Page 4 of 74 FirstFirst 12345678910111213142954 ... LastLast
Results 76 to 100 of 1844
Thread: Noob Drift Build :) - E36 turbo
  1. #76
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by imaiami View Post
    I have the bentley in pdf if you like to give you the pinouts/ or at least wire color for the connector you need. lotta going through systems if I remember, but you shouldn't need many wires since you aren't using the stock gauge cluster eh?
    and not the stock fuses and relays?
    not many wires needed. No stock cluster, no fuse box nor stock relays (except the 3 that are tied to the engine harness)
    I have a painless wiring aftermarket harness and fuse block.
    Manifold/turbo/dp/wastegate are here. Unfortunately I'm a moron and didn't show my fabricator pictures of my cage tieing into my front shock towers, and totally forgot about it when looking at pictures of the manifold/wg piping.... thus the downpipe and WG pipe don't fit. Going to have to get them modified. Here are a few pics of the manifold and turbo on the car though
    And some WG clearance issues that I need to fix / have modified since I didn't tell my fabricator about the cage tie in to the front shock towers:
    That's it for now.. Might have to pull the manifold/turbo off to send it back and get modified. Maybe first start next weekend?
    -Mike
    IG: @mikevanshellenbeck
  2. #77
    Dec 2003
    memphis
    Lots o' m3s
    Quote Originally Posted by MikeE36 View Post
    Also, anyone know where to get replacement exhaust nuts? World pac doesn't have a PN for them. I guess dealer? Home depot?
    You may also want to use the 135/335/n54 exhaust studs. They are a torx head bolt and much easier to deal with. You can cut them to length if your manifold is an odd depth.
    You'll also want to think about riveting or screwing in the DEI wrap on the wheel well - as the adhesive will start to fail over time.
    Lots of progress, keep it up.
    SOLD -A dozen ///M3s of all shapes
  3. #78
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    Just cut that part of the cage Problem solved. You're welcome.
  4. #79
    Aug 2011
    Florida
    1997 M3/4/5
    <3 Benny Yeah around 2 years auto-x/track with my car. I have like 40-50 youtube videos of the black car
    T1 at H2R (local-ish track) in the black car
    -Mike
    link to youtube vids plox
  5. #80
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by Flak View Post
    http://www.youtube.com/user/mvs36
    -Mike
    Quote Originally Posted by Piner View Post
    I'd rather not do that. Way too much work went into this chassis to just cut a cage tube like that. I might just rotate the first pipe and have the recirc closed up on the DP and run open dump for now
    -Mike
    more test fitting... wrapping downpipe, turbo blanket, etc.
    Had the downpipe modified and WG piping modified to just run open dump. Bring ear plugs if you want a ride
    aeroquip -10 push lock drain
    -Mike
  6. #81
    Aug 2008
    Lakeland Florida
    Open dump is the way to go, sounds sexual
  7. #82
    Austin, TX
    S13, Turbo M3
    hell yeah. I had an open dump on my 6262 but only for 3 days.... street driving it, cops can hear you from literally 1/4 mile + away.... I don't want to go to jail. For a drift/track car though, hell yeah! so easiest way to fix this piping was go open dump. I still have to go get a dump tube fabbed, but i'll drive/tow the car to my buddy to do that after the *rest* is done, i.e. running, with windows, etc.
    few more pics from last night
    -Mike
  8. #83
    Jul 2010
    NC
    e34 528i/5
    This thread is porn for gearheads!
  9. #84
    Dec 2008
    Suwanee, Ga
    '93 325is '06 RSX
    just went through the whole thread. so jelly.
    amazing build and cant wait to see it done.
  10. #85
    Dicktone Limo
    clutch fan?! god why?!
    can you bring this thing up to a club loose event so I can drive it?
  11. #86
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by bennyfizzle View Post
    because the clutch fan does a way better job at cooling at low speeds / high RPM than any e-fan. I had a spal setup. According to my MXL water temp logs, the clutch fan flows a LOT more air than a 16" spal.
    -Mike
  12. #87
    Aug 2009
    Surfside beach sc
    E46sedan m50,12 ecoboost
    About the clutch fan, really? I guess cause your boosted you get alot more heat. I run dual 10inch electric fans but I'm also na so I'm guessing not half as much heat as you. Been following this build for a while. Sure do wish I had this kinda fundage haha.
  13. #88
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by Euroslide View Post
    Yeah turbos make a lot more heat than an NA car. The clutch fan flows like 5000 CFM once that fan clutch starts locking up as water temp rises to the 195-200 area. Hence the crazy "howl" you get when the car gets warm.. It's flowing a LOT of air. My spal would flow more at idle and keep idle temps a little lower, but for high rpm, low-ish speed situations (i.e. auto-x or drifting), the clutch fan does a WAY better job of keeping the water temp in check. (which is why I think it's crazy chelsea isn't running a clutch fan right now. AHEM. )
    -Mike
  14. #89
    Aug 2009
    Surfside beach sc
    -Mike
    Haha idk he's doing a good job of it. I'm running a v8 with an upgraded cooling system, pump, rad,160 t-stat and the fans output 2900 cfm a piece. Did away with the clutch fan when it broke on the inline six.
    [QUOTE="Euroslide"]
    Ps keep up the amazing work.
  15. #90
    Dicktone Limo
    Yeah man, one 16" spal flat blade flows like 2400cfm. I know you have a lot more power, and therefore heat, but I can't believe that that clutch fan would do better than two of those bad boys.
  16. #91
    Austin, TX
    S13, Turbo M3
    how are you fitting TWO 16" spals? lol that's crazy talk!
    pics in a min
    -Mike
    good think I relocated the expansion tank lol
    -Mike
    temporary panda. kidney nose panel, mirrors, and bumper need to be painted alpine
    -Mike
  17. #92
    Dicktone Limo
    lol good point I didn't completely think that one through.
    im sojelly.
  18. #93
    western,MA
    87 swapp e30,boosted e36
    no nice, how are you going to have working windows? my windows do not work, got the sunroof to work but i want windows
    Jacques Cousteau could never get this low
  19. #94
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by mo gun e36 View Post
    I won't have front windows. Only glass windshield, and lexan 1/4 and rear window.
    -Mike
  20. #95
    Aug 2009
    Surfside beach sc
    I'm not running dual 16s haha they are 12s?10s? I'd have to look again. not sure if that was directed at me or Benny.
  21. #96
    Springfield, MA, USA
    635CSI
    this is good stuff
    ULTIMATE DRIVING MACHINE
  22. #97
    Austin, TX
    S13, Turbo M3
    Yeah I was talking about Benny. He mentioned 2400 CFM for a 16" spal, and talked about fitting to of them. I didn't / don't think that's possible to fit. The rad isn't wide enough
    Quote Originally Posted by GreatWhiteShark View Post
    this is good stuff
    Thanks Should have some more progress tomorrow night / Wednesday night. Bit too busy with school/work today to do anything (still at work now )
    -Mike
  23. #98
    Louisville, KY
    turbo m3
    Wow, Mike! Everything looks awesome. I can't believe I missed this thread. I thought your replies in Otis' thread were said in jest about the manifold and turbo.
    This is my signature....
  24. #99
    Austin, TX
    S13, Turbo M3
    Quote Originally Posted by BadBoostedBmwM3 View Post
    heh, nope! I sent him the manifold/wg and told him I wanted a twin scroll top mount T4 setup So far I'm VERY pleased with his work. If I did it again though, I would go with a 3.5" downpipe. the 4" is asking for trouble with heat management and it being so close to EVERYTHING. Good thing I have solid engine / trans/ everything mounts or I'd have problems with it bumping into stuff too
    -Mike
  25. #100
    Louisville, KY
    turbo m3
    -Mike
    You should PM... i have a question or two.
