Results 1 to 25 of 59
Thread: Just Another 95 M3 Turbo Build Thread
    Joliet, IL
    Out of Service
    Thought it was about time to introduce my build since I actually started the car up last night (Still gotta install the rims and finish up some misc wiring and then she will be ready to drive). Below are the details of my build. The car is a silver on black 1995 M3.
    OBDI S52 (Rebuilt Cylinder Head w/ Mild PP)
    Cometic 0.140" HG
    ARP 2000 Studs
    Besian Vanos Rebuild Kit
    TRM Walbro Kit
    TRM Siemens Deka 60# Injectors
    TRM Blow Thru MAF
    TRM Tune
    TRM Motor Mount
    CXRacing 2.5" Intercooler Piping Kit
    CXRacing 3.0" Intercooler Piping Kit
    CXRacing 24"x12"x3" Intercooler
    Garrett GT3582R (T3 .82 AR 3” GT V-band w/ Tial 0.70 AR Ported Comp Housing)
    SPA T3 Manifold (Ported WG Port to 38mm)
    MaxPSI Oil Feed Kit
    MaxPSI Oil Drain Kit
    MaxPSI Water Cooling Kit
    CES 90 Degree TB Elbow
    RC Big Bore TB
    Prosport Boost Gauge
    PLX Wideband
    RallyRoad Steering Column Gauge Pod
    RallyRoad Oil Pump Nut w/ Safety Wire
    AMS-500
    ATPTurbo Vacuum Routing
    TMS Oil Pan Baffle’s
    TIAL MVS
    Synapse BOV
    Crank Case Evac Setup (Napa Check Valve, 5/8 Hose, Vibrant evac fitting, and AN push lok fittings)
    Clutchnet Red 2x PP and High Performance Organic Disk
    Active Autowerke Diff Support Bracket
    3" Full Exhaust w/ Magnaflow Muffler, Vibrant Ultra Quiet Resonator and Vibrant Quick Release V-bands
    16” Low Profile Mishimoto Curved Blade Puller Fan w/ Aluminum Fan Shroud
    Fluidyne Radiator
    Misc/Maintenance:
    e21 Trans Mounts w/ UUC Enforcers
    AKG Motor Mounts
    UUC Stainless Steel Clutch Slave Line
    Euro Expansion Tank
    New OEM Clutch Slave
    New OEM Master cylinder
    New OEM Fuel Filter
    UUC Under Drive Pulleys w/ New Belt
    NGK 4644 Plugs (Gapped to 0.024”)
    New OEM Rear Suspension Bushings and Bearings
    AKG RTAB Pockets and Front Subframe Reinforcements
    TMS Rear Sway Bar Tab Reinforcements
    TMS RTAB Limiters
    New OEM FCA, FCAB’s, and Tie Rods
    New Top and Bottom End Gaskets (Including Rear Main Seal)
    AutoPower Street Sport 4 Point Roll Bar
    Schroth Quick Fit Four Point E36 Harnesses
    Koni Threaded Coilovers
    Sparco Evo L Seats
    UUC Evo 2 SSK w/ All New Shifter Bushings and Clips
    Momo Shift Knob
    Momo Millenium Steering Wheel
    AC Schnitzer 3 Piece Spoiler
    SSR GT2 18x8.5 and 18x9
    +More
    The day she arrived
    Rear Suspension Overhaul
    Head back from the machine shop
    Block prepped w/ honing stones and ARP’s installed
    The Goods
    Vanos Rebuild
    Head going back on (32 ft-lb + 90 + 90)
    TRM Walbro Kit (Install was breeze with the machined bracket that guaranteed the correct filter depth)
    Mishimoto setup on the Fluidyne radiator. Took a little trimming, but the finish is great.
    Clutch installed and turbo bolted up
    Motor back where she belongs
    Still haven’t gotten the rest of the pictures off my camera, but more to come.
    Space
    Space
    NY
    skateboard
    Do like. Good to see her coming along. Another silver beast ready to hit the streets.
    ― George Orwell
    Joliet, IL
    Out of Service
    Quote Originally Posted by GG///M3 View Post
    I think I should be in the neighborhood of 450-500whp and can't wait to hit the streets. Only down side is I started her last night, but will be out of town for two weeks. So I can't wait to get back and take to the streets.
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    bada$$!!!!!!!!!
    So CXracing sells some PREfit piping pieces?
    That list looks very well sorted man.
    NICE, very.
    Congrats.
    Joliet, IL
    Out of Service
    Quote Originally Posted by milKt View Post
    bada$$!!!!!!!!!
    NICE, very.
    Congrats.
    I wish. No I just bought a 3" and 2.5" kit since it came with a slew of couplers and t-bolt clamps along with the piping. I had to cut it all up and mock everything up (ended up with pretty much a mirror image of the TRM piping).
    Thanks for the compliments. My goal for the project was to build a reliable setup and use good quality parts. For the most part, everything I bought was brand new. I debated building the motor, but for my goals the cost didn't seem to fit my budget ($10k including the car) nor my power goals (450-500whp). Minus all stuff I need to return or re-sell I came out at just under $11k.
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    I like the build. That Mishimoto fan shroud is pretty cool too!
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Nice GT35R system! Look forward to driving reviews and maybe a dyno.
    I'll guess you have enough piping left to sell to someone else, for another custom intercooler pipe job.
    Saskatoon, SK, Canada
    m3, gtr
    what will you be using for a coolant overflow tank?
    Louisville, KY
    turbo m3
    Nice to see it finished Ryan (IIRC that's your name. LOL)
    This is my signature....
    Mar 2010
    San Diego, CA
    93' Turbo e34, 04' Ram
    nice job!!! looks sweeeet
    TRM Turbo, Hybrid Audio Technologies stereo, S50 Cams, list goes on and on and on...
    Joliet, IL
    Out of Service
    Yea I have about half a box left of piping and couplers. I plan on hanging on to it for when this motor goes and I decided to build the motor and go top mount
    Quote Originally Posted by black bnr32 View Post
    I think I stated it in the first post, but if I didn’t I went to a euro expansion tank
    Quote Originally Posted by BadBoostedBmwM3 View Post
    You nailed it. My name is Ryan. I am so glad everything is finally back together. Once I get back in town I plan on getting the rims on and taking it for a spin. Crossing my fingers that I didn't make any mistakes that will come and bit me.
    Charlotte
    '97 Estoril M3 Turbo
    Nice, you've been planning/gathering parts for awhile now. ive seen you buy, sell, buy constantly turbo parts on here. Glad you got your right setup and will finally enjoy it! Happy boosting!
    | 1997 Estoril M3 - TURBO - |
    | GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning |
    | 46mm Precision gate| 62# injectors | Dual Walbro's |
    Goal: 600+ whp pump gas reliable 10 second car.
    -2007 335i Sport Package
    Joliet, IL
    Out of Service
    Well after getting back from working 19 days straight of 14 hour night shifts, I have finally done it. I finished up some wiring in the cabin for all the gauges which are wired off of relays, still need to mount the gauge pod to the steering wheel column. Finally got to installing the FCAB. I thought I was going to be able to muscle them on, but after getting both on just a little I gave up since I got tired of the 45 min battle. Went to autozone and got a harmonic ballancer puller, then headed to ace and got some 3/4" square tubing, 5/16" all thread, 5/16" nuts and fender washers and proceed with the tool understeer recommended. After only 5 mins, I swear, the car was back on the ground for the first time in nearly 9 months.
    Heading to the DMV right after this post to get me a set of plates, call up the insurance boys, and then heading out on the road for a first ride.
    O yea of course I am going to put on the front bumper, just gotta figure out some new routing for my brake cooling kit. And of course she needs a bath badly.
    Jan 2005
    StL, MO | LA, CA
    e36, e90
    Are you going to do the 1000 mile break in period for the engine or just going to jump on once up to temp?
    Current: 95 M3 Turbo | 08 335i
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by Eric BMW View Post
    he just did a .140 MLS. There is no break in needed.
    -Mike
    IG: @mikevanshellenbeck
    Joliet, IL
    Out of Service
    Quote Originally Posted by MikeE36 View Post
    -Mike
    ^^^This. Just got back from the first 5 mile drive. WOW . This thing is going to be scary fast. We at least for me it is considering I drove a s52 swap 325 for 5 years and I barely made 1 psi on my first drive and it felt way faster. Trying to take it easy on the new clutch, which BTW is butter smooth, but after the breakin on the clutch I have a feeling this thing is going to be amazing.
    On a side note. I had two fault codes when I first started the car, 1A and 49. Looked at the peak manual and 49 means TPS, which seems easy enough. Either the connector is loose or I need to replace it. I am having trouble figure out what the heck 1A really means. I know peak says control unit supply, but what the heck is control unit supply?
    Any help anyone can provide would be great.
    Last, this is the first time I have driven the car in close to a year and for some reason the drivers side door won't unlock with the key nor the alarm. What gives?
    Hawaii
    TT Stg2 M3, 17 S1000R
    Quote Originally Posted by cragg56 View Post
    Good stuff, have fun and NO VIDS? jk just be careful.
    '97 M3- GC Track/School|Spraco strut bar|X-brace|UUC Swaybarbarians|w/ VMC adj End links| UUC systemU|SouthBend stg5 clutch|Powerflex RTAB/LCAB|UUC Red Tranny mounts|M50mani|Greddy EBC|Innovate LC-1
    M52 Crank, Cams, Pistons, Rods:
    94 325i, 95 M3, 1997 325
    congrats man I now you need to give me a ride
    Washedit1 by thedude60526, on Flickr
    11/10's Racing
    94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
    Joliet, IL
    Out of Service
    Quote Originally Posted by stanksbeamen View Post
    No vids. Maybe later I will have some with my digi, but I don't think ill be making enough vids to get a go pro. I will for sure have to be careful. Went out for another drive after I cleared the fault codes and man it is fast. Went out on a back road and got on it a little bit, but shifted by 4500. That 35r spooled all the way up to my WG spring pressure of 8psi and it felt like the tires wanted to break loose. No more of that for a while till I get a few more miles on this clutch.
    Quote Originally Posted by thedude60126 View Post
    Thanks Ed. Once I get a few more miles on the clutch I will for sure come out to the death base or a meet. You are more than welcome to a ride.
    I still gotta get my hood on it, install the roll bar, install my Sparco Evo II's and a pair of schroth quick fits.
    Aug 2009
    Dakota County, Minnesota
    1997 BMW 328i
    milKt's Avatar
    Great Job!
    m3, gtr
    congrats on the smooth sailing thus far
    The Moon
    1995 E36 M3, 2008 E90
    That is sweeeeeet
    I am starting on mine in the next week or two. 95 M3 as well.
    I don't have a spa manifold I bought a jv 666 manifold, do I still need the trm motor bracket?
    Also, How long did it take trm to send out your parts?
    Mar 2010
    San Diego, CA
    NICE!!!! congrats on that! I am kinda going through the same thing right now and it feels amazing!
    Dec 2008
    Earth
    none
    Me three, and mine was out for a year too! Congrats dude its an eppic feeling to say the least!
