Nope hasn't been balanced. Clutch is a Southbend Stg 5 and i have a stock dual mass flywheel. Realistically I'm going to have this and the DS professionally double checked and balanced to completely rule them out.
Brand new control arms, bushings, and tie rods. Can't be that.
Revisit to an old thread. I struggled for a year plus trying to rid the E36 M3 of the deceleration driveline vibration. 2 New flex disks, balanced drive shaft, readjust The CSB, re-torgue the trans mounts to name most. FINALLY it turns out to be the vertical drive shaft alignment. I used a bubble torpedo level and shimmed the level till the back section of the shaft showed level on the level. Then compared the front section. It was off 1/2 bubble. I shimmed the CSB mount with a couple of thick washers and got the front angle very close to the rear section, about 4 mm total thickness. Viola no more vibration!! Wish i had a digital level to get it closer, but it is now close enough to eliminate the vibration. Best to all struggling with the decel vibration. This might be worth a try.
check the tq of the wheel lugs?
Capital Driving Club Car # 102
How to turbo your car:
Step one. Install ecu and learn to tune and or have it tuned.
Step two. Install injectors and retune.
Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
Step four. Retune car
Step five enjoy
Tail flange? You mean pinion bearings? You'll have to press the pinion out in every IRS or third member diff I've seen. That means dropping the diff and disassembling it. You should recheck the pinion depth and pinion to ring gear contact after replacing the bearing, as well as pinion bearing preload if you don't have a crush sleeve in there (I think most modern BMWs use a crush sleeve tho). It's not super hard, but I wouldn't call it a simple job if you've never taken apart and setup a diff. You need a press to do the work as well.
Yet another thread revival! rocky999, your experience seems to be similar to mine. Thanks for this info, as it presents SOMETHING I haven’t tried yet. Trying to understand your description. Are you basically saying that you aligned the CSB so the entire driveshaft it is one straight line from the trans to the diff?
I’ve had numerous attempts to replace almost everything. Guibos, CSBs, rebuilt/balanced driveshaft, clutch/pp/flywheel, rebuilt diff, etc. But this vibration has been there for years and I’m going a bit batty trying to figure it out. The only thing I haven’t attempted yet is to replace the crank damper on the front of the engine. Aligning the driveshaft would be a lot easier, so will give that a try!
My vibration is also only on decel. Not every time, either. But frequently. And when it happens, you know it. Very noticeable. It isn’t totally predictable but it seems more likely to happen if you lift off abruptly. A light touch on the accelerator makes it immediately go away, and lifting off the throttle extra-gently seems to be the best way to keep it from happening.
I have ultra-stiff Vorshlag motor/trans mounts, and poly diff/subframe mounts. But the slight increase in in NVH from these things is clearly NOT what we’re talking about, here.
Here to ask of anyone else's opinion but I've had this problem since I swapped a zhp motor into my 325i after it blew up and installed 80a engine/trans mounts. My car now has an extreme vibration that feels like your driving over massive rumble strips when I hit 3k on decel. Ive got 209k on the chassis but it was very well kept. My only clue is that when I blew my motor I over revved from a money shift and while the car was still rolling I tried to take a turn and my rear end slipped out from behind me on a slightly wet day. Curious as to why my car is making a distinct vibration/shudder, I haven't really taken a look at the rear. Thanks!
Has anyone figured out the cause of there decel vibration?
1994 325is- M52 swap, Fan delete, AA chip, CAI, TC-Kline DA, H&R 28mm front sway, Kevin Higgins exhaust, kosei k1 17x8.5's with RA1's, DS2's with REO1R's, 3.23 lsd
