Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 83
Thread: LS1 swap on the cheap
  1. #51
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Correct, but if someone wanted to dive into the ETM they could see if the signals are the same, and then that's one less thing to fab up.
  2. #52
    houston
    1998 328i
    The abs lines are barely in the way of the headers as far as i can tell. I can get away with bending the lines back a little bit to make more room. The booster is already cleared with a slight offset, so all I am going to have to do is build headers to clear the steering shaft! Wahoo!!!!! this is exciting i just cant believe how good this engine and transmission fit into this car with the 99 fbody oil pan i have great clearance from the crossmember, it literally looks stock!
  3. #53
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
  4. #54
    Nov 2009
    Auburn, GA
    Chevy, xBMW's, LS Volvo
    Quote Originally Posted by Pzary3233 View Post
    I know the master cylinders are the same between an OBD1 318 and a 325. However, I'd be willing to bet that the ABS controller is different too. They're different for a reason, it's not something I'd be comfortable modifying without having a VERY good understanding of how the system works,a nd WHY they're different between the different models. Perhaps somebody here is familiar with those, but the ABS system is not something I'd be advocating to people reading this as ok to be playing with.
  5. #55
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    I guess it depends on what your skill level is as far as electronics. Would I adapt and go? Nope, I'd have to send it to an electrical engineer friend. but alas, just an observation.
  6. #56
    houston
    1998 328i
    Well good afternoon fellas. I am no longer going to build custom headers from a kit and im going to use the Sanderson CC1LS1 and cut the drivers side up. So will the regular set work (with some cutting) or do i need to mix and match them the way Steve Van s did on his e30. E36Ls1 could you explain exactly what you did to the drivers side as far as where did you cut the flange and just more details of what was done to make it work. Thanks.
  7. #57
    Calgary
    E36
    Kenndoggy pretty much sums up how I did the header. Except with the E36, you need to flatten the elbow a bit where the steering shaft is. Make sure the elbow hugs the block. You won't be able to use a flared out oil pan.
    1997 318i
    1997 Corvette LS1
    4L80E
  8. #58
    Nov 2009
    Auburn, GA
    Quote Originally Posted by LS1 E36 View Post
    So there is room to use block-huggers on the E36?
  9. #59
    Jun 2005
    Portland, Oregon
    04 Allroad, F20c Lotus 7
    Quote Originally Posted by kenndoggy View Post
    only on the passenger side, not at all on the drivers side
  10. #60
    Jun 2006
    croatia
    BMW m3 e36 1994
    Question about ABS and brakes. Is it physical relocation abs module and extending connector wires for abs pump only job for abs system to work properly? Is it needed any rewiring to ls pcm or something else?
  11. #61
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Relocate, extend wires, extend lines, then you are done.
  12. #62
    Jun 2006
    croatia
    BMW m3 e36 1994
    thanks
  13. #63
    houston
    1998 328i
    Foler are you building a ls1 m3? Where are you at in TX. Im in Houston.
  14. #64
    Jun 2006
    croatia
    BMW m3 e36 1994
    no no, I will be swap ls376/525 into e36. I will in future travel to ohio and tx for parts. i am from europe.
    before 2 hours i pay for my first part: http://www.ebay.com/itm/Swap-Gm-LS-S...#ht_500wt_1156
  15. #65
    houston
    1998 328i
    O I see, well cool good luck to ya. Does anyone know of an adapter i can but to connect the t56 clutch line to the bmw MC.
  16. #66
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Depending on the style of master cyl you have....
    I've got a braap modified line that will not work for me. It may work on your 98. I am pretty sure that is what Braap has as well.
    Otherwise you've got a few other options.
  17. #67
    houston
    1998 328i
    So it will connect the t56 clutch line to the e36 MC. How much do you want for it. Do i need anything else to make the connection or is it complete.
  18. #68
    Jun 2004
    PA
    Too many to list...
    Good thread here. I too would like to see more info on the block huggers and how they are modified.
    Doug
    '97 M3/4
  19. #69
    houston
    1998 328i
    UPDATE its getting closer and closer!!!!! I've got my high pressure PS line adapted to the ls1 powersteering. I also took my T56 clutch line cut and had it adapted to the bmw m10 fitting. This was all done at a hydraulic shop down the street. My total for both PS and clutch came out to $24.00.
  20. #70
    Upper Saddle River NJ
    MZ3, YUK DEN, FORESTERXT
    ABS 4 pump 2000 Z3
    I am trolling ever thread i can find to find some clarification on th 4 pump abs unit....can anyone comment on whether it works the sames as the 3 pump....and all I have to do is extend the lines and wires to the passenger side?
    I do not have a DME anymore...REAL OEM shows a separate control unit..but that does not help.
    I am not using AST / DSC ...just the abs.
    help a guy out here...I m starting thinl about just buying a vette again LOL
    PS- some good exchange on this thread!
    00 MZ3 with LS2 /T56 swap (425rwhp/404Torq corrected to SAE), with oil cooler and 3 qt accusump, TCK DA, , 1.75 in Vorshlag Headers, RD Sways, Dinan Upper Strut, Turner Brake Cooling with Stainless Lines, DTC90 Pads, Fidanza LTW Fly Wheel and LS7 clutch and pressure plate, Hurst Shifter Hamann Kit, Digi tec Wing, Full grand am style cage from Deman MotorSports, New Age radiator, Lower temp alum thermostat, center 75d FCAB, Rear Camber and Toe plates, AKG 75d bushings throughout , SLR Roll Center / Bump Steer Correction kit, Turn one power steering pump and cooler, Rogue Rear Strut mounts, TCK Camber Plates, 18x10.5 wheels with Hoosier R6, Rogue Dual-Ear diff, Randy Forbe Reinforced Diff Mounts, adjustable sway bar end links, 500/700 springs, Custom Advanced Motorsports carbon fiber hood, carbon fiber roof, bumper cover, splitter and Dive Planes, Pole Position, lexan Windows, PBR C6 z 6 piston calipers with C6z rotors,custom dual master cylinder pedal box...
  21. #71
    Mar 2011
    Dallas, TX
    2008 535i
    extend the wires and extend the brake lines and you are set. Make sure to jumper the old ASC throttle actuator with a resistor or it won't work.
  22. #72
    Mar 2004
    USA
    96 328is 6.0L
    Not sure if your z ABSos different, but my 96 328 4 channel ABS just worked fine. All I did is relocated it, extended wires and lines.
    Quote Originally Posted by Kaane View Post
    Or just leave the original solenoid plugged in.
  23. #73
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Also there is an abs ecu under the dash not in the original sms.
  24. #74
    Mar 2012
    louisville, ky
    1986 RX7 GXL + 5.3L LM7
    Yes, you should be skeptical on the driveshaft. It vibrates due to it being out of phase. Too bad as it was the right length and diameter. I'm going to upgrade to one with a cv at the trans. I've already grabbed one from, you guessed it - the junk yard! But I'll have to get it properly tubed and balanced, so that will be $200-300.
    Do you think that this was due to the particular driveshaft you had, or would all ranger driveshafts vibrate? Are you thinking it's because of the CV on the differential side?
  25. #75
    Calgary
    E36
    The trans slopes down about 6 degrees relative to the diff. It vibrated because the Ranger shaft doesn't have cv's.
    My new shaft, which goes on today, has a double cardan cv at the trans and a single ujoint at the diff (which is straight on).
    1997 318i
    1997 Corvette LS1
    4L80E
