Page 1 of 40 123456789101126 ... LastLast
Results 1 to 25 of 976
Thread: Starting my swap...
    May 2010
    Salem, OR
    2000 BMW 528
    Starting my swap...
    Well, my head gasket and my transmission took a crap in my 528... With almost 200k on the clock, not a shocker.
    So I'll be swapping in an ls3 from here (already purchased): http://www.crateenginedepot.com/stor...P2218C509.aspx
    This transmission: http://www.monstertrans.com/store/pr...tml?fullSite=1
    And an M5 rear diff and one piece custom driveshaft.
    I'll be making the exhaust and mounts myself.
    But my biggest problem is getting all the new stuff to work with the cluster and all that. I got a stand alone ECU and TCU but I'll be needing help with wiring and programming of modules.
    If anyone could help when I get there or put up some links with good info I'd appreciate it... I'm sure I'll have lots of questions along the way.
    I'll be starting the teardown soon...
    Texas
    '04 Porsche CTT
    Damn, that should be a great set up. What stand alone are you running for the engine and trans?
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by sid33 View Post
    Just a regular GM performance parts ECU: http://www.crateenginedepot.com/stor...7-P2221C0.aspx
    And TCU: http://www.monstertrans.com/store/pr...ol-System.html
    Dallas, Ga 30132
    97M3.4.5,EG,YZF
    Talk about awesome potential. There are several E36 LS swaps in Oregon, I'm sure they'll chime in. Looking forward to seeing this develop, take lots of pics!
    Apr 2009
    san diego
    2003 530i
    Nice!! takes lots of pictures!! one thing though, that engine is pretty pricey. you could've built up a motor for less but your setup is gonna be killer
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by smkocheran View Post
    Actually, for a used ls3 with 30k miles was about $1000 less... So I decided on a new one.
    Apr 2009
    san diego
    2003 530i
    dude car-part listed a couple LS3(under $8)..one of which is $4200 with 7,500 miles
    Naperville, IL
    1998 540i
    I am sure that engine is in excellent condition
    OP - the whole swap shouldn't cost more than $1k if you know what you are doing.
    Rob
    Prior projects:
    1998 540i with 6.6 LS2/T56 Chevy Power
    - pictures and details
    1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
    1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
    Columbus, OH
    1998 M3/4/5
    2000 528iA Sport. I want to do the same swap (auto trans).
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by rao View Post
    Engine and all?! Engine and auto transmissions are things I don't like to buy used, especially site un seen and from a junk yard... to many variables that cause serious damage to internals.
    Quote Originally Posted by 82bmw633 View Post
    I'll try and document as much as I can...
    Naperville, IL
    1998 540i
    Engine, transmission and donor car.
    Is your budget higher?
    Rob
    Prior projects:
    florida
    xx,xx,xx
    i wanna see this
    -tony
    May 2010
    Salem, OR
    2000 BMW 528
    My budget is about 15-16k engine, tans, misc...
    I'm gonna try and part out my engine to recover a few pennies..
    My budget is pretty high, I know, but I don't plan on ever getting rid of this car, and I'm going to have it insured for more than what I have into it.
    Minneapolis,MN
    2003 M5, 2014 535i
    E39 + LSx = match made in heaven. However I have heard Turbo M50 is better.
    Good luck with the swap
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by Schitzo View Post
    Thanks schitzo, I've read yours and rao's treads about 10 times each.... I'm sure I'll still have questions tho.
    Elizabethtown, PA
    99 540i6
    If you check my thread, I pretty much detail how to recode the cluster and what you need to do it.
    I also go into how I went about tying the GM harness into what little is needed to/from the bmw to make it run.
    We need an e39 swap club!!!
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by James39 View Post
    Yah, your thread has been the most helpful as far as wiring... I've got a few ideas on how to do it.
    A swap club would be sick... I think bimmerfest would be the best time and place to meet up... But it's a long drive for everyone.
    May 2010
    Salem, OR
    2000 BMW 528
    So... The ls3 can communicate over a CAN bus, can this be adapted to the existing BMW can bus? Instead of converting both the PCM and cluster to use analog signals, could I make them communicate over the CAN bus?
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by Jesus Freak View Post
    Unfortunately not.
    Even though both GM and BMW use Can-Bus for communication between modules, the CAN-IDs used for the various messages are different meaning a BMW module cannot understand a message sent over CAN-BUS from a GM module.
    The key to figuring out CAN-BUS systems will be to crack or acquire .DBC files used by the various auto makers. Such a file would contain all the information describing the respective CAN-BUS network, message IDs, their priorities etc.
    Build Thread
    Apr 2009
    san diego
    2003 530i
    Isn't their a way to just scan the bmw CAN-BUS system and datalog the information?
    May 2010
    Salem, OR
    2000 BMW 528
    Unfortunately not.
    Figured it was a long shot, thanks tho.
    Another thing, could I make my own cluster of whatever guages and not have issues elsewhere in the car? (i.e. lcm)
    Or should I just stick with the stock cluster and convert everything to analog?
    Minneapolis,MN
    2003 M5, 2014 535i
    Stick with your cluster. The only thing that needs to be converted to analog is your tach and coolant temp. It will not cause issues elsewhere.
    Build Thread
    May 2010
    Salem, OR
    2000 BMW 528
    Thanks again for your help. I know I'm a ways away from dealing with this, but I want to be as prepared as possible.
    Elizabethtown, PA
    99 540i6
    If you're anal like me, switch over your MPG gauge to analog also
    I maxed it out in the cluster function at 1250 and it's still about 8% or so off. I will fix that someday too.
    Minneapolis,MN
    2003 M5, 2014 535i
    ^^^Did you wire it to an injector signal wire? I didnt feel comfortable doing that.
    Build Thread
