engine wont turn , after removing valve covers found that piston in cylinder 8 is stuck. guessing that its a broken connecting rod. if that is the case is repairable?
if anyone had similar problem, please advise
Wow that is beyond basic.
If one cylinder is stuck, and the rest are moving, then you have a broken conrod. Fixable, depends on many things, there just not enough info, pictures, somthing anything?
What i dont understand is, how can you tell its cylinder 8 just by removing the valve cover?
I also find it odd that your keyboard doesnt have shift key for capital letters.
92' E36 Coupe 320i
Coil overs - 17" Rondell 58 8.5"/10"
Stroker M50B20 w/ Vanos Delete
Miller Performance W.A.R Chip - Ebay headers - 328i Exhaust
