Page 5 of 74 FirstFirst 1234567891011121314153055 ... LastLast
Results 101 to 125 of 1844
Thread: Noob Drift Build :) - E36 turbo
  1. #101
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by BadBoostedBmwM3 View Post
    You should PM... i have a question or two.
    ? PM me if you have a question
    (doing switch panel wiring tonight. Found an X20 pinout so I now have ign, starter, fuel pump, etc. wires. )
    -Mike
    IG: @mikevanshellenbeck
  2. #102
    Mar 2008
    Bunker Hill, WV
    95 M3, 07 Titan, 96 XJ
    Mike are you writing this stuff down as you do it ??? im sure there will be people like my self that are interested in doing this sort of thing for a race car with the painless wiring harness ...
    I wanna do this in the E30... so i can get rid of that stupid fuse box with more fuse's then i actually need.
    E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
    Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
    *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
    Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
  3. #103
    Dicktone Limo
    yeah please do!
  4. #104
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by rpm620 View Post
    Quote Originally Posted by bennyfizzle View Post
    yeah please do!
    I am not really writing anything down as I go, but there are not that many steps and I remember everything I've done. I'll try to take a little more detailed pictures as I continue / finish the wiring and do a write up afterwards (after I know it works )
    -Mike
    getting somewhere... (I think )
    -Mike
    bigger oil cooler and aeroquip -10 an push lock fittings came in, as well as -10 push lock oil line
    -Mike
    oil cooler installed / current engine shot
    -Mike
  5. #105
    Ship, Pa
    Red Sled, RC51
    Thermostat for the cooler?
    "Believe nothing you hear, half of what you read"
  6. #106
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by Fender13Bender View Post
    nope. I live in Texas. Never had a problem getting it up to 150 F before beating on it.
    -Mike
    got the starter and ignition wired, power to the fuse box and switch panel, installed DME and cover, mounted the front battery post, installed the catch can and ran lines, and the front air ducting nose panel above the kidneys.
    Also hooked up the O2 and NGK wideband into the downpipe, working on figuring out how I'm going to get the cowl to fit so I can properly secure the engine harness to it. The metal is kind of beat up there for some reason, not sure what happened with the previous owner(s) but I'll figure something out.
    Couple of pics
    -Mike
    (I took more detailed pics of the wiring which I will post later with a small write up after I know it all works. Should at least be able to test accessory power stuff tonight, and then startup should be this weekend)
    -Mike
  7. #107
    western,MA
    87 swapp e30,boosted e36
    looking alot like my setup. i dont run a stat on my oil cool and i run the same one from the looks of it
    Jacques Cousteau could never get this low
  8. #108
    Dicktone Limo
    dude that's such an awesomely sick, clean setup.
  9. #109
    Austin, TX
    S13, Turbo M3
    Thanks More pics later. Engine bay is pretty much done except for a couple small things, and have to wire the headlights and turn signals still.
    Working on switch panel and dash. MXL and wideband are wired up. Need to make a bracket for the fuse block and mount it, and then I'll run a circuit test of the optional accessory just to see if I can turn on the MXL and wideband.. if that works, then I should be good to go. Ign and starter and all are wired up. Just need to hook up my turbo drain, fill it with fluids, wire the fuel pump, and fire it. Should be able to tomorrow night if the switch panel is verified operational tonight.
    (temporary break for online physics homework due in 2 hours ... )
    -Mike
    my wiring works
    dash test fit - not secured obviously and still crooked (didn't want to cut that much but the windshield bars made it really really difficult to keep the full thing. pretty much impossible actually
    accessory power on the switch panel works - wired to MXL and wideband.. soon as you flip the switch, both turn on
    MXL obviously not mounted either... I'll make brackets tomorrow so excuse the ghetto test lol
    I'm pretty confident in the starter and ignition setup too, so we should be able to see first start tomorrow night or mid day saturday unless I run into some giant problem.
    To do before start:
    -wire fuel pump
    -find nuts from home depot that fit the factory grounding studs (made a bracket for the fuse block hanging off 2 of those)
    -hook up turbo oil drain
    -change oil / fill
    -fill with coolant
    -install EGT probe
    -clamp / secure downpipe wrap better (dont want to bake it and then i can't move it)
    -double and triple check everything
    SOON!
    approaching the 1 month mark for the build too. Started on sept 12. Hopefully I can have it fired a few days before then
    After it fires, i'll properly secure the wiring further, secure the dash, make brackets for the MXL, etc. and do some *finishing* touches to the interior to hide the wiring as much as possible.
    Still need to figure out the diff leak, fix that, fix the fubar'd threads on the shock bolt that I still haven't fixed, install DS, bleed clutch and brakes, roll the fenders heavily (although I might just skip that and go straight to cutting them, since Sean's angle kit adds 50mm to each side up front... I pretty much have to flare it for that.)
    -Mike
  10. #110
    Oct 2008
    Centennial, CO: S'port, LA
    95 M3 - 03 325i - 68 Bug
    Which oil cooler is that you were previously running?
  11. #111
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by SneauxM3 View Post
    mishimoto universal
    -Mike
  12. #112
    Sep 2009
    Simpsonville,SC
    07 335i 6mt,M3 drifter
    hellums yeah im ready for a video!
    M52B28,S52 cams,UUC UDPs,M50 Manifold,M3 Exhaust,3.23 LSD and rokkor coilovers
  13. #113
    Apr 2009
    coffs harbour australia
    bmw328i coupe
    Turbo manifold
    Mate that turbo manifold is a work of art. I'm guessing it's a custom made? Did you design it? It's exactly the top mount manifold I'm after. I'm planning on doing a similar build to yours but rhd. So all the other manifolds out there won't fit. So if you did buy it off the shelf so to speak. Were did you get it.?
    Great build btw.
    Cheers
    Jonny
  14. #114
    Austin, TX
    S13, Turbo M3
    It's aliveeeee!!!!!!!
  15. #115
    Sep 2009
    Simpsonville,SC
    video says it all....
  16. #116
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by driftin07 View Post
    working on it... friend is emailing me his from his phone. my phone is dumb and can't take good video.
    -Mike
    [ame]http://www.youtube.com/watch?v=-gfg1RDGbFU[/ame]
    -Mike
  17. #117
    SO cold in the D
    1993 325is coupe
    Thumbs up.
  18. #118
    Sep 2009
    Simpsonville,SC
    WOOT WOOT!!! congrats. so jelly right now. hoping mine will be done by middle of the week! hoping...
  19. #119
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by DHutch View Post
    Thumbs up.
    Thanks guys! Super stoked about it now that that milestone is covered. Anyone who wants to run a painless wiring harness in their racecar, LMK. I can walk you through it. I may post a seperate thread about wiring it if there is interest. It's really not that bad
    -Mike
  20. #120
    Sep 2009
    Simpsonville,SC
    how much was the wire harness?
  21. #121
    Austin, TX
    S13, Turbo M3
    ~$580 with everything, fuse block, switch panel, etc. etc.
    -Mike
  22. #122
    Sep 2009
    Simpsonville,SC
    thats not too bad.
  23. #123
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    Is the wg piping only coming off one bank or is it tied to both banks? I ran two gates off my manifold but I'm curious if one 44 would have worked off a single bank. I didnt want to run a single gate with the inlets merging from both banks.
    97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
    02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
    16 M3 - 9.3@151 - Built motor/twins
    15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
    BMW SOB's turbo E30 - 8.72@158.39
    follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
  24. #124
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by mike radowski View Post
    yeah, that's how it is setup. 1 gate from both banks, so technically it's not true TS there at the WG merge.
    -Mike
  25. #125
    Nov 2005
    Linden, NJ
    F80, E36, X3"M"
    Gotcha. You can keep it true twin scroll with a single gate if you keep it divided all the way to the gate, although it makes the piping more complicated.
