great progress, keep it up
_____________________
1990 M5 Euro (French)
I'm needing some M5 love...any updates?
Current Garage:
91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
05 X3 3.0i -family workhorse - diamond schwarz
12 X5 3.5d - torque monster - space gray metallic
86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
88 Schwinn Sierra - 1WD Off Road Vehicle
e31 & OHC BMW CCA #385540
rear headrests = win :-P
No, not yet. I have a long list of leatherique products to buy including dye for the carpet and door gaskets. I have a full set of A/B/C pullars that I am ready to start recovering in black. I have the glue and everything.
I am not in too much of a rush with the car. I have been driving it for weeks with the rear seats out and most of the console and front trim out. I don't mind it. When I am driving all I care about is waiting for the oil temp. to warm up so I can start wailing on it. The car is still making trips to the grocery store fun.
Current Fleet:
E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
Past:
E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
E39 1998 528i 5-Speed Black on Black - Sold locally.
E34 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
Current Fleet:
Past:
nice work, is your plenum flap working yet on start up? Mine quit for some reason and I can't get it going again.
I need to double check it. I now know that a proper self test will have it raise two times, but I think it only goes up once. I also need to hook up the vacuum guage and make sure all is where it should be.
5.5kRPM hits you in the face pretty hard so my gut tells me that the resonance flap is not working as it should.
Current Fleet:
Past:
It should cycle twice within 5 seconds of start up. Have you checked your TPS to see if it clicks right when you nudge the throttle from idle? Car should be off to test this. Also, put a glob of vaseline on the tip of the flapper backstop screw so you can confirm that it opens at all after cruising around
nice!~
Current Fleet:
Past:
Nice work! Love the color! Looking forward to watching this come together
Gone but not forgotten:
'95 540i/6 M-Sport. GA65474. Alpineweiss/Parchment.
Supercharger project
Current Fleet:
Past:
Wow!!! What a difference. Great work sir.
What an improvement!
Current Garage:
That interior is going to be so awesome when you're done with it's resto.
Nice!!
The difference a little time+elbow grease makes is stunning! great work
Inspiring work... great to see you are enjoying bringing a hand built back to its former glory.
Sub'd.
wow. thats awesome.
I destroyed a vader in my e36 with leatherique. The dye didn't soak in the leather, it went on like paint. It peeled 3 months later.
Their conditioner is pretty awesome, though.
e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
Yeah. I am worried about that too. After each coat I am going over it with a damp paper towel to remove any excess dye. Worst case scenario is to sand it all back down and try another dye. Even after my final coat of dye I will probably wet-sand it with 1000 grit sand paper.
On the Nappa leather (earlier E34s - maybe until '93? It seems to correlate with having french stitching) the dye/gunk on top of the leather is much thinner than the stuff on the later leather. It leaves the leather less protected, but the feel is much better and it is very easy to remove.
Current Fleet:
Past:
Well if we back up a bit this is what has been happening with the interior after I pulled the console and rear seats out a few months ago.
As I have had time I have been soaking it in Leatherique's rejuvenating oil. The leather was like cardboard, so most pieces have recieved multiple coats.
Last night I finally felt ready to start prepping some of the parts for dye, so I used the Pristine Clean on them to clean all of the Rejuvenating Oil up. Once all of the residue from the oil was wiped up, I used the prepping agent they supplied me and some 320 grit sand paper on get rid of the old dye. I found that most of the old dye was already gone, so I did not same much. Time will tell whether or not I should have sanded more - but better to be cautious with such rare pieces.
I poured out the dye into a tupperware container and grabbed an old sponge. I dipped just the edge of the sponge in the dye, and was sure to stir the dye each time I went to pick some up with the sponge. The dye goes on very wattery but starts to be absorbed quickly. It is pretty easy to keep the application of the dye even.
The rejuvinating oil really brings out the small cracks in the surface of the leather, so believe it or not this is how the rear seat looked with very little sanding.
After a first coat:
Current Fleet:
Past:
