge tube/BOV,AA Downpipes,AA Race Exhaust, AFE Elite intake,BSH catch can, OS Giken LSD, PSS10 suspension, H&R sway bars, Motorsport CF strut brace, Stoptech BBKS, Forgeline ZX3S 19 x 8.5 front and 19 x 9.5 rears w/P235 35 19 fronts and P275 30 19 rear Conti Extreme DW's,Motorsport alcantara digital steering wheel, P3 boost gauge..etc
2011 X3 X-Drive 35i, Mineral Silver, Oyster leather
Hartge Power Pack tuner, H&R sport springs, Forgeline DE3S 19 x 9 Conti Extreme DW P245 45 19 all around, Supersprint Exhaust
AA Preferred Dealer
I have to agree with HoJo here, that set of tools will be very handy with many driveline parts on your car. I can personally vouch from doing diff installs.
for everyone else reading this thread either archived or not, that's the classic example of a fried clutch.
-Ron
Hey man, I'm a professional!
That set of tools may be handy, but a regular set of torx sockets is not going to get his transmission out.Or his axles for that matter.He needs reverse torx.
AA Preferred Dealer
I'm gonna buy a set of torx sockets and clutch kit today.......any other part to buy that I'm gonna have to change after taking off the tranny?
Reverse torx, right? Hollow head not protruding head sockets.
AA Preferred Dealer
I'm gonna buy both sets.
correct - the Female torx sockets.Originally posted by marc1119
