Hi,
My 1989 E34 M5 Eurospec had bit of fire damage cause by fuel line issue. It damaged some parts in the engine bay.
I am looking revive this and need some help with parts.
I've got a friend with 1991 E34 535i which he is parting it out and was wondering if there are any parts that I could use from it as compatible parts.
Things I need:
Brake booster setup
Engine harness(I know this won't be compatible but if you have one for sale from M5, plz let me know)
MAF sensor and intake pipes
Fuel lines
Any help would be great!
use realoem and compare part numbers.
Things to note:
M30 does not have a MAF (whole different setup) and the M5 ones are uber expensive.
Fuel lines under the car are the same, not sure once you get into the engine bay
if you need a maf, look into millers maf setup. theres also a guy in the classifieds parting an m5. dunno if anything enginewise is availbale but the brake booster might be available. like stated above, use realoem and see whats interchangeable.
-Alex
Did you miss the s*itstorm about the m5 miller maf?Originally Posted by AHenry014
MAF for M5? Take out a loan -.-
I know. They're convinced that they won't make any money.
From the outside it seems different.
________________________________
Nik
91' M5 3.9L Stroker
92' M5 3.8L
95' 540i6 Supercharged
95' 540i6 4.7 Stroker
95' 550i6 M70 Conversion
Check out the later pages of the Dark Knight build thread.Originally Posted by Triforce5
