Hey guys, this works on my 99 M3.. except i cant tell if I unlocked the functions or not.. the whole day+month idea.. Goes to #19 func., then you're supposed to enter that magic number.. so today its.. 18, correct? nothing happens.. shouldnt it say Lock off or something?
under test 11, if you enter '71' you will get the AM/PM clock. if you enter '72' you will get the 24 hour clock. anyone got any more of these code
Maybe I missed it somewhere but, is there any way to make it display the info on these hidden menus in english units instead of SI? Mph means a lot more to me than km/h. Cool trick though!
'14 Evora S - Chrome Orange/Ebony
'02 M5 - Carbon Black/Silverstone
'15 M235i xDrive - Mineral Grey/Black
Maybe someone can answer this. Why does my Computer Module not do the same as listed from the other Control Modules I have found online.
This is what I get:
And YES, I understand what most of it means and to display some I have to his (SET/RES).
Function ->
00 Test MFD Lights (It beeps 3 times)
01 Change Speech
0 DT.
1 ENGL.
2 FRANZ.
3 ITAL.
4 SPAN.
5 AMERICAN
02 Clock
00 24 Hour
01 12 Hour
03 Datum
00 tt.mm
01 mm.tt
04 Temp
0 C
1 F
05 Quarz: - 001d
06 Status
000000a Gear in D
000000b Key in Pos 3
000000c
000000d
000000e
000000f Start Car (Displays after 000000b)
0000001 Key in
0000002 All On
0000003 Key in Pos 2
000100a Gear in R / Braking
000200a Gear in R / Decelerating
000300a Gear in D / Braking
000400a Gear in D / Decelerating
07 Nothing (Just One Beep)
08 Same
09 " "
10
11
12
13 " "
08 - 13 do nothing at all and continues, I stopped at Entry 22.
I do not get test 19 or any such thing.
The instrument Cluster gives me:
01 BMW Part#............364438
02 Code No. Nothing
03 K No.....................7504
04Last 5 Digit VIN.......37508
05 Software Version#..200
06 Revision Index#......88
The AC option does what I have found listed online from Temp Sensor to Software version 37
Any ideas??????
1996 328iA-4 4DR SEDAN Alpine White \ Black (300/0) E36 M52
01-09-2016: 195,600 Miles
2007 328iA-4 4DR SEDAN Alpine White \ Grey 10/2006 E90 N52N
01-09-2016: 158,600 Miles
2007 530i 4DR SEDAN (N52B30A) Silver \ Grey Metallic 05/2006 E60 N52
01-09-2016: 158,230 Miles
bump on this one! i just can't figure out the way how to do it...
consumption is like 5,1l/100km on my 325i so i'm guessing i have to change the thing in testsequence02 to 4-cylinder engine
i pressed 10 or 1 and then it switched between ITON and DTON. DTON is dualtone perhaps, but dunno what's ITON
you have to enter the month+date! if it's 12th of october, it means 10 (as october) and 12 (as the date). 10+12=22! you have to set the right date first, because the obc reads the date out of itself.
Ok guys when i press 1000 and 10 its says "Funktion" and when i sum the date and enter it it just goes off and now even when i press check nothing happens it stays off, i can get the first 4 or 5 functions but thats it, is it still locked??
TEMP (A-TEMP)
Outside temperature
Displays the outside temperature after pressing the TEMP (A-TEMP) button. If it falls below +3�C, a gong signal is heard as a warning; the outside temperature is displayed and flashes for eight seconds.
The warning is repeated if the temperature rises to at least +6�C and then drops again to +3�C.
RANGE (REICHW)
Probable range
This display indicates after pressing the RANGE (REICHW) button how far the car can probably be driven on the fuel remaining in the tank. The value takes into account the way in which the car has so far been driven. A plus sign (+) in front of the displayed value means that it is still undergoing a correction process (measuring tolerance).
If three horizontal display segments flash, the range is below 15km and the car should be refuelled as soon as possible.
The on-board computer registers fuel added to the tank only when the engine has been stopped and the quantity of fuel exceeds four litres.
SPEED (GESCHW)
Average speed
Shows the average speed since the last reset. To display press the SPEED (GESCHW) button.
To reset the calculation press SET/RES. The on-board computer doesnt include the time the car is standing with the engine off in its calculation.
CONSUM (VERBR)
Average fuel consumption
Average fuel consumption can be computed for two distances in parallel. Each time the button CONSUM (VERBR) is pressed, the display alternates between the average consumptions for distances one and two. There is also an indication of whether distance one or two is being displayed.
DIST (DISTANZ)
Distance from destination
After pressing the DIST (DISTANZ) button the display shows how far the car is from the destination, provided the total distance was input before the journey started.
The probable time of arrival, which is recalculated continually as driving conditions change, is also displayed.
If the car has already completed the full distance which was input, the distance value is preceded by a minus sign (-).
LIMIT Speed limit
If you exceed a speed limit which you have previously input, you will hear a warning gong. The corresponding LED flashes and the display shows the stored limit briefly. The warning is repeated if the speed limit is again exceeded after the cars speed has in the meantime dropped by at least 5 km/h below the entered value.
To cancel the speed limit input press the LIMIT button again. The LED goes out but the stored value is not lost and can be re-activated with the Limit button.
To adopt the cars actual speed as the limit value press the LIMIT and then the SET/RES button.
km/mls
Display units changeover
Press the km/mls button to switch display units between km/h and mph or litres per 100km and mpg and back.
CODE Immobilizing vehicle
A 4-digit number can be entered with the "CODE" key in ignition switch position 1. The engine hood and radio contact is monitored when the vehicle is parked with CODE armed. The engine cannot be started until the same code number is entered again in the BC to disarm the system. Depending on the selected function, the small display shows either the date or the time. Date and time can be displayed for 8 seconds by pressing the key in ignition lock position "0".
CHECK Check control faults
A display test is performed if there are no check-control faults and the "CHECK" key is pressed for at least 10 seconds. The test appears immediately after pressing the "CHECK" key in ignition switch position 1 or when no check-control is coded in the BC V.
MEMO Arbitrary reminder
An hour signal and/or any arbitrary reminder time can be programmed or checked with the "MEMO" key:
After pressing the "MEMO" for 3 seconds enter "MEMO" appears in the large display, ":00" appears in the small display.
After entering any time (minutes) with the digit keys "1" and "10" and acknowledging with the "SET/RES" key, the hour signal then sounds 15 seconds before each full hour plus the set time in minutes.
Gong time = Full hour plus input time in minutes minus 15 seconds.
Hi - would this work for 1994 e36 320I?
Hi,
Any ideas why an asterisk appears after the language is changed?
My computers default language was GB but after changing it an asterisk (*) has appeared & remains, even whet set back to default..
What does this mean? It's doing my noggin in!
does anyone have a guide for OBC's that read 'Funktion' when 10 and 1000 are pressed
Here is some more cool info.
The BMW E36 digital climate control unit has a feature that allows different sensor values to be displayed on the control panel. The display mode is called up by pressing the "AUTO" and "REAR DEFOGGER" buttons simultaneously. 12 displays are available and you can toggle through them by pressing the fan rocker switch.
Test number
Function
Test 1
Interior Temp Sensor
Test 2
Exterior Temp sensor
Test 3
Left Heater Core Sensor
Test 4
Right Heater Core Sensor
Test 5
Evaporator Temp Sensor
Test 6
Engine Speed Input
Test 7
Road Speed Input
Test 8
"Y" Factor Value . . . Anyone knows what is this?
Test 9
Fresh Air Flap Position in % (99.5% Max.)
Test 10
AUC Sensor Voltage (if equipped)
Test 11
Battery Voltage
Test 12
Software Version
The sensor display functions are exited by pressing "RECIRC" and "AUTO" buttons simultaneously and also by turning the ignition off. The decimal point is not shown therefore 66.5% would show as 665 All temp displays are in degrees centigrade. Negative values are indicated with minus sign
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
I was just thinking about this thread earlier as I fiddled with my OBC at the Taco Bell drive thru.
E36 NON Vanos and Misc Parts for Sale
http://s1126.photobucket.com/user/To...25i%2092/story
http://s1126.photobucket.com/user/Tomfordny/library/
thanks for sharing. I guess this makes my VDO volt gauge useless. I can put some other gauge in there now. Cool.
Hi,
I haw enter the OBC in number 19 and now is unlocked.
I haw problem with number 10 which is for the language.
on mine is 00 D, and everything is on German.
When I enter the 10 number it is not possible for me to change anything. I press button 10 and 1000 but with button 10 nothing happened and with 1000 just go to the test 11.
Please help I haw everything on the German now and I don't understand nothing.
So I menage to unlock on 19 it said ''ON''.
But test 10 is problem.
is there an operators instruction manual for this obc? i own a 95 325 with the 18 button unit, and i would like to know all the functions and how it works. also my clock is totally dark. is it bad or just a bulb?
Its a shame the OBC does not have the capability to continually re-sample data, if it did you wouldnt have to press the reset button to get speed and consumption...it would continually update. I guess there was not sufficient computing power in a system designed around 1990 (my guess to the design date)
A hundred years from now it will not matter what my bank account was, the sort of house I lived in, or the kind of car I drove. But the world may be different, because I was important in the life of a child.
for Zach, Everett, and Lilly
Unless the OBC has some unbelievably inefficient programming, there were plenty of processor cycles back then to show less averaged values. It's just how they wrote the specification and code
--- MORE MATERIAL --- MORE MATERIAL --- MORE MATERIAL --- MORE MATERIAL --- MORE MATERIAL --- MORE MATERIAL ---
For your enlightenment and amusement, here's a bitmapped PDF (not mine) of the E36 OBC section in the European E36 owner's manual. It includes the park/auxiliary ventilation feature not covered in the U.S. manual.
Last edited by johnf; 12-01-2011 at 07:23 AM. Reason: Automerged Single Posts -- Grrrrrrrrrrrrrrrrrrrr
But that's not how those functions are meant to be used, and therefore incorrect. Further, your requirement wasn't in the specification and would be an impermissible (and unsettling) variance.
Needless to say, I exaggerate tremendously to convey the possible and much milder thinking behind the OBC.
