This is a special BMW REAL AXLE/BEARING TOOL to use on a different applications
I rented similar tool ( just the older version ) to replace my REAR bearings
it worked great w/o any hammer !!
I like it so much so i bought my personal tool
http://www.bimmerfest.com/forums/sho...159&highlight=
see post started from #77
- Install the Bearing onto the Hub first; If you use the correct socket to drive on the INNER Race only, then you are fine.
- Use BMW Special tool to lift IN Hub & Bearing combo.
- The same tool can be used to lift OUT Hub & Bearing combo
- The same tool can be used to press IN Shaft Axle only
- The same tool can be used to press OUT Shaft Axle only
Tool is for rent , 100$ including my shipping
You will need to pay 400$ which i'll give you back in the end of lease
bump
bump
up
Does this tool work on the rear axle on an E39?
It looks like it is the front axle tool for an E60/E61.
I have both E60 and E39 axle tools
Original BMW , rent is 100$
Rent condition :
$400 prepaid with PP
I sent you tool , in 2 weeks you sent it back
i refund you 300$ ( one way shipping is my )
if interesting mail me direct
igorolen gmail com
small shaft is for E39 , big shaft is for E60
I dont have black tool any more , it was the old version of the same tool
up
up
up
up
photobucket fixed
Where did you find the axle tool? I’d like to get one for E36 M3. Already have a bearing tool, but I spent hours getting the axles back in.
'95 M3 S54 Track Toy
'19 X5 40i M-Sport
'16 Cayman GT4
‘23 GR Corolla
