E39 DIYs done: Wipers, O2 sensors , MAF , Upper/Lower Intake Boots , FSU , ABS module fix , Power Steering Reservoir , Changed Rear Differential Oil , DISA , SAP, Vacuum lines , Radar Detector Hardwire , Fuel Filter , LED Angel Eyes , Headlight Adjusters--> [1],[2], [3] , Headlight Polishing, Punted: Fan Clutch/Tensioner/Pulleys , Oil cap O-rings , Window regulator ,Crumbling Cowl
Easy-peazy. FYI, The Bosch sensor comes with compound on the threads.
I didn't remove anything but the sensor. The special O2 socket and a 6" extension for my 3/8 driver is all I needed. Close fit, but no problems.
Great write up! I recorded a DIY video for this job as well, in case it helps anyone out:
https://bimmerzeit.com/2016/04/21/m5...placement-diy/
I don't think it is necessary to remove the plastic clips as shown early on. The O2 sensors just plug in to the other end. You just pull them out.
Also, I do recommend removing the passenger side cabin air filter to get more room for the Bank 2 sensor near the firewall.
But overall, this was an easy job. $105 in parts and about 45 minutes. Much better than the $495 I was charged by a dealer.
Nice video. Well done.
See the DIY video guide here:
