Page 65 of 74 FirstFirst ... 15405556575859606162636465666768697071727374 LastLast
Results 1,601 to 1,625 of 1844
Thread: Noob Drift Build :) - E36 turbo
  1. #1601
    Feb 2010
    Norway
    97 bmw 320, 94 bmwm3
    Great build!
    I see you use a s50 crank? is that from the euro engine?
    I have a 3.0 stroker myself With the s52\m54b30 crank, and that is making a lot of trouble With the dampener coming loose.
    Have you had any issues?
  2. #1602
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by s50b30 View Post
    Great build!
    It is S50US crankshaft out of our US 3.0 engines. 86mm stroke.
    I have had 3 dampers fail with the rubber separating from the metal ring and with high RPM rev limiter abuse, the crank harmonics are always an issue with 86mm and longer stroke cranks. I am going with an ATI damper now so hopefully I can prevent all those issues
    Mike
    IG: @mikevanshellenbeck
  3. #1603
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by milKt View Post
    Did you have an issue with your other AR Design manifold? Wondering....or do you just expect even better twinscroll pulsing due to equal length action?
    bump
  4. #1604
    Oct 2012
    Green Lake Wisconsin
    1991 BMW 325i
    bump
    Are you simply asking because you are considering buying a first gen ar design? Otherwise of course equal length is better, especially when you are trying to get the most efficiency out of your setup, and even detonation control.
  5. #1605
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by rowleym View Post
    +1
    I had zero issues at all with the other AR manifold. It was completely awesome, it just couldn't fit the huge frame Borg Warner that I wanted to run as it was custom built for a 6262/ GT35R frame size turbo. A S366 / EFR9180/ GT40/ GT42R + would not fit on it as the downpipe would run into the shock tower and I didn't feel like cutting all that up. AR happened to come out with the V2 manifold just around that time and it was avertised as even more power potential, more equal length, and I could fit a larger turbo so I went for it.
    The V1 still kicked ass and took names though.
    Mike
  6. #1606
    milKt's Avatar
    I've been KILLING/enjoying my v1 AR top mount for years (15k miles)...no issues, but...
    Mike "tests" hardware a bit more thoroughly, if you will. - He give his hardware HELL!!!!!
    I was wondering if he found any solid, measureable reason for the change.
    Quote Originally Posted by MikeE36 View Post
    +1
    Mike
    I see.
    thanks
  7. #1607
    Austin, TX
    S13, Turbo M3
    I see.
    thanks
    "Durability testing" is my specialty
    Mike
  8. #1608
    Ship, Pa
    Red Sled, RC51
    I still have Mikes first top mount manifold. Loving it too.
    FYI mike, I'm able to hold 11 to 12 psi on a 9 psi spring.
    "Believe nothing you hear, half of what you read"
  9. #1609
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by Fender13Bender View Post
    That's great control! Awesome. How's the power?
    Mike
  10. #1610
    Feb 2015
    Oregon
    1993 BMW 325is
    You should definitely trade me...... If you go back to page one of your build that's what I pretty much have, not nearly as pretty.
  11. #1611
    Austin, TX
    S13, Turbo M3
    Well a little more progress. I've been swamped launching Van's Parts so I haven't had much time to work on the M3.
    I did get in some supertech one piece std. size valves. I went with black nitrided intake, and inconel exhaust. (I also happen to sell these now if anyone needs a set, PM me. I will be a supporting vendor soon but I haven't been able to get the right people to email me back yet). Email me mike@vansparts.com
    Here are the valves, just std. size for a simple swap. I wanted to go with these one piece so I don't worry about breaking off a stock valve face at 7500 rpm drifting. I haven't had any issues in 5 years running stock valves, but it would be just my luck after it's all back together that one would come apart.
    Minimal update, but things are happening.
    Mike
  12. #1612
    Vancouver, BC Ca
    1993 325is
    Mike
    Bump your limiter up to 7,700 and most harmonic issues will diminish or vanish. I was told the nastiness happens at 7,400 and if you rev through it quickly you greatly minimize your "exposure".
    I have a 3.0 aluminum block built single Vanos that has a 7,800 rev limit. I DO have an ATI damper as well, but it's seen the rev limiter plenty of times and has about 9,000 miles on it now. I have had 3 oil analysis done now by Blackstone and the particulates in the oil are normal for a non-race engine.
    I'm certain I don't beat on my car the way you would Mike, and it's not forced induction but I'm still happy with the results.
  13. #1613
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by jakermac View Post
    That's great info, thank you. My goal was 7700-7800 rpm, but I'm still just a little gun shy since it's somewhat uncharted territory drifting with a lot of power at that rpm. Even Chelsea Denofa in his 800+ whp Formula Drift monster E46 only turns to 7200 rpm or so.
    Which ATI damper are you running? The VAC offering? I need one that has an OBD1 trigger wheel, and I'm not really willing to pony up the dough personally at this point to have another custom damper made that will suit my specific needs. I was told the "colby damper" was rated for 11000 rpm and 1800hp, but didn't have a trigger wheel, whereas the VAC unit is rated at 600hp, but does have an OBD1 trigger wheel option. I am shooting for somewhere in between those numbers. I just hope the VAC one will suffice. Only one way to find out
    Mike
  14. #1614
    Vancouver, BC Ca
    1993 325is
    Mine came from Dan Wennerberg at Pure Performance in Ca. I don't know what HP its rated for but is it OBD1 compatible:
  15. #1615
    Feb 2010
    Norway
    I reved to 8000 rpm, and that did not help me.
    The stock balancer broke the woodruff key 3 times, the last time it destroyed the surface the balancer sits on on the crank.
    But its 89.6 mm stroke.
  16. #1616
    Feb 2012
    Socal,ca
    97' E36M3 11' e92 lsxm3
    mike..
    whats plans for this season... gonna compete in pro/am or what?
    Castro Motorsports
    SLR Speed, Spec Clutch, Fuel Injector Connection, Turbojoe Tuned, Socal Sidewayz, Motorsport Hardware, StreetFighter_LA
    instagram @jefgroffaction
  17. #1617
    Austin, TX
    S13, Turbo M3
    I know for a fact that the engine won't survive with the stock damper on the crank. I am hoping it will be okay with the ATI unit though doing it's job. I wouldn't dare try 8000rpm with a stock damper
    Quote Originally Posted by 1FRacing View Post
    mike..
    I will be running as many pro-am rounds as my budget allows. We are having some really gnarly events in Lone Star Drift this year, with several japanese drivers flying out again (Yokoi, etc.) to tandem with us. My budget is tied up in my business mostly so I don't have a tire budget yet to speak of, but I am determined to drive at least 2 or 3 rounds this year. I spent over 10k in Kendas in 2013, so I'd really like to get someone to help me with that given how much smoke my car makes
    I will also be doing a few road course DE days, as I really miss that environment of just lapping for 25 minutes several times a day, and using the same set of tires all weekend
    Also will be out testing the car at a local track after the engine is broken in on the new turbo setup.
    Mike
  18. #1618
    Austin, TX
    S13, Turbo M3
    Some updates to keep this thread alive! Here are some pictures that I posted in my FI thread:
    Current line card I'm working on if anyone is interested:
    A’pexi
    ABA Clamps
    ACL
    ACM
    ACT
    Advics
    AE
    AEM
    Aeromotive
    Aeroquip
    Afe Power
    Agency Power
    Airaid
    Aisin
    ASCO
    Akebono
    AKG
    Alta
    AMC
    ARP
    Ate
    ATPTurbo
    ATS Diesel Performance
    Atsugi/Paraut
    Autogage
    Autometer
    Automotive Parts Center
    Avid Racing
    AVO Turbo World
    B&M
    Bando
    BBK
    BD Diesel
    Behr/Hella
    Belltech
    Bendix
    Bilstein
    Blackworks Racing
    BLE
    Blox
    Bocar
    Borg & Beck
    Borg Warner
    BorgWarner (KKK)
    Borla
    Bosch
    Bowa
    Brembo
    Brian Crower
    Brosol
    Buddy Club
    Bully Dog
    C&M Hydraulic
    Car Dolly
    Carrillo
    Castrol
    CEF
    Centerforce
    Centric
    Clevite
    Clough & Wood
    Clutch Masters
    Cobb
    Cofap
    Cohnen
    Cometic
    Comp Cams
    Competition Clutch
    Continental
    Corsa
    Corteco
    Cosworth
    CP pistons
    Crane
    CSF
    CTEK
    Cusco
    Daikin/Exedy
    Danblock
    Dart
    DBA
    DC Sports
    DEA
    DeatschWerks
    Defi
    DEI
    Delphi/Lockheed
    Denso
    Deves
    DiabloSport
    Doowon Climate Control
    Driven Racing Oil
    Driveshaft Shop
    Drop Engineering
    Dynatech
    Eagle
    EBC Brakes
    Edelbrock
    Edge
    Eibach
    Elring
    Enduro
    Eneos
    Energy Suspension
    Enkei
    Eurospare
    Exedy
    FASS fuel systems
    FAST
    FCC
    Febi
    Ferodo
    Ferrea
    FHE
    FIC
    Fidanza
    Flennor
    Flex-a-lite
    Flowmaster
    Fluidampr
    Four Seasons
    FTE
    Fuelab
    Garrett Turbo
    Gates
    GK
    GlovePlus
    Glyco
    GMB
    GoFastBits
    Goodridge
    Goodyear
    Gorilla Automotive Products
    Graf
    GramLights
    Grams
    Greddy
    GrimmSpeed
    GTSpec
    H&R
    Halla
    Hallmanboostcontroller (HBC)
    Haltech
    Hasport
    Hawk
    Hella
    Hepu
    HKS
    Hotchkis
    Hurst
    HushMat
    HuskyLiners
    HyperRev
    Hypertech
    Idemitsu
    Ingalls
    Injector Dynamics
    Injen
    Innovate
    Install Bay
    Invidia
    ISC Suspension
    JE Pistons
    Jurid
    K&N
    K1 technologies
    Kelford Cams
    Killer B Motorsport
    King Engine Bearings
    Koni
    KOOKS
    Koyo
    Kraft Werks
    KW Suspensions
    KYB
    Laso
    Liqui Moly
    Loctite
    LSD
    LuK
    M7
    Magnaflow
    Magnecor
    Mahle
    Manley
    Marshall Instruments
    MBRP Performance Exhaust
    MEYLE
    Mintex
    Mishimoto
    Mitsuboshi
    Moroso
    MotoRad
    Motul
    Mountain
    Mr. Gasket
    MSD
    Muteki
    Nabco
    NGK
    Nokya
    Nissens
    Nissin
    NPW
    NRG
    NSK
    NT
    NTK
    NTN
    Nu-Geon
    Okada Projects
    OMC
    OPparts
    OS Giken
    Pagid
    Painless Performance
    Paraut
    Parts-Mall
    Pentosin
    Performance
    Perrin
    PEX
    PIAA
    PLX Devices
    Power Division
    Pro Parts
    PROCAR
    Progress
    Project Kics
    Project Mu
    Prothane
    Pyoenghwa
    QA1
    Quaife
    Quarter Master
    Race Ramps
    RaceQuip
    Radium Engineering
    Radtech
    Rally Armor
    Rays
    RC Injectors
    Ready-Aire
    Redline Oils
    Rev-X
    Rigid Industries
    Rocky
    Royal Purple
    Russell
    Sachs
    Samco
    Sanden
    Sanyco
    SCAT
    SCT Performance
    Sebro
    Seibon
    Shuriken
    SKF
    Skunk2
    Smarty
    Snow Performance
    Sonax
    South Bend Clutch
    SPAL
    Sparco
    SPC Performance
    SPEC
    SRP Pistons
    SSR
    ST Suspensions
    STACK
    Stage 8
    Stoptech
    Superchips
    Supertech
    Synapse
    Takata
    Tama
    Tanabe
    TCI
    Technafit
    Tein
    Textar
    Thermal R&D
    Tial
    Tokico
    Torque Solution
    Tovic
    TRW/Lucas/Girling
    Turbo XS
    Turbonetics
    Turbosmart
    Unwired Tools
    URO
    Valeo
    Valvoline/Zerex
    Varga/TRW
    Venair
    Vernet
    Vibrant
    Volant Performance
    Volk Racing
    Wahler
    Walbro
    WASPcam
    WeaponR
    WeatherTech
    Whiteline
    Wilwood
    Wiseco
    ZEX
    Zimmermann
    /shameless plug for Van's Parts.
    Here are some progress pictures! I am back from vacation and things are moving along quick this week!
    While on vacation I went to a drift event at MMP (Miller Motorsports Park) and drifted my buddy Nate's turbo Miata. What a blast! I was really cramped in the car, with my helmet constantly hitting the main hoop, and my left elbow constantly hitting the door bar, but it was a blast!
    Back to the Gorilla!
    I hope to have the engine assembled and the turbo kit on Monday:
    Picture of the block/pistons from 2009 (M52 block/head, S50 crank/cams):
    Honed once or twice now. Another time and it will get 11+ CR pistons
    Cleaned up the shop at home a bit (the bench anyway) - we can fit TWO cylinder heads on the bench now, and actually still see the bench!
    Swapping out stock 2 piece BMW valves for Supertech one piece valves (black nitrided intake, inconel exhaust, single groove keepers on both.)
    Supertech 84lb dual valve springs and Ti retainers looking great and taking the abuse like a champ:
    210mm 4 clutch flat plate diff rebuild pics:
    Thanks for looking!
  19. #1619
    Feb 2010
    Norway
    looking good!
    whats the advantage of single groove valves?
    where did you get a hold of that valve spring compressor?
  20. #1620
    Austin, TX
    S13, Turbo M3
    looking good!
    I do not know if there is any advantage or not, but I know the supertech inconel exhaust valves only came in single groove and since I wanted to run inconel exhaust valves for sure, i just went single groove on the black nitrided intake valves also.
    The valve spring compressor is a tool we bought and then modified and cut the little rectangular pad that fits over the retainers larger to clear the Ti retainers and supertech dual valve springs (it was designed for stock retainers/springs and did not fit quite flush until being modified a little larger). I can't remember the brand at the moment but I'll find it for you. It makes valve spring/retainer/valve swaps a breeze.
    Mike
  21. #1621
    Austin, TX
    S13, Turbo M3
    Well it's 3:30 am here so I'm calling it quits for tonight. Got quite a few things accomplished and mocked up. I still need to get an ATI damper on order but I think that's the last piece of the engine puzzle. Here are some pictures from today's progress:
    More on Sunday! Off to Lonestar Drift Round 1 this weekend to spectate and hang out.
    Mike
  22. #1622
    Feb 2015
    Oregon
    1993 BMW 325is
    Mike I love you and all of your cars.
  23. #1623
    Jul 2004
    Austin, TX
    AA turbo 332i
    Awesome progress and congrats on getting the business up and running! You know I'm going to want to come spectate on the build lol
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
  24. #1624
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by dgerny View Post
    <3
    Quote Originally Posted by jjjjjjj View Post
    Thanks Jonathan! We will have to hang out some time soon for sure. Congrats on getting your boost situation figured out!
    Here are some more pics today guys of some mock up
    Mike
  25. #1625
    Austin, TX
    S13, Turbo M3
    Well the uppipe and upper WG dump fitment leave a lot to be desired. I guess they didn't fully bolt everything down when mocking the setup up and building it or something but it's pretty aggravating... Going to have my local fabricator friend move the WG dump to the other side of the uppipe instead if we can.
    Pics:
    Mike
