I've only done a dozen or so cars, some American, some Euro, but all certainly OBDII. I only have the connector for OBDII setup.
My question relates to the ones I've done vs. my MZ3 because I've never messed with the M by resetting it on the way to an emission check. I am trying to get setup to run catless for the track w/out installing EOL termination resistors for the O2 sensors and wondered how it would potentially effect my emissions check. Most people here restore their setups a day or so prior to inspection, clear fault lights, and pass with out issue and then go back to catless again. So to answer your question; my "knowledge" is the cars I've done. My "inquisitiveness" is for the ones I want to do.
The automotive folks for Ford have chimed in on other forums with the formulas/logic tables and number of cycles that their computers require to both start registering data as well as trigger the next CEL. I would like to have this data for BMW.
97
Agree wholeheartedly..
missed this reply in my last response - I have gathered the same understanding from other manufacturers. The cycles can sometimes be up to the last 80 averaged start and stop engine cycles before the next DTC/MIL CEL trigger. (nvm.. automerge FTW)
F/I'd Silver/Black MCp
(All your ///MCoupe are belong to us..)
Well... all 98+ OBD II cars shouldn't get away with resetting codes before an emissions check. I didn't even know that was possible with any OBD II cars, and to clarify, that's not what I did here. I just cleared a code back in June and haven't seen it since.
It was a faulty cat code which seemed odd for a car with 20k miles. If it comes back, I'll replace the cats.
From what I understand of these cars, if you can't connect to the computer at the emissions station then you need to perform the recall again.
Why don't you want to run resistors (O2 simulators)? Or just set the O2 monitor to permanent readiness in a tune? I ran simulators on the LS1 until it was tuned with HP Tuners.
To answer your question, if you don't run them you will have no chance of passing an emissions check. And it seems like a total waste of your time to swap the exhaust and cycle the computer just for a one day emissions check.
No hard number but they say "an hour of normal driving"
Whatever that means.
Good info, and see your point. I live in the only county in the state that runs emission checks and I do it on a 2yr cycle... cumbersome but doable.
Update - passed inspection today
I'm having a very similar issue with a 2003 M3 SMG convertible. I took my it to the dealership to have an emissions recall completed (SI B12 22 08). They tried a number of times/ways but are unable to get the M3 to communicate. They have tried various diagnostic tools, but can't get a response. Service manager says they don't know how it's even running (or why it runs so well). Coincidentally, I've never been able to communicate with my own diagnostic tools outside of a cheap little hand scanner. Is the DME "flashable" even though there's no communication?
Thanks!
I had the same issue. This is a recall and you need to have your DME flashed with updated software. Go back to the dealership and have them pull the records. Even if they say it's been flashed ask them to perform the recall again, that's what I went through at the stealership. Read through this thread.
Also read this:
Actually, they say the recall/update has never been applied. Just wondering if it's still "flashable" even though they can't get it t communicate.
Thanks!
Yes it's 100% possible. It is communicating, just not sending emissions back to the computer. The old software leaves 2 pins disabled in the diagnostic port. The flash corrects this.Originally Posted by icm3
Well, they figured it out. Both the steering angle sensor and left headlight control unit were preventing the vehicle bus from communicating. Nothing $1400 won't fix. They are completing the recall now that the car is communicating.
Sounds like BS.
They tried to do the same thing to me except my bill would have been $3000.
By the way they made me pay for the recall work to be done. I bet they didn't even file the paperwork for the recall.
If I were you I'd bring it to another dealer and tell them you want the recall done and nothing else. See what they say.
The steering angle sensor is legitimate. I've had issues on and off with the DSC, brake and SMG lights coming on. As for the headlight control unit, I can get one cheap enough and it's an easy enough installation that I'll do it myself. Don't really want to touch the steering angle sensor though.
Let me get this straight. You asked the dealer to flash the DME but they fooled around doing other things that did not fix the problem. Then charged you two hours for the 5 minute process you asked for in the first place. I think I would be standing on top the the service managers desk peeing all over him.
Dan "PbFut" Rose
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
I did speak to BMW corporate. It is what it is. I'm just happy that I'll be able to connect to the car with my diagnostic setup now. Thanks for all of the ideas/replies.
BMW NA is useless. I called them when the dealer did this to me and they said there's nothing they can do about it.
Long story short is an educated owner is the BMW service department's worst nightmare, because they can't gouge you for power steering lines and tires and ball joints and sensors and other shit you probably don't need.
Luckily I caught them before they had the chance to do all of that work (to the tune of $3300 - my car has 23k on the clock and truly has none of those things wrong with it), and told them do NOT touch the car in any way except for flashing the DME.
I followed up with the dealer and they said I wouldn't be getting my refund. Not to mention they damaged two of my wheels, kept my fuse box cover and knocked one of my M badges off. I was LIVID. Oh yeah and they locked out my radio, and gave me incorrect security codes for 2 weeks.
Got them to agree to repair one of the wheels which I'll be doing soon. If that doesn't go smoothly I'll be following up with BMW NA for what it's worth and I'll smear their name all over the BMW community.
Please PM me the dealer,as I work for one.
If you pay for service at a dealership with plastic you can then contest it if they do work you did not want or need. Had a carb kit put in a car one time and I drove down the road about one mile and it started spewing white smoke. I never figured out how the mechanic blew my head gasket but my CC company took me seriously and never paid them. I did have the expense of a new head gasket though.
-Marshall
I have a dumb question and not sure if this is related. I just bought a 1995 325i and needed to get a smog certificate to complete title transfer. While driving the car a check engine light came on and the little battery symbol was appearing in the dash. I had to take it to a test only center. The car failed. The guy said he looked the other way regarding the check engine light and it failed on the emissions test. The car died on my way home and I believe my alternator is bad. Would this in any way be related to my failed smog. Here are the numbers from the smog test
HC(PPM)
(MAX)85 - Measured - 134
CO(%)
(MAX) .34 - Measured .86
This is not related to the problem I had with the DME.
But yes it's possible. Did you pull the codes that threw the CEL? You could have a low voltage code if the alternator was on its way out. Not exactly sure if or how that would cause a smog issue but there are really dozens of possibilities. Low voltage to O2's or mass air for example.
No I don't have a scanner to pull codes. I removed the battery and put a different one in and the check engine light went away. I am going to have the alternator situation taken care of first and see if that resolves the smog issue. Thanks for the reply.
Replaced the alternator and it passed smog. Thank you for your assistance. Now to fix the reclining seat gear. LOL
I have a 2000 540I and i'm having a hard time getting it smog. I change my speedometer about 2 yrs ago and notice that my on board computer wasn't working. then I knew that guy from ebay sold me the wrong year. always just recently my speedometer and radio shut down at the same time and it never came back on again. I'm trying to get the car smog but they cannot get a connection from my ECU. I took it to the shop and they cannot figure out why it's not getting power. I can't get any codes at all. Please help.
