With A/C off its around 500rpm and with A/C on it goes to around 700-750 rpm. These are the values from the OBC test no. 7 IIRC.
When coming to a gradual stop, it goes to about 300rpm and then "catches itself" and bounces up again. In the proces, the downshift suffers (and me ofcourse).
ok, heres my board. definitely an update/completely different.
lol @ the black crap over to "hide" whats going on(its hard as a rock/wont easily come off). I didnt give it a super good look over but there was nothing i could quickly figure out
because it is so different. i jumpered the 7 and 8 anyways and it didnt change the function.
as you can see on one side its got those jumper connections already...hrmm
I get the zke, ike errors. It reads the dme and srs just fine but cant access the abs computer.
I am running a 20 pin adapter and it seems to be wired correctly though ill have to reconfirm. (seemed like it was wired properly to pin 15 and since it connects to dme
already I think thats fine)
edit: this may be my problem since I think pin 16 is unused on my 20 pin adapter. installing a jumper on this
cable may be my answer.
hrmmm.
edit: sorry about size.
bought mine from xcar360
found this
http://www.ebay.ca/itm/INPA-K-DCAN-I...#ht_1584wt_952
looks like the same unit... wonder if mine is a kcan modified to work with bmw scanner(likely)...now I just have to figure out how to change it /run inpa instead
edit: can i jump pin 15 (L line) with 7 and 8?
would that work?
hi; you can change idle speed in dis ; as i can recall; function selection; dme; idle speed; test plan ....
is this same as pasoft? can it write vin to used abs pump or used ike or dme?
[QUOTE=stef168;23711005]hi; you can change idle speed in dis ; as i can recall; function selection; dme; idle speed; test plan ....
Thanks, I'll try DIS as soon as my interface cable arrives
now will this worn on OBD1 cars?? i have a SRS and ABS lights on, need to find whats the problem and fix it.
this is same as pasoft and can be updated at their web site.
this software will not recode abs/dsc on my 2002 330ci...unfortunate because thats all i need it for besides code reading
it will code the ike and dme.....its strange it covers all module except the asb/dsc. Will have to use ncs expert or disv44 for that unless someone knows something i dont
just got my BMW Scanner today (ordered of eBay for $60) and had those "connection error with IKE" blah blah and after a little searching came across this thread...
opened up my scanner to solder pins 7 & 8 together and they already were.... looked at the picture again on the first post and noticed pins 1 and 2 were soldered but mine weren't!
So soldered pins 1 & 2 and boom... worked like a charm
moral of the post... Make sure pins 1 & 2 are soldered along with pins 7 & 8 solder together. Just thought i'd post this as a heads up.
My Previous Vehicle - In the Edmonton/Northern AB Area? We're having a meet... Click Here
What is the round adapter you are using? I have the BMW scanner and it works fine on my '01 but I need to access more on a '00 that has the round plug.
'05 545i 6spd manual, Sport pkg, CW pkg, Alpine White w/Auburn interior
'01 325i Sport Package, 5spd, Alpine white, Xenons -sold!
'93 Mustang LX 5.0, 5spd, Vortech Si-Trim, etc. 11.91@123.5 - 5+ yr old street tires
Not a hijack, but on a tangent: what are people's experience with xcar360's scanner for programming functions? I'd like to get one touch close on my coupe's rear windows, my halogens to come on full when I use my Xenon high beams, and get rid of my damned 37 degree beep. Does anyone know whether this product can make these changes?
So this unit will tell me what is throwing the "check engine" light instead of having to look up the codes? (sorry if it sounds like a stupid question, but this is my first day looking into this stuff and I'm sick of getting raped by the dealer getting told "it was just a program error" and paying them to reset the light.)
The Ultimate Driving Machine.
i got mine last week and having trouble getting the drivers to work..was given a link to download updated drivers for xp but im having a heck of a time figuring it out..anyone else have this issue
i had to go into control panel...then device drivers.....then browse computer for device drivers in the C: drive from device drivers.....for windows 7 32bit
once it found the software it downloaded it with no issues
well i finally got drivers installed..unfortunately i can only perform first 2 options...looks like ill be soldering this weekend
How do you erase adaptations?
///M* Coming soon..
I cleaned/ changed the MAF and no vac leaks.
I did however take the car to A friend who, using and old version of DIS, managed to increase my idle speed by 100 rpm. The hard downshift is almost completely gone. I think i'll raise it another 50rpm to bring it up to about 700rpm. That will be perfect.
Thanks for all the help though.
Btw, I did receive my PA soft today. I hope I dont have any problems setting it up.
I see that is an old thread but i just bought an BMW scanner 1.4.Managed to install drivers and get it to work but when i connect to OBD2 it will only see 2 modules.DME and EGS.Tryed to bridge pin 7-8 but nothing happens.I read somewhere that on E39 modells with booth obd connectors i have to use the round conn under the hood.So ordered an adapter obd2(16 pin) to obd1(the round connection 20 pin) I have to know if i have to make any changes to BMW scanner or it will just work with the adaptor without having to bridge the 7-8 pin?
@tim8dena I have exact same problem as you.I have to keep all the time AC working in order to not get that shock each time when i have to stop.Did you fixed this issue?Ho
Ok,thank you for the reply.I managed to test the DME and got this errors
8C/01 - Activation, map cooling
22/01 - Function, inlet-camshaft control, bank 2
21/01 - Function, inlet-camshaft control, bank 1
0D/00 - Oxygen-sensor heater before cat. conv., bank 1
I did a clear and
returned after a while with engine started.What does that means?I have to replace the vanos sensors?The car works perfectly....
