Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Thread: What size wheel spacers is everyone using?
  1. #26
    Apr 2008
    Peachtree City, GA
    1996 ACS 850Ci
    No spacers here. Had a lousy experience with them on a previous vehicle. I won't use them again.
  2. #27
    Feb 2009
    Norway
    -90 850 -12 ///M550xd
    I run 245/ 9"x19 et 0mm front and 275/ 10,5" 19 et 14mm rear, no spacers, no rubbing or any issues what so ever.
    Rear
    -Egil (my name)
    2012 ///M550xd touring
    1990 850Ia Hartge Supercharged.
    2004 M3 (sold)
  3. #28
    Nov 2009
    Las Vegas, NV
    95 840ci 6sp,00 750iLV12
    Where did you find 30mm spacery hudcentric?
    Quote Originally Posted by Bryson View Post
    30mm (et -3) front and 15mm (et +12) rear, no wobbles. Good spacers shouldn't cause vibrations..
    Where did you find 30mm spacers? Are they hudcentric? I only found 15mm from H&R especially for the rear because of the flange lip or whatever that keeps others from mating up with the hub. I need 20mm
  4. #29
    Apr 2008
    Toronto
    850i, Alpina B7, E61
    I have a 10mm spacer wit 19"X9" with 265/35/19 up front and a 20mm spacer with 20"x11" with 305/30/20 in the back
    The front is lowered using H&R springs, the back is at sock height, I have the Eibach springs for the back, but haven't got around to installing them. I may not install the rear springs as the wheel fills the wheel well evenly.
    I would recommend getting a set of wheel hub extenders for above 10mm spacer.
  5. #30
    Nov 2009
    Las Vegas, NV
    What brand did you go with for the 20mm spacers. Part numbers would be great. Thx
    Sent from my SPH-L720 using Tapatalk
  6. #31
    San Jose CA
    1991 850i S70 6 speed
    I highly recommend going with M Techs in the back, which are perfect match for the front spring rates of H&R.
    I have gone through 6 different spring setups, and my favorite was and still is Mtech rears and H&R front. I have also a car with CSI everything all around, stock but engineered by M Division so they did their homework.
    alex
    Quote Originally Posted by TPIOlds View Post
  7. #32
    Nov 2009
    Las Vegas, NV
    Thanks Alex.
  8. #33
    Mar 2013
    netherlands
    850 CSI
    Spacers are for looks not for driving.
    Most of the time it messes up the geometry (tested it on several cars and hate them).
    Best is to keep original ET-values (or very close) and get rims that fit.
    Buy an alpina set or have a set custom made, so it still drives ok.
    BMW 850 CSI march 1994 (EU spec), SOLD. https://www.classiccars-forsale.com/...94-bmw-850csi/
    BMW 850 CSI november 1994 (EU spec)
  9. #34
    Nov 2009
    Las Vegas, NV
    Ok, let's say that I'm not mathematically savvy. What are the correct ET values for the flush look fitment? And what or how do I go about measuring to get the values that a custom builder would need? Vossen makes a custom wheel that I like.
  10. #35
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Agree with Huub's and Chuck's comments above - avoid using spacers wherever possible.
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
  11. #36
    Apr 2008
    Toronto
    Would you happen to have the part numbers for the Mtech springs??
    Quote Originally Posted by alex840 View Post
    alex
  12. #37
    Mar 2013
    netherlands
    850 CSI
    Quote Originally Posted by uinvyme View Post
    wheel size website has a nice tool for it.
    https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
    left the original size, right what you want
    below it will give you suggestions....... not an easy just put on a rim thing, as close as stock as possible (especialy the ET value).
    And the E31 has pretty strange ET values, in general most rims will not work on an E31.
  13. #38
    Apr 2008
    Toronto
    Here is the website I use
    https://www.rimsntires.com/specspro.jsp
    You could also do a test fit and do the math.
    I used a combination of both methods to fit my rims, and I had literally no time for error I got the rims back from the refinisher, fitted the rims to the car and it rolled out of the backyard for the first time on the rims at 11:55pm to be driven for my wedding in the morning.
    All the work and math paid off I had no issues.
  14. #39
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    No spacers front or rear with my e31 specific MKs. Front ET is 5mm, rear is 21mm fwiw...
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
  15. #40
    Nov 2009
    Las Vegas, NV
    Nice, glad you made it to your wedding in classic style
  16. #41
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    H&R spacers front and rear for me.
    20mm front (bolt-on) and 15mm rear (bolt-through).
    Bilstein shocks all round, Eibach springs at the front, M-sport springs at the rear.
    Wheels are 17" style 5s.
  17. #42
    Nottingham, UK
    E31, E36/7, E61
    alex
    Although they are not on realoem etc. the dealer should find them if you enquire. Peter at Sytners parts did explain to me why they are not listed once, can't remember exactly why, but they are colour coded, think that was something to do with it.
    these are the numbers.
    33 53 1 138 739 - spring
    33 53 1 136 696 - spring pad
  18. #43
    Nov 2018
    Sweden
    1994 840ci
  19. #44
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    I love how the original question was “what size spacers are you using” turned in to a thread that’s 90% people just showing off their cars without spacers on wheels that are hard to come by or very expensive or both.
  20. #45
    May 2009
    UK/Birmingham
    Bmw 540i Sport
    Quote Originally Posted by killian665 View Post
    Well it depends on your wheels
    The one I see in first post
    Looks like v20 hamann from e63 style
    They normally ET23 to ET38 not best size for E31.
    Sent from my SM-G960F using Tapatalk
    F13platform, on Flickr
  21. #46
    Jan 2012
    Denver, Colorado
    840ci
    Hi guys, will 18x9.5, 22offset work on the front?
  22. #47
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Certainly will!
    My BMW Repair YouTube Channel
  23. #48
    Jan 2012
    Denver, Colorado
    840ci
    Certainly will!
    Thank you Timm
