Results 1 to 6 of 6
Thread: Manually retract on fully auto top?
    Sep 2011
    bradenton, Florida
    97 328i convertible
    Hi guys, I searched this forum and tried to find it in my manual with no luck. There were tons of threads for getting it back up though.
    I have a 97 328i vert and the motor to raise lower the top is shot. I want to still be able to drive with the top down on occasion but I can't figure out how to manually retract it. I found I am supposed to use an Allen wrench but can't find where? Any help would be great.
    Riick is offline ฎ Resident Wiseguy ฎ
    Teeny-Tiny Delaware
    '97 328ic Slushbox
    FIRST FIRST FIRST -- Lower *all* the windows partway !!!
    Allen key operates the motorized hooks that hold the top to the windshield
    Some people use a cordless drill with Allen-key shaped bit to operate
    this part of roof.
    Once this is released, THEN, you ned to release the motors from the top
    --- this is done by using lever under driver-side of rear seat.
    Now you should be able to lower the roof itself.
    How to get rear cover to unlock & open -and- later to close & lock
    ... I have no idea.
    Sep 2011
    bradenton, Florida
    97 328i convertible
    Where is the location to use the Allen key?
    The Netherlands
    DE-spec E36 328i/M3 cab
    At the handle behind the rearview mirror. It's all explained in the owner's manual which everyone should have or not, get first. As most questions are answered right in there.
    1998 BMW M3 3.2 Cabrio • Alpinwei฿ III on Schwarz • German spec • 1 of 12
    IG:
    Dec 2018
    Mt. Airy, MD
    1997 328i
    After releasing top from windshield and disconnecting motors, I can't get the tonneau cover to move. Help
    Baton Rouge, LA
    '98 328i convertible
    You need to crank it a long time. Far past when the latches let go. The top will lift maybe 6" above the windshield before the top can be lowered. Then you need to lift the rear of the top so it is vertical. Then you can lift the tonneau cover. Then the entire top can be lowered into the storage area.
    - Ken -
