Page 1 of 14 1234567891011 ... LastLast
Results 1 to 25 of 330
Thread: The Old Boat Build... part one?
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    1989 735il Turbo Build 328WHP Goal
    i figured while it was raining its ass off here in MD i would put this together to start documenting my build.. well enough small talk heres the list of things ive already bought
    things ive gots:
    MillerPerformance W.A.R. chip
    TO4E turbo
    38mm wastegate
    some cheap bov
    VAC motorsports oil relocation and cooling kit
    Cometic .080 over MLS head gasket
    Bosch 42lb injectors
    19 row oil cooler
    all oil lines are 10AN
    oil feed line is 4an
    things to be ordered :
    intercooler
    TCD manifold
    adjustable FPR kit from VAC
    some decent manual boost controller
    and some other things im probably forgetting to mention..
    ANYWAY on to the things you guys like the most..
    PICTURES !!
    sorry for the iphone 4 quality
    il be uploading some real pictures after the hurricane passes.
    heres the car we will be turbo ing
    beginning to put together my throttle body relocation kit i came up with
    all assembled and pressure tested !! looks very clean
    soo worth the price
    my cheep turbo and wastegate
    and heres the best thing on my motor!! just finished this up last night when i had nothing to do
    to be continued..
    Yorba Linda
    1991 325I 2dr E30 M20
    Sick!
    should be fun... Love the valve cover!
    It's tough to drive with Clown Shoes on
    USMC 0317
    Chicago, IL
    e28 m5, e34 TCD S3
    Stock fpr is fine. No need to waste money on an aftermarket one.
    Jan 2005
    Lake Washington/Renton
    2000 4Runner/95 OBD1 3.2
    no need for a HG on your motor too
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    Quote Originally Posted by DTM325PWR View Post
    playing it safe man.. getting my head decked and new valves installed.. i kinda want some room to go for more power
    my goal is 328WHP or 400 crank
    Jan 2005
    on the auto trans?
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    yes, most likely getting a TCD stall converter later down the road as well..
    also i got my LC-1 gauge mounted today.. looks purty clean.
    Got a few things done last night. Il be posting pictures tonight when I get off work
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    can anyone tell me what they used to "Tee Off" the oil pressure switch on the head to feed the turbo oil? i cant find any info on what thread type it is to make one or anything like that
    and heres pictures of the progress
    Bellevue, WA
    1995 540i/6,740i
    You'll want to get oil from the oil filter housing. The oil pressure switch at the back of the head isn't a good supply & would reduce oil to the valvetrain. I got a new oil cannister with the factory oil cooler, which had a boss that I tap'd for oil supply to the turbo.
    A throttle body from an m50 might be a good way to swap an m30 intake. The m50 e34 throttle cable could be used and the piping would be simple.
    You really want an o2 gauge in place of the coolant temp gauge?
    Chicago, IL
    e28 m5, e34 TCD S3
    Quote Originally Posted by 89BMW735il View Post
    Stock FPR is good up to 600whp. Also stock gasket and all is good for around 350whp depending on your tune. If you are def set on MLS then make sure to look into how to prep the surfaces properly as that is critical. Look into goodntight. He is a user on here with a high power m30.
    For oil pressure sensor and such i went with this:
    http://store.nexternal.com/ireland/e...pter-p885.aspx
    Jun 2006
    Raleigh, NC
    E34, E368
    Why wouldn't you mate the TB to the middle of the manifold?
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    im going for a rather clean setup.. since i dont have a high HP goal. i can get away with alot.
    Sep 2003
    Brew City, WI
    Boosted BMWs
    Quote Originally Posted by EuroPartConnect View Post
    Also stock gasket and all is good for over 450whp depending on your tune.
    Maybe 350rwhp but certainly not 450rwhp.
    Todd DeHate - Turbo Charging Dynamics
    1985 535i euro LSX Turbo
    503rwhp/485rwtq
    Chicago, IL
    e28 m5, e34 TCD S3
    Post this on mye28.com. Many more FI m30's there then here.
    Quote Originally Posted by Turbo Charg Dynam View Post
    You are correct. Good&Tight had 370whp on stock head gasket/head bolts.
    Last edited by EuroPartConnect; 08-31-2011 at 11:39 AM. Reason: Automerged Doublepost
    Abbotsford, BC
    Unicycle
    400 - 410 WHP on stock 9:1 M30 is totally doable all day long. Did it for over a year on a gasket with 190K miles
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    So do you guys think ARP headstuds are overkill? Cuz I bought some. What WHP would be safe for my transmission. Do you think I could reliably do 350-400whp?
    Jan 2005
    Adelaide, South Australia
    Shitbox Suzi
    ARP is never overkill!!!
    No idea about the trans, BMW dont seem to make very good autos. (or at least, nothing made before the mid 90's)
    Fast, Cheap, Reliable - Pick any two, and the third is laughable
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    yeah ive got a 89 EH trans.. ARP studs are cheap compared to what i thought they would be.. so why not get them..
    should i replace my valves with new ones? i figured since i have the head off and it getting a 3 way valve job and decked it should have new valves..
    what are your thoughts?
    Jan 2005
    Shitbox Suzi
    as long as the valves are sealing, they should be fine.
    The exhaust valves should be inspected, as they will get a bit more of a workout when boosted.
    Off the top of my head, i cant remember what to do with springs and retainers. Someone had a thread a while back that mapped the rates and pressures on different stock springs, but that was M5X/S5X - not sure if thats much help doing a M30 though.
    Personally, i would strip the head, give it to a head shop in a box and ask them to give it a good going over.
    When you get the box-o-bits back, you can have the fun of lapping them into their seats. I always do my own lapping, i have had a few issues over the years with head shops not spending the time (and hence money) to get the kind of seal im looking for.
    [ame]http://en.wikipedia.org/wiki/ZF_4HP22_transmission[/ame]
    Seems that your trans has been used in quite a few different cars...
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    ok i dont wanna touch anything cause the last head i tried to remove the cam from got hammered to death to recover the cam LMAO (i had a new head just wanted the cam for wall art.. ) so i assume a valve job and a decking should be fine..
    all i have left to buy is:
    Miller MAF
    42lb injectors
    misc intercooler piping bits
    30x10x3 with 2.5 in /outlets Intercooler
    Boost controller
    new plugs and wires.
    have my down pipe fabbed up
    and maybe a MSD 6AL-2 for some fun..
    i dont think im missing anything else.. so this build should be done by hmm around H2Oi (which i will not be attending cause id rather spend the money other things)
    Chicago, IL
    e28 m5, e34 TCD S3
    Your stock trans without a different converter will be very poor. Bosst will be laggy and not to fun. If you plan on sticking with an auto get a converter from TCD.
    Jan 2005
    Shitbox Suzi
    I do believe that he mentioned that he was intending to make such a purchase.
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    but it will hold the power? if so then AWESOME
    Chicago, IL
    e28 m5, e34 TCD S3
    Not many people have gone FI with the factory auto. So not much info on how much it will hold. Todd at TCD had an auto for a little while with an m30 in his e28. He could have some insite to that.
    Nov 2009
    Glen Burnie MD
    89-735iL/03-745Li
    I just emailed Todd to see what he had to say about it. Hopefully I can get some good numbers without worrying about my trans breaking.
    Looks like my number will stay at 330whp
    Just so I don't have to swap transmissions. It's not that I can't drive a 5speed. I just don't wanna go thru the trouble to do the work. Anyone wanna make some money doing it for me haha. Il buy the parts and pay to have it put on. But I don't want to mess with transmission stuff anymore.
