Page 3 of 23 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 567
Thread: Build yourself an S50B30 clone for cheap!!! DIY
  1. #51
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by cj.surr View Post
    I'm trying to figure out about grinding the gear, too. The OP seems to never answer this question.
    Vanos gear that is bolted to the camshaft has to be shortened 4mm as you can see in the photo fresh grinding marks. Ones you compare your stock cam with m54 cam you will know what I am talking about.
  2. #52
    Upstate
    E28
    Any idea if there are any other OEM pistons that will work with this setup? I can find an s52 crank and m52 rods, but I can't find m54b30 pistons for a reasonable price at all.
  3. #53
    Apr 2009
    monterey park , california
    1993 325is s52 6 spd
    @op when you said you re-used main bearings and rod bearings , were those from the m50 or m54
    also why did you have to shorten vanos gear / what kind of grinder was used?
    forgot to ask if the m50 head was used or something else?
  4. #54
    Jul 2011
    Denver, PA
    Blue 2000 Z3 2.3
    Could I use an s50 rotory assembly in an m50 block?
  5. #55
    Nov 2010
    Cape Coral, FL
    1993 BMW 325i
    Quote Originally Posted by coolpizzadude View Post
    Good question. I'd like to know too.
  6. #56
    Upstate
    E28
    Yes, but you would have to bore it out, which would probably make it not worth it. It's cheaper just to buy the whole S50 block and use the M50 head, which is the same.
  7. #57
    Edmonton, Alberta Canada
    96 328is
    after all of this is done what engine management are you using and what kind of tune will be required. I have all the parts you have listed and would like to know about the ecu tuning and so on .
  8. #58
    Sep 2010
    Venice, CA
    1999 Ford Escort
    after all of this is done what [COLOR=blue !important][COLOR=blue ! important]engine[/COLOR][/COLOR] management are you using and what kind of tune will be required. I have all the parts you have listed and would like to know about the ecu tuning and so on .
    I've done quite a few S50 kits, if you choose right you can find something that uses all stock sensors and preserves full VANOS operation... my suggestion is Vi-PEC or Pectel; we've tried them all and these are our choice.
  9. #59
    Vancouver, BC Ca
    1993 325is
    How do you feel about the Miller Performance W.A.R. Chip system?
  10. #60
    96 328is
    Quote Originally Posted by neelvasavada View Post
    so this is a direct replacment not a piggy back, so i would need them to tune it by dyno or tell the specifacs of the car. The only dealer in Alberta is in calgary which is about 3.5 hours away meaning an expensive tow or trailer rental. but seems legit and understandable. what did you do to use this vi- PEC?
  11. #61
    May 2009
    UK/Romania
    E36 328i M54B28
    Nice job man! Simple and concise. Thinking of doing the same in the summer. Any particular bits I should have in mind before starting the build?
  12. #62
    Upstate
    E28
    I have a question... I plan on using the M54 intake camshaft, so I would only use the M54 tray and lifters for the intake side, correct? Just leave the M50 stuff on the exhaust side?
  13. #63
    Oct 2008
    mocksville NC
    e36M3 e30is e39it
    This is a really cool thread, I may have to build one of these monsters for an e30...
    I have all the stuff I need.
    Thanks man!
    PM/email me for some of the cleanest and safest redrills money can buy.
    info@ewheelworks.com
    I can also powder coat, polish, and plate for a very competitive price.
    ewheelworks.com
  14. #64
    North Alabama
    1998 BMW 323IS
    Is that a model car in your pic ?
    The shadows suggest it is.......looks really neat
    A hundred years from now it will not matter what my bank account was, the sort of house I lived in, or the kind of car I drove. But the world may be different, because I was important in the life of a child.
    for Zach, Everett, and Lilly
  15. #65
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by paniolo View Post
    The M54 is really hard to fit in an e36....
    How's that?
    I have seen some nice M54B30 shoehorned into an E36.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  16. #66
    USA
    -02 530i
    Shoehorned? An M54 is no larger than the M50/M52 engines that came in the E36.
    An M73 in an E36 would have to be shoehorned in, but even that is not impossible.
    http://www.akgmotorsport.com/swaps.php
  17. #67
    The Netherlands
    Quote Originally Posted by granlund View Post
    Shoehorned? An M54 is no larger than the M50/M52 engines that came in the E36...
    Well that was my point. Because the OP said it was a tough one to fit.
    Which means I have mixed up the meaning of "shoehorned" in. I thought that meant it was an easy fit. Like how you easily slide into a shoe with a shoehorn.
    So I guess it means the opposite.
    IG:
  18. #68
    North Alabama
    1998 BMW 323IS
    How much HP ?
    what would a S50B30 clone in good condition produce in HP and Torque ?
  19. #69
    Nov 2010
    San Jose, CA
    96 M3,'12 Grand Cherokee
    Quote Originally Posted by Pdwight View Post
    The same as any 3 liter m50 based engine with similar compression i.e. the same as an s50
  20. #70
    North Alabama
    1998 BMW 323IS
    Well a simple answer would have been nice, I could have said will it produce 1/3 as much as a LS1 or double that of a Chevy Vega GT Engine
  21. #71
    Upstate
    E28
    It doesn't get much simpler than that... An S50 makes 240hp.
  22. #72
    North Alabama
    1998 BMW 323IS
    There we go........Thanks
  23. #73
    SoCal
    '94 325i vert
    So the lean issue was never solved?
  24. #74
    Upstate
    E28
    That was only for one other guy that did something different in the build (I don't remember what).
    The OP has the engine running with a good AFR, as far as I know.
  25. #75
    North Alabama
    1998 BMW 323IS
    That would be a huge HP gain if my little S52 ever goes south
